Cement foundation or treated wood foundation... - Beyond.ca - Car Forums
Results 1 to 20 of 26
Thread: Cement foundation or treated wood foundation...
    Nov 2003
    2008 Mercedes Benz C230, 1968 Chevy Impala
    Default Cement foundation or treated wood foundation...
    I'll likely continue to have more questions from you all as I continue learning about homes.
    I have come across both building methods. I would have thought in a climate such as ours that receives a good chunk of precipitation would lead one not to use wood for foundations. But Im finding a good chunk of the homes in the Shawnessy/Evergreen area have these.
    Thoughts/experience with either?
    1968 Impala: Status: Stored
    1977 Dodge Triple E RV: Sold
    1989 Mercedes Benz 420 SEL: Sold
    2008 Mercedes Benz C230: Cruising
    2000 Bluebird TC2000: Build phase of skoolie project
    2018 Rav4 XLE: New baby friendly daily
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    i wouldn't have a wooden foundation. ever. It would always be an impermeable material that doesn't rot.
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
    Sep 2012
    Neither. I prefer CONCRETE.
    Is there a price difference when building with wood over concrete?
    I'd imagine concrete is more expensive. It's much easier to screw up a wood foundation to have years of problems. I'd pay the extra for the concrete.
    Jan 2016
    The YYC
    Parked in the Bike Lane
    Default Re: Cement foundation or treated wood foundation...
    Originally posted by cycosis
    ... a climate such as ours that receives a good chunk of precipitation...
    WTF? Calgary is a desert. Extremely dry. Are you talking about somewhere else?
    V8s
    Never go with wood foundation, there's no good that can come of it. I would avoid buying a house with one for sure, and if you're building, it's a tiny incremental cost for concrete (percentage wise of total home cost).
    Nov 2004
    edmonton
    Ford
    any pics. ive never seen a wood foundation, always concrete.
    Street Tune
    446HP 536TQ W/6# Lower, 3.5 upper 16* and 16psi
    The SHBARUS
    Are you sure those are not just wood form for the concrete foundation?
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    It sounds insane to have wood in contact with soil
    Nov 2003
    Were you not around this summer with all the rain? I get that we dont have a lot of humidity and that we dont see months on end of rain like vancouver, but to say we are always completely dry is not accurate.
    Its a concrete pad with full treated wood walls.
    Oct 2009
    There are plenty of 100+ year old homes in Calgary that have wood foundations.
    While I agree with your point, The homes built 100 years ago lasted a lot longer than any new ones will last.
    Nowhere
    Probably because the wood treatment chemicals they used 100 years ago would be all cancer-causing
    Jun 2003
    Canada
    GMC Sierra
    I'd be interested in seeing some examples of what you're talking about. I'm in restoration construction and have worked on mostly old buildings in Calgary recently. I haven't seen any wood foundations yet, just old sandstone foundations.
    Elbonia
    Jeep of Theseus
    When a few Beyonders were volunteering doing cleanup in Mills Estate after the flood, the house we were working on was definitely on a wood-only foundation. Not sure of specific age, but it would have been an original building in that neighborhood. Sorry, didn't take any pics, but I'd assume that many houses in that area would have been built the same way. It was on New Street, if I remember correctly.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Originally posted by BerserkerCatSplat
    When a few Beyonders were volunteering doing cleanup in Inglewood after the flood, the house we were working on was definitely on a wood-only foundation. Sorry, didn't take any pics, but I'd assume that many houses in that area would have been built the same way.
    Wasn't it just an old dug out with a subfloor?
    Elbonia
    Jeep of Theseus
    Possibly, although I do remember vertical beams of some kind as it was a reasonably large dug out area and the house had to have been supported somehow. Maybe my memory was fuzzed by the sewage stench, that was nasty.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    It was a super weird diy basement reno for sure
    Apr 2003
    '03 S2000
    PWF (Preserved Wood Foundations - the darker green lumber not simply stained) have been around for a while and have to be designed/stamped by an engineer. Before engineering school I worked on some (carpentry). They are in the Alberta Building Code and there are CMHC/CSA guidelines for how they are to be built.....e.g. drainage system, size of lumber/plywood to resist soil pressure (better than concrete in this regard incidentally!), treated materials, and the special poly wrap used on the outside to provide a moisture barrier, metal ties anchoring the lumber etc.
    The biggest advantages are quick construction (wood framing) and better insulation e.g. wood and insulation vs. concrete ... also thinner/added space inside.
    I have noticed those wood basements tend to be warmer.
    Design life? 75 years just like a concrete basement.
    Done properly (like anything) there is nothing wrong with them.
    (yes, have built and designed them)
    Cheers,
    R
    "I don't look for something; I find something" - Picasso
    Apr 2003
    '03 S2000
    Here's some info on PWF via Goggle search:
    http://www.townofunity.com/mrws/file...dwoodguide.pdf
    http://woodfoundations.com/
    http://www.woodpreservation.ca/index...od-foundations
    So there are a number of advantages ... even designwise and especially in our winter for construction (too cold and you cannot pour concrete and it can be damaged) and also for warmth, cheaper to heat etc.
    So really nothing wrong with them and they won't crack ... unlike concrete.
    I would check one over first (like any foundation for that matter) or even have an engineer look at it beforehand but would not hesitate buying one myself.
    R
  1. Deck Staining - Pressure treated wood.
    By ganesh in forum Home and Garden
    Latest Threads: 05-03-2018, 01:32 PM
  2. GRAY pressure treated wood?!
    By Sonic in forum Home and Garden
    Latest Threads: 06-05-2017, 12:49 PM
  3. FS - Pressure Treated Wood - LOTS!
    By Boosted_TL in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-24-2014, 03:54 PM
  4. Question for the men: How do you want to be treated by a woman?
    By Sykes in forum Society / Law / Current Events / Politics
    Latest Threads: 06-02-2009, 11:05 AM
  5. FF: 11 1"x5"x6' Pressure Treated Cedar
    By bennyhanna in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 05-27-2007, 04:53 PM
