New Work Rig Build thread 1999 Suzuki Carry - Beyond.ca - Car Forums
Results 1 to 17 of 17
Thread: New Work Rig Build thread 1999 Suzuki Carry
    May 2004
    Default New Work Rig Build thread 1999 Suzuki Carry
    So the time has come for a new build thread. Picked up this 1999 suzuki carry db52t a couple months ago now, and have been slowly working on it since.
    You may also remember my build thread for the honda beat from before ( http://forums.beyond.ca/st/365543/la...ect-1991-beat/ )
    Sorry picture are gone, I'll try to host a couple here of the beat too.
    Some info:
    1999 Suzuki carry 4wd
    Imported through B-pro
    48,xxx kms
    All stock
    Mods so far
    Suzuki sport front bumper (da62w)
    Suzuki sport fogs
    Honda Acty rear and side panels
    Suzuki Every sport sideskirts
    Wirus Pro catback exhaust
    Tein front coils
    Special Garage front and rear overfenders
    Work 14 inch Cr01r rims
    195/45/14 tires
    here are some pics. Hope they work
    Start with a couple from when I first picked it up from its OOP
    click for larger version
    Made short work of the 12 inch rims and test fitted the low offset works. Fit with very little rubbing on the oem bumper
    My little helper
    Ill post another update right away. Just want to make sure these image tags work.
    May 2004
    next on the copping block was the muffler.
    OEM vs Wirus win
    then the front bumper arrived intact from Japan. I knew it had a blemish on the front driverside, but they were hard to find in near mint condition. These are found onthe sport edition of the van.
    mounted
    through my front blinds that shows the stance as well
    Next up was the honda acty sides and rear. Ordered these on a whim, not sure if they would work, or what mods would be reuired to make them work. I wasn't looking for perfection, but just wanted to add to it to make it a bit more pleasing to the eyes on the back end of the truck
    rears on
    While I was at it I decided to order the Every sideksirts to give it a lower feel to the ground effects
    You can see in this little bit distant shot that there really isnt much room between rims and skirts in the rear especially and front bumper
    Then I ordered overfenders rears on
    Fronts on
    And thats pretty much where she sits right now. Next post future plans
    May 2004
    Future plans
    Headliner - Think I'm pretty set on this fabric. The truck is for my aquarium maintenance company, so its right for the truck on a few different levels.
    ICE- (lol) car comes stock with only am radio, and only has a speaker in the actual din unit. There are spots for two 3.5 inch speakers in the dash, which are currently empty. I've got speakers, just need to find a cheap usb single din for it.
    Gauges - I have a bunch of left over autometer gauges from old projects, need to find an oil pressure one, then I'll have voltage, coolant temp, and oil pressure or temp.
    Steering wheel - I have an extra 330mm personal wheel from the beat and I have ordered the hub from Japan for it
    Seats - Still trying to work these out... I picked up a set of DC2 recaros from my good friends at JDM source that I will be trying to make work. The challenge being space, and access to the engine below the seats.
    Also working on some cedar side rails for the box. Gonna be a farm/race truck!
    Thought I would share with beyond. Hope you enjoy.
    Oh ya.... and an fnf pick of the beat when I showed up late to help a good friend move into his new place.
    Aug 2007
    93 integra
    you don't happen to work right beside bob's shop do you? urban x in the north? I swear i drooled over this very beat when i worked there...
    May 2004
    Default Nope
    Nope, but I'm in and
    Out of concept aquarium here and there and have driven it to work once in a blue moon.
    Just paid for an air suspension kit for the truck . Things are Gettin serious
    May 2009
    Medicine Hat AB
    General Motors Competizione
    Default Re: Nope
    This serious?
    I hope so.
    2007 GMC 2500 Duramax
    1981 GMC C1500 454
    May 2004
    Default Goals
    Yep. Need to keep it somewhat functional as I actually use it for work. Currentky battling a bad ignition on the truck. Just ordered a bunch of parts and have confirmed its ignition switch. Just need to get in there and drill away four "breakaway bolts ". What a pita.
    I've never done an air system, but it seems like it won't be too too hard. Front air struts are bolt in. Rears not so much. Truck currently has leaf suspension in the rear and they only make the air kits for the van version of the truck, which has coil springs in the rear.
    So from why I can gather we will have to 4 link the rear and make mounts for the air struts. Think I'll try to get the fronts on myself , mount the tank, compressor... Run wires and airline and then see if I can find a shop to help out with the rear.
    Anyone done anything like that for the rear?
    May 2004
    Default photodump update
    just a quick update as I have been super busy with work and got a new pup.
    First pic of pup
    Second, changed the mirror on truck to that of a suzuki every (power folding)
    Then painted bumper, tried three times and could not match paint that well, so theres a new colour of white on the truck... but, its a work truck! Also added air struts and yellow fogs, personal 330 mm.
    Comressor and tank are undermounted on bed, behind passenger as well as all valves. meter is mounted low on driverside and simple 3 way toggle switches were added to dash
    heres a photo dump including a couple I got from people that were at illmotions sunday school.
    next up is to tinker with the rear suspension and spoiler for tail gate
    May 2004
    So I’ve got a few mins between jobs today so I figured I’d do a bit of an update to this work truck as well as some other kei cars that have come and gone over the years. Will break it up into multiple posts between jobs so will probably update throughout the day.
    First off some cars I’ve owned and built during this time .
    If you’re an og beyond.ca member you might remember the Honda beat I built ages ago.
    I also owned a toppo briefly....
    And owned about 4 suzuki altos this one being the best one to show you
    I got the bug and bought another Honda beat. Still have this one. It’s away fro winter, but will be back in the spring
    And last but not least, I’ve got a couple of kids now and they wanted something they could both go in so I’mported and awd Honda that’s from japan. Lowered it, out some recaros in, and a couple of kids seats.
    It’s actually really good in the snow. Pizza cutter tires and Honda’s awd. Since these pics I’ve added mugen wing, and front and rear lips as well.
    Next post will be mini truck updates
    May 2004
    Default Mini truck
    Here she is in all her glory.
    Recently found in auction the super rare hello special body kit. Complete. And after some intense budding, was able to take her home to Canada.
    Went from this....
    To this
    Auction included a dual exhaust for it as well. Which I rigged up so I could throw the rear bumper on.
    Mar 2005
    Pushbroom
    Awesome! Man I love your builds
    May 2004
    Holy moly . Been a long time since I've updated this ...
    Added a lowered utility decal to it after someone posted it on Reddit and everyone was up in arms that I'd made it useless.
    Wow! That's so cool! What a unique project.
    Jan 2017
    Summer car or work truck
    I am so in love with this......
    Mar 2010
    Ioniq 5
    Same, I want it haha
    May 2004
    My 8 year old daughter would kill me . She's already picked out what colour she wants the wheels, headliner and steering wheel for when she gets it when she's 16.
    Mar 2005
    Pushbroom
    This thing is so cool
  1. Replies: 87
  2. Fs: 1993 4wd Suzuki Carry
    By monkee_pride in forum Trucks, SUVs, Vans, Trailers
    Latest Threads: 08-17-2013, 12:47 PM
  3. Drilling Rig Versus Service Rig
    By phaedrus16 in forum Careers
    Latest Threads: 01-22-2013, 05:14 PM
  4. (project unnamed) new rig build at the shop .
    By lemon-aid jay in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 04-06-2010, 03:34 PM
  5. Help me Build A New Gaming PC Rig
    By s--dime in forum Computers, Consoles, and other Electronics
    Latest Threads: 02-02-2007, 10:26 AM
