Educate me on CBD Oil - Beyond.ca - Car Forums
Page 1 of 5 1 2 ... LastLast
Results 1 to 20 of 99
Thread: Educate me on CBD Oil
    Jun 2003
    Default Educate me on CBD Oil
    Is anyone using CBD oil to treat joint inflammation or arthritis? I have always suffered from rheumatoid arthritis on my legs usually on my knee or my ankles, sometimes it will start with a swollen knee and it would then transfer to my ankles. I've been to the hospital several times in the past to get it checked and I usually get sent home with NSAIDs that I don't like using or told to take some extra strength Advil. It's been like this for years sometimes it will happen 2-3 times in a year to the point that I can't walk unless I take a lot of Advil. I haven't been to my doctor recently but as I get older, I feel that I need to look for alternatives as I know how destructive pain killers can be to the body.
    I tried looking it up online but there are so many products out there, it's quite overwhelming. I'm looking for something that can be ingested and be able to function normally. I was told to set up an appointment with Natural Health Services and will probably go that route. I just wanted to get some feedback from people who use it or have used it in the past to treat inflammation or arthritis. Thanks
    6.7 CUMMINS, E50 AMG
    When you go to natural health make sure you tell them your looking for oils, unless your ok making your own butter (easy)
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Tell the "bud geniuses" as they are the ones that will help you pick a producer, and not all producers have oil
    Personally, I'd go with a topical... even with thc there is no high. Anything you ingest will take a while to build up a tolerance even if it's cbd specific, as there are still trace levels of thc
    Homemade Epson salt baths are amazing for joint and muscle pain and inflammation... you come out just feeling like jello... it's basically just activated coconut oil (decarbed bud, then warmed in coconut oil, and strained) so if you just made that (all oils from producers seem to be sunflower oil based, and 3x the cost of the bud that's in them) then you could probably just rub it on the areas you need it
    Jun 1987
    SK
    Fit Dugan Signature (2016)
    It will do nothing for you, there is zero medical benefit from cannabis. Moran.
    - Gestalt
    Originally posted by SJW
    Originally posted by snowcat
    Consistency and potency are really variable, even when buying "the same stuff as last time"
    Science-y-type-discussion:
    https://fivethirtyeight.com/features...ay-every-time/
    look, if you stick your dick on my shoulder, then I'm gonna stick my dick on your shoulder. That's how shoulder dicks work.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    That's a pretty wordy article for what could be summed up as "not everyone tests their batches"
    Which is less of a concern up here, with the licensed producers we have... but if you're ready worried it's best to stick to bedrocan as they are one of the few research grade growers
    Dec 2008
    C.Dot
    Marijuana and all of its components are highly addictive and cause immediate death to your body and mind. Don't use it. Do you want to end up panhandling on the street trying to figure out who stole your goodwill sleeping bag? No? Don't do drugs...
    It's many times more poisonous than any pharmaceutical grade drug. Especially those non kidney and liver toxic nsaids.
    [SIZE=0.05]The message endorse by pfizer.[/SIZE]
    Originally posted by ZenOps
    I say we slow down the spinning of the earth so that there is 25 hours in the day.
    Join me.
    I'm not any kind of expert, and also not a consumer. Any independent testing done in Canada?
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    As long as you go the LP route there sure is... the BC dispensary route? Not so much
    Also with the LP's you're locked into one grower basically so the consistency is much greater than multiple sources for the same strain that the article was also touching on
    But again, bedrocan is a whole different level... they're the original medical cannabis company from Europe so their processes at this point are very consistent
    Nov 2004
    edmonton
    Ford
    you can split your prescription between multiple LPs. i have 3 gram a day split to 2 different LPS
    Street Tune
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    NHS' official stance is they will only split after first follow up appointment, I say official cause the gf got her's split right off the bat, mostly cause her first choice didn't do oil, and she was recommended to use it (which she doesn't haha)
    So we have 3 between us, bedrocan has been the only consistent one though for always having their full line in stock
    Other two are aurora and mettrum
    But the point is if you order "sour diesel" from xyz, it's going to be the same master that the clones are from every time vs grey market weed which is whatever the grower claims it is for marketing purposes (which is what the article was talking about)
    YH2/FK8
    Currently have 3 LPs in the household. Both my GF and I use the oil. I use it for pain/inflammation for the knee and she uses it for migraines. Works pretty well for the most part.
