yes he does. i take my stuff to him when possible
is there room inside the tube for an internal coupler that will hold the two bores concentric with room enough for the axle to slip thru or can the bore be relied upon for reference?
If the bore can be relied upon, even the OD of the tube, i think i can do that
from the hot rod article it looks like the bar alignment tool (and fancy fixture) with adapters on each end to hold the bearing races parallel, using heat to nudge the welded tube into position for final welding
if the tube goes back together with a coupler i'm thinking i can weld that without warping it. saying this never having done one or even having ever worked on a rear end. probably not the project to try it on
i am currently beta test machining/lapping subaru valve buckets down for new cam lash. thats more my thing, weird stuff, one offs, welding
