Shop destroyed wheel lock key - Beyond.ca - Car Forums
Results 1 to 20 of 24
Thread: Shop destroyed wheel lock key
    Apr 2004
    Default Shop destroyed wheel lock key
    My sister brought her car in to get some winter tires installed that I ordered for her, and later on I get a call saying the wheel lock key "blew up" because it was over tightened. I'm the one who last installed the wheels, and I know I used a torque wrench to 85 ft lbs...so I don't buy their excuse.
    Here's a pic
    click for larger version
    And to make matters worse, they charged me $76 for his time to remove the 4 lock nuts manually.
    Does this sound like something that could really happen? I feel like it was a new tech that doesn't know how to use wheel locks that fucked it up, and I would rather not pay $75 for something that's their fault.
    Thoughts?
    Sep 2008
    Turbo stuff
    Those things wear and tear, they occasionally do that. Not really their fault. Not yours either obviously. Just, shit happens.
    I had one break clean once and the little pattern was completely intact, but broken off of the key.
    Try and get em to go halfers on a new set of locking lugs, or just keep regular nuts on the car and try and get em to go halfers on the labour for removing the locks.
    Nov 2004
    W204
    Pretty much what Sentry said, I had the same thing happen to me a couple weeks ago changing my tires, the key just broke like your picture and took me a little longer to get the remaining locknut off.
    The charge from the shop is justified if they had to remove all 4. I'm sure they could have called you before removing the locknuts and let you approve the charges, but I guess this saved you making the extra trip and you were able to get your wheels/tires changed especially with how busy shops must be during the rush.
    Dec 2006
    Lease
    I had GM factory wheel locks break apart too OP, changing myself, and I always make sure it's aligned. Always have a spare set of wheel lock in my garage (just $19-30 anyways), learned it working in shops that wheel locks break apart. Kinda saved the night not having to drive the other vehicle to grab a set (in the middle of the night/stores closed)
    May 2004
    2005 F350
    first thing i do when i get a vehicle is remove those fucking things. just more trouble than they're worth imo.
    If they called you and told you they will be charging an extra $76.00 to remove them and you agree then of course pay for it. Otherwise I wouldn't pay for it.
    Also wheel locks are garbage and worthless. I've had them break in the past as well.
    Apr 2004
    well they did call me to tell me it broke on the first one and that they need to use a tool to remove the 4 other ones, but no price/cost was quoted.
    Anyways i'm not too concerned about the cost if it was a legitimate thing that happens and not their fault due to incompetence... sounds like this happens quite often so i'll drop it and pay for their time. I was just surprised because i went 8 full years of owning this car changing the wheels every summer/winter without any issues, then the first time i take it to a non-mazda shop it gets destroyed.
    guess it's just bad luck... i can imagine the frigid cold also makes these things a bit more brittle too so maybe that contributed.
    thanks for the replies and yes definitely not using wheel locks any more after this. don't even know why mazda thinks their stock 16" rims warranted locks back in 2008
    Mar 2015
    Lethbridge AB
    1994 Mustang, 2007 F150, 1991 Volvo 240 Wagon
    Wait, why couldn't they use their own key after destroying yours? Don't most reputable shops have their own set of common lug nut keys?
    Or were the lug nuts stuck on?
    1994 Mustang - SBF swap in progress
    May 2004
    2005 F350
    chances are slim to none that a jobber shop will have a key that matches.
    we have over 100 different key possibilities for my brand at work. that is just 1 OEM supplier. can you imagine what is out there?
    Using an impact gun on locking lugs could cause it to break sooner.
    Also never recommended but I've seen shops do it.
    Mar 2015
    Lethbridge AB
    Missed the oem key. Thought it was aftermarket, I know places like Kal tire have their own set of typical aftermarket.
    Feb 2004
    78 civic
    I hate when this happens. I'm now recommending people don't use them. I personally think you have a greater chance of having wheel lock problems vs wheel theft.
    Bunch of Honda's
    This.
    Should be cross referenced with this thread:
    http://forums.beyond.ca/st/401433/wh...it-in-calgary/
    May 2008
    I've broken three of these by hand. I'll never use them again, especially seeing how fast the lugs can still be taken off with an impact gun.
    Jul 2005
    I had nothing but problems with them as well, bought some good project kicks locks for one of my cars, other doesn't have the factory ones anymore they only lasted a year and broke off .
    Dec 2008
    Weird, I've had 3 sets of mcgard ones and never broken or damaged any? Must be hit or miss with these
    Chinatown
    FJC, S30
    I've had my OE set for 10 years. Knock on wood. They are used twice a year and it's fine. Then again, only balance auto garage touches my car and they take plenty of care.
    Submaker.Illest.
    AB
    16' Tacoma Offroad
    Seen lots break from improper torquing. I typically under torque the lock key to prevent this.
    Trucks with keys are absolute assholes.
    Oct 2006
    Nothing
    Same - I had a gm one break on me and I ended up smashing on a socket to get the @#$#@ off. Hate wheel lock keys with a passion - and really, they'll only stop an incompetent thief, not one who wants your rims.
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    So it's been 10 days and still no one has mentioned it...
    Your sister has a cute hand...
    ...@therealarifjina...
  1. FF: McGard wheel lock key #04640
    By JDMMAN in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 06-04-2017, 12:11 PM
  2. Replies: 1
    Latest Threads: 05-27-2015, 06:18 PM
  3. FS: CG Lock seat belt lock
    By OneUpYou in forum Automotive Parts
    Latest Threads: 08-14-2014, 12:46 PM
  4. WTB: Xena Lock Motorcycle Disc lock
    By jacky4566 in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 06-04-2014, 08:10 PM
  5. Replies: 28
    Latest Threads: 07-03-2007, 11:19 PM