    Although strains that are grown aren't 100% consistent, they usually fit within range of THC/CBD levels they are supposed to be in (UK Cheese - Hybrid - 14.00-17.00% THC; 0.00-0.30% CBD for example) and the prescription label and ordering info will reflect that. LPs are under Health Canada and have to test everything they produce in terms of THC/CBD%, contaminants, mold etc.
    Anyway, when you go in, just let them know what you need it for and the Bud Geniuses will point you in the right direction to best suit your needs. Some oils are more expensive than others.
    If you are an approved home-grower, there is a list of labs that you can send samples of your cannabis to for testing. A number of them are the same labs that the LPs use, if not their own.
    2008 BMW 335i - 2008-2013
    Unknown
    What is the scientific explanation for this?
    I'm suspecting it's the placebo effect. Also, once the bather hears the miracles of Epson salt water, they're also more inclined to soak longer in the miracle hot water, instead of a shorter "regular water" bath.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    It's the infused oils that are doing the work, the bath just gives the entire body an even coating
    The (activated) thc/cbd does wonders for inflammation, actually thca is probably even better, but since I make it with leftovers from the vaporizer it's activated... and still works. It's not a placebo effect, you feel the warming, tingling sensation as soon as you touch any "canna butter" or infused fats, I also have a hot tub that I soak in just as long. Even with the jets it's not even close to the same relief or sensation. Plus if you don't rinse off the residue it lasts a long time. ie. I was fresh out of the tub when I made that post last night, and I'm still feeling nice and loose
    Edit: and since I'm not a doctor, I'll let the pros explain them
    https://www.leafly.ca/news/cannabis-...nabis-topicals
    YH2/FK8
    Apparently Cannabis Massages are a thing now in the states. I've read some pretty interesting and positive reviews so far. I'd be intrigued to try it if it were ever available here.
    Anyway @ercchry, how do you draw the bath with the oils and how much do you use? I did the same thing as you, I made some coconut oil recently with leftover Volcano trimmings, but I made it to ingest. But this bath sounds interesting.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    I used a "commercial" bath bomb as reference, but at $14 a pop (from dispensary)... fuuck that. It was 30mg of thc so depending on the strength of your oil use that as a base?
    But yeah, basically start with your typical coconut oil... then what I did was mixed it into the Epson salts (worked out to be a 8:1 ratio) and added some essential oils and nice smells and whatever... gf used it all before I got a chance to try it
    So for my bath I just added a tbsp of oil right to the hot water, with the salts and some bubble bath, made sure it all melted and mixed the water up well before getting in. Then soaked for about an hour. A massage afterwards would be ammmmmaaaazing
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Okay, found what I used as a guideline... 16:1 for the salts:oil
    Made 1cup of oil (probably closer to 1.25, but then loss from melting)
    Had 18g of med brown vape poo I'd say half of it started life as either 8/8% thc/cbd or 0/9 and the other half being 17% or 22% thc
    1-2g of fresh 9% cbd only premilled
    Then maybe 20ml of mettrum's cbd only oil
    So yeah 15ml/bath of infused oil. Too much? Not enough? Dunno, hard to gauge without any sort of high involved
    Affordable Condo
    V6 Hybrids
    ercchry needs a custom user title for his knowledge on this stuff
    Originally posted by rage2
    Shit, there's only 49 users here, I doubt we'll even break 100
    I am user #49
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Haha, I watched too much viceland when it was on free trial
    Doing a little math, if we say the average strength of the material I used was 5% then 15ml of this oil is 60mg thc
    Whoops... and looking at dixie elixir's bath soak they recommend 10mg/bath
    YH2/FK8
    *SNIP*
    Awesome. I'm gonna try it out. I may have to pick your brain more. Expect a PM or two.
    I've been making butter/oil via sous vide with consistent results from my edibles. I've been recently looking into the baths and massage oils for all the oil I made, so this is a good starting point.
  1. Replies: 20
    Latest Threads: 10-17-2005, 10:00 PM
  2. Educate me
    By oddjob in forum General Car/Bike Talk
    Latest Threads: 02-01-2005, 11:27 PM
  3. DVD burner! educate me!
    By Daddymax in forum Computers, Consoles, and other Electronics
    Latest Threads: 01-03-2004, 10:39 PM
  4. Looking to get a Subaru Legacy Turbo...educate me.
    By Gripenfelter in forum General Car/Bike Talk
    Latest Threads: 11-06-2003, 04:15 PM
