Asus n66u thread. - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Asus n66u thread.
    acura TYPE A
    Default Asus n66u thread.
    Since many people have this router. I thought i would ask
    which dd-wrt firmware do you guys recommend?
    last time I had dd-wrt 2.4/5ghz wi-fi was really crippled.. that was 2012-2015
    Thaco's Avatar
    Oct 2004
    Rage2
    i have the ac66u, running advanced tomato 3.4-138 just installed this FW, was running an old version of tomato on it for about a year, it was perfectly reliable, i only upgraded because my 14 year old needs time/access restrictions and that didnt work on the old FW but works fine now.
    User title molested by Rage2.
    ^^ Fact Checked
    Mar 2005
    Calgary/Alberta
    2022 X2M
    I use the most current 380.65.4 and haven't had a single issue. Asus Merlin FYI
    Used to use tomato but back when i tried it wasn't as simple as downloading and flashing so i moved away from it. Has that changed?
    E .· ` ' / ·. F
    Your tears fuel me
    Thaco's Avatar
    Oct 2004
    Rage2
    yeah its that easy now
    ^^ Fact Checked
    Mar 2005
    Calgary/Alberta
    2022 X2M
    I just checked it out and noticed It still requires the use of the firmware restoration utility. I like the ease of downloading and flashing like asus merlin gives, If i run into issues i will give it a try but for now my lazy ass will use the 2 minute method of merlin lol.
    We are a family of all MacBooks and I don't have a single laptop with a lan port.
    E .· ` ' / ·. F
    Your tears fuel me
    Thaco's Avatar
    Oct 2004
    Rage2
    been a long time since i did the original firmware but i am pretty sure i just uploaded it to the firmware upgrade page like any other upgrade.
    ^^ Fact Checked
    Not Aspen
    Two from Freemont
    So I am running 380.65_4 of Merlin.
    I noticed a slow down in my downloads where I am only seeing 140 down and 165 up. This is compared to my sig.
    When I connect to the TELUS router, I get my sig speeds. Monitoring the cpu, etc I don't see it overheating at all or being over taxed.
    Any ideas?
    I had QOS running at one point (don't remember turning it on) and when I switched it off, that gave me better stability and more speed.
    Mar 2005
    Calgary/Alberta
    2022 X2M
    Any ideas?
    Thought I would give this a shot since I'm running the same firmware as you.
    I was able to get 177 down and 16 up with shaw using my MacBook on my main floor with the router in the utility room a floor below me. I am not seeing a slow down so it could be telus to asus related.
    E .· ` ' / ·. F
    Your tears fuel me
  1. Replies: 87
  2. FS: ASUS RT-N66U Wireless N Router
    By imranm in forum Computer Hardware & Peripherals
    Latest Threads: 12-01-2014, 08:24 AM
  3. Asus RT-N66U double 450mbps N wireless router.
    By WRXer in forum Consumer Electronics
    Latest Threads: 07-14-2014, 11:52 AM
  4. FS: MINT 32gb Asus Eeepad Transformer w/Asus Case
    By topher91 in forum Consumer Electronics
    Latest Threads: 12-01-2011, 09:54 AM
  5. Replies: 77
    Latest Threads: 09-23-2004, 11:57 AM
