Turning Brake Rotors - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Turning Brake Rotors
    Aug 2002
    992 T-hawk Golf R
    Default Turning Brake Rotors
    Do shops still turn brake rotors that are warped? If yes where is a good place and any idea on cost?
    I like neat cars.
    Jan 2016
    Most places just put on new. There is a lot less warranty issues
    If someone does still turn should be around 30 or so. Pending on the car a new rotor could be that or a bit more
    rs4, ram, 675f3
    I have a set of rs4 rotors that need to be turned but i heard they dont turn drilled rotors??
    At audi they are $830 per rotor. Managed to get some for $550 per rotor.
    Jun 2012
    1290SDR, 701SM
    brand new car, warped rotors at 13,000 KM. They put them on the machine. Warped again at 16,000. Put new rotors on. Should have just done it in the first place.
    Aug 2002
    992 T-hawk Golf R
    Interesting article that I found on warped rotors.... Apparently it's a myth and the vibration is caused by pad material transfer onto the rotors.
    http://www.stoptech.com/technical-su...nd-other-myths
    The obvious question now is "is there a "cure" for discs with uneven friction material deposits?" The answer is a conditional yes. If the vibration has just started, the chances are that the temperature has never reached the point where cementite begins to form. In this case, simply fitting a set of good "semi-metallic" pads and using them hard (after bedding) may well remove the deposits and restore the system to normal operation but with upgraded pads. If only a small amount of material has been transferred i.e. if the vibration is just starting, vigorous scrubbing with garnet paper may remove the deposit.
    Followed by this:
    The only fix for extensive uneven deposits involves dismounting the discs and having them Blanchard ground - not expensive, but inconvenient at best. A newly ground disc will require the same sort of bedding in process as a new disc. The trouble with this procedure is that if the grinding does not remove all of the cementite inclusions, as the disc wears the hard cementite will stand proud of the relatively soft disc and the thermal spiral starts over again. Unfortunately, the cementite is invisible to the naked eye.
    I like neat cars.
    There is actual warping (which can be caused by various reasons) and then there is cementite issue as mentioned above.
    I have a warped rear disc on my lowly civic, less than 2 years old and 20,000 kms (on the rear). Cause? Axial warp. Dial indicator shows too much run out.
    My fault for buying cheap chinese discs for the rear. They rust like shit after 2 days of rain and I drive pretty tame as far as acceleration/deceleration (I only corner hard).
    AB
    16' Tacoma Offroad
    Most of the time it is pad material, but cheap metal results in poor characteristics.
    Ideally you'd use an on-car-lathe but they are typically only in dealerships.
    Aug 2002
    992 T-hawk Golf R
    I think it was pad material. After some hard driving it appears to have fixed itself.
    I like neat cars.
  1. LF: someone to install new back brake rotors and brake pads
    By mard in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 06-12-2009, 07:12 PM
  2. Turning Rotors @ 12,000 mi
    By malonesm in forum Mechanical
    Latest Threads: 07-17-2007, 03:43 PM
  3. Magnum Cross Drilled Rotors or KVR Cross Drilled Rotors
    By JDM_RS13 in forum Performance Modifications
    Latest Threads: 06-13-2005, 07:51 AM
  4. Noise while turning, brake release squeak
    By adrenalman2004 in forum Mechanical
    Latest Threads: 06-27-2004, 05:25 PM
  5. Brake rotors... high and low quality??
    By homie in forum General Car/Bike Talk
    Latest Threads: 07-13-2002, 03:54 PM
