Monitor goes blank every few minutes - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Monitor goes blank every few minutes
    Jan 2016
    The YYC
    Parked in the Bike Lane
    Default Monitor goes blank every few minutes
    This is weird an annoying, I run my laptop through a monitor when I'm at home, and the monitor goes totally blank for a couple of seconds every five minutes or so. It's acting like a loose connection, although I have checked both ends of the cord and that isn't the case.
    It also does this with two different laptops, so I'm guessing it's something in the monitor. Or could it be something internal to the cable?
    Any troubleshooting tips? It's a cheap-ass bottom of the barrel LG monitor, but it's all I need and I would prefer not to replace.
    May 2008
    Wildflower Ranch
    Neo-Liberal Anarchist Mobile
    Did you try turning it off then on?
    Beyond, bunch of creme puffs on this board.
    Everything I say is satire.
    Mar 2009
    '18 Murano
    Good call, Roy.
    Sounds like either the A/GPU is overheating (if separate) or the monitor is done. You'd need to test the monitor from a different source.
    If it is the monitor, sometimes its also the power supply transformer (power brick) thats gone.
    Jan 2016
    The YYC
    Default Re: Monitor goes blank every few minutes
    Oct 2009
    Unknown
    If possible, restore the monitor to default.
    Mar 2010
    Ioniq 5
    Some random troubleshooting steps:
    - Try the other input (DVI if you are using VGA, or vice versa)
    - Try a lower resolution
    - Try resetting the monitors settings
    - Try a different cord, could be a damaged/crushed wire inside it
    - Smash monitor with a hammer
    Feb 2016
    Try connecting the laptop to your TV. This way you know it is not the cable at fault if you get a picture. Isolation of variables. Sounds like a toast monitor from here.
    May 2008
    Wildflower Ranch
    Are you sure you entered the correct password?
    Jan 2016
    The YYC
    The plot thickens! Tested with a second monitor, and the behavior continued.
    Decided to try connecting with an HDMI cable, and oddly, the monitor gives the errors "no cable connected". The computer can "see" the monitor however in the intel HD graphics control panel and says it's working correctly.
    Ideas?
  1. 1 speeding ticket issued every 3 minutes during Deerfoot Trail crackdown
    By schocker in forum Society / Law / Current Events / Politics
    Latest Threads: 07-07-2014, 09:14 AM
  2. Replies: 5
    Latest Threads: 09-27-2009, 04:16 PM
  3. Replies: 26
    Latest Threads: 07-05-2008, 01:10 AM
  4. a few fill in the blank ( politics )
    By Moe Man in forum Society / Law / Current Events / Politics
    Latest Threads: 10-05-2004, 10:09 PM
