Audi A6 window regulator problem - Beyond.ca - Car Forums
Results 1 to 2 of 2
Thread: Audi A6 window regulator problem
    Jan 2005
    C/AB
    AP1 / CRV
    Default Audi A6 window regulator problem
    Helping a friend who has a 2008 Audi A6 Wagon and both front windows are 'crunchy' at certain spots when you roll the window up and down. We took the door apart and removed the regulator assembly the other day but couldn't really pinpoint the issue. It seems like this is fairly common, can anyone with audi experience point us to the likely culprit?
    The fact that the crunching seems to occur at roughly the same location when rolling up or down led me to believe that the gearing in the regulator motor might be the culprit but when running the motor assembly by itself it ran smoothly and without grinding. I tried to load the output shaft with my hand and still ran smooth without issue or noise.
    The cable assembly and plastic clips and sliders all appeared to be in order without damage or obstruction.
    We want to avoid throwing parts at the problem. If any audi techs / enthusiast can share their experience it would be greatly appreciated.
    Mar 2005
    Pushbroom
    I would be inclined to start with the simple and easy things first. Maybe throw some lubricant into the tracks and see if that frees it up a bit?
  1. WTB: 1996-2000 Civic Window Regulator
    By thw_goalie in forum Automotive Parts
    Latest Threads: 06-10-2006, 03:38 PM
  2. WTB: 92-95 civic power window regulator
    By djfob in forum Automotive Parts
    Latest Threads: 03-02-2006, 01:10 PM
  3. power window regulator??
    By autumnrain in forum Mechanical
    Latest Threads: 10-25-2005, 04:18 PM
  4. WTB: 92-95 civic window regulator
    Latest Threads: 03-08-2005, 04:34 PM
  5. Window Regulator:
    By Pete92SL in forum Mechanical
    Latest Threads: 07-26-2002, 02:11 AM
