School me on Countertops - Page 2 - Beyond.ca - Car Forums
Page 2 of 2 FirstFirst 1 2
Results 21 to 27 of 27
Thread: School me on Countertops
  1. #21
    Oct 2004
    Rage2
    Just looking at some more options, i might just go with the ikea in stock countertops (it'd cost under $200, that way it doesn't hurt so much now since i plan to get a stone countertop later anyway, just not in the budget right now), they don't have a backsplash so they should be easy to cut, then just use something like this instead of normal miter bolts since i dont have a router or anything.
    https://www.richelieu.com/ca/en/cate...085/sku-917282
    Only thing that sucks is they only come in 98" and i need 102", so i will need a second joint.
    User title molested by Rage2.
    ^^ Fact Checked
  2. #22
    Aug 2005
    Calgary Alberta
    That should work, just remember to tape the cut line with masking tape and use a decent blade- laminate like to chip when saw cut. those bolts are neat but if you can hold the seam tight, even a scrap piece of 1/2 OSB or mdf with a few short screws on the bottom would hold it in place for you.
  3. #23
    Oct 2004
    Rage2
    thats actually a good point, i have a few feet of perforated angle iron at home, i could probably just rig something up with that, just put a couple bolts through it, i'd likely remove it after the glue sets anyway, might replace it with some low profile plywood or something, the corner unit is a pullout anyway so we will never be actually reaching in there.
    same as this
    I might even do an alternative mitre cut on the corner so i can avoid a second joint, could do like a bulkhead mitre to make up the 4 inches we'll be short on the countertop. Kind of like what jwslam showed above
    ^^ Fact Checked
  4. #24
    Apr 2004
    Edmonton
    2020 Genesis G70
    Originally posted by C_Dave45
    If you go with someone like FloForm, be prepared to double his budget at least. I've done work for them, they're not cheap. Good work, but you pay for it.
    I actually just had a quote from them. Counters, tile, sink, faucet for kitchen and main floor bath. $14K. I haven't had time to get any other quotes yet though. I was hoping for under $10K...
  5. #25
    Jun 2003
    KTM
    Originally posted by spikerS
    https://www.rustoleum.com/product-ca...ransformations
    get it at HD for couple hundred bucks.
    I know people who have used this. Doesnt hold up very well but looks good initially.
  6. #26
    Oct 2004
    Rage2
    i actually found out ikea's custom countertops for laminate range from $17-$28 ln/ft so for my setup i'll be looking at roughly 15 feet so that's really reasonable, i'll probably end up going with that, they make the sink cutout, edge contour and mitre cuts for you as well, just working on getting the cabinets 100% fitted for accurate measurements before ordering, i will probably order it this weekend though.
    ^^ Fact Checked
  7. #27
    Oct 2004
    Rage2
    so i ended up going with Ikea custom laminate, $420 @ $28 lin/ft (self install)
    Funny thing is, they use floform, but they are way cheaper than going directly to floform.
    ^^ Fact Checked
  1. where to buy laminate countertops..
    By 03ozwhip in forum Home and Garden
    Latest Threads: 11-18-2014, 11:32 AM
  2. Wood Countertops
    By LOLzilla in forum Home and Garden
    Latest Threads: 08-17-2014, 11:29 PM
  3. Where are the best deals for decent quality countertops?
    By tirebob in forum Home and Garden
    Latest Threads: 02-18-2010, 07:13 PM
  4. Sourcing Granite Countertops for Bathroom
    By Civ2NR in forum Home and Garden
    Latest Threads: 11-23-2009, 07:32 PM
  5. Drilled too many holes in new countertops
    By eina15 in forum Real Estate / Finance
    Latest Threads: 12-04-2007, 10:39 PM
