Recently, been noticing the hot water pressure in the house getting lower and lower. Its still enough to take a shower and use but definately compared to the cold water pressure its way too low.
And this is throughout the entire house which leads me to believe its the hot water tank.
Upon visual inspection, everything looks fine, and working fine. Its a newer updated tank I think in 2005. So I'm guessing the problem is the water outlet is clogged with calcium and whatever else blocking it.
House has PEX pipe so I don't think I need to cut and solder pipes. Do I just un-screw the outlet pipe and clean or any tips? I'm gonna drain the hot water tank first and see if that helps (first time I've done this since moving in)
