So I shut off my taps and removed hoses back in October. I have a newer house with an unfinished basement that's at about 21 degrees all the time. Now that I'm at site I started worrying about that pipe freezing because you do things on automatic unsure if u turned off shut off valve or not. I have a buddy with a similar aged house less than 10 years old and he keeps his taps on so he can fill his ice rink all winter and he has a finished basement.
I feel like I should be at less risk because the area around my water pipes is always high temperature the only frozen part are the two outside spigots that I believe are frost free and only stick out 2" from house.
