Rent/borrow a thermal imaging tool? - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Rent/borrow a thermal imaging tool?
    Thaco's Avatar
    Oct 2004
    Rage2
    Default Rent/borrow a thermal imaging tool?
    My inlaws live in a bungalow (relatively new, like 7 years old) and the master bedroom is above the garage, its cold as shit in there, like 13* when the rest of the house is 24...
    I know they can hire someone to do a thermal imaging scan or whatever, but i just wanted to do it myself out of curiosity, anybody know any places that rent them out? likely only need it for a couple hours.
    User title molested by Rage2.
    ^^ Fact Checked
    Only 15min from Aspen!
    Nothing interesting anymore
    You don't need the tool, I can tell you without one that they didn't put proper insulation between the garage ceiling and the bedroom subfloor. Same thing happened to a few people.
    Dec 2011
    Pretty much this. Also, a fully insulated garage helps the room above it as well, doesn't flux with deep freezes as much. Bud had a living room above his garage, always felt cold, added insulation in the garage and a small space heater and the room above the garage now sits at the right temperature.
    Thaco's Avatar
    Oct 2004
    Rage2
    i assumed this as well but they are convinced its the windows, just because they frost up... so i wanted this to show them they're wrong :P
    ^^ Fact Checked
    There's a Holmes on Homes episode on this. Forget episode # though. It was the floor.
    Pricey to rent but here:
    http://www.rogersrentall.ca/equipmen...9&key=006-0070
    Edit: Also look at the cold air returns. Maybe not hooked up or not enough.
    Tell them they're frosting up because of the humidity coming from melting snow in the garage.
    Not Aspen
    Two from Freemont
    Also, make sure they vents are balanced.
    That room is likely furthest from the furnace and if the rooms that are closer have the vents open full tilt, you aren't getting enough hot air to that room.
    Thaco's Avatar
    Oct 2004
    Rage2
    yeah i considered that as well, even if we close all the other vents it barely helps in there, its not that far from the furnace, the furnace is basically on the front wall in the basement, pretty much a straight shot up an interior wall to the room, so it should be fine for airflow
    i am pretty sure its 90% the floor, just need to prove it
    ^^ Fact Checked
    Jan 2005
    C/AB
    AP1 / CRV
    I had this problem and after screwing around with vents and really getting nowhere, I ended up just making my own mini climate control loop for the bedroom with an inexpensive electric radiant oil heater and a thermal relay controller (link below) works a treat.
    https://www.amazon.ca/Inkbird-All-Pu...+control+relay
    also I have a Seek Thermal cam if you still want to measure
  1. Thermal imaging camera
    By RawB8figure in forum Home and Garden
    Latest Threads: 12-06-2016, 01:08 PM
  2. Consumer InfraRed Imaging - FLIRone vs Seek Thermal
    By v2kai in forum Computers, Consoles, and other Electronics
    Latest Threads: 09-25-2014, 01:55 PM
  3. thermal imaging recommendations?
    By JVR1 in forum Real Estate / Finance
    Latest Threads: 10-27-2011, 03:43 PM
  4. Replies: 3
    Latest Threads: 12-19-2009, 04:33 PM
  5. Replies: 5
    Latest Threads: 06-12-2006, 06:30 PM
