WTF is wrong with my PC - Page 2 - Beyond.ca - Car Forums
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 44
Thread: WTF is wrong with my PC
  1. #21
    Oct 2009
    Unknown
    Originally posted by Mitsu3000gt
    Yes, provided the used space on the existing HDD is less than the replacement SSD. You can even customize what gets transferred over if you need to reduce the size of the source drive, the software is pretty clever.
    Good to know.
    My old go to Acronis Migrate easy wouldn't clone to a smaller drive even if the source data was less than the size of the destination drive.
  2. #22
    Acronis True Image (free, WD edition) also supports dissimilar/lesser space, physical disk migrations based upon disk space use.
  3. #23
    Oct 2009
    Unknown
    Ok thanks.
    It's been a long time since I've had to clone a drive.
  4. #24
    Mar 2010
    Dewinton, AB
    Thanks for the suggestions so far will try some when I get home. With regards to that Samsung drive that's internal right? Do I just unplug my current he, put the new one in and then install W10 and then reconnect my other drive??
  5. #25
    Yes it's internal. It would replace your existing hard drive, or used along side of it provided your existing drive wasn't failing after all.
    You would first back up your existing hard drive just in case ( you should do that now regardless in case it's failing unless you don't have anything on it you care about).
    Then you would install that Samsung SSD alongside your existing hard drive, and run the Samsung Data Migration tool to automatically clone the drive. Then you simply change the boot order of the drives, or unplug the old one and plug the new one into where the old one was, and off you go. You could also start fresh, it's just more work. You should be using an SSD regardless though, they are absolutely dirt cheap and the difference it makes compared to a regular HDD Is night and day.
  6. #26
    Mar 2010
    Dewinton, AB
    Ok so this would still be running Vista then. I'm gonna hit up mem express otw home and grab that drive.
    I have one of those we terabyte drives that Costco sell so that would be my backup right??
  7. #27
    Mar 2010
    Dewinton, AB
    Does that Samsung data migration tool start up automatically?
  8. #28
    Bicycle
    Remember that Vista is too old to have trim support for SSD. So make sure you have some sort of trim tools or your SSD will degrade much faster under Vista.
    Windows 7 is the oldest Windows OS that supports Trim.
    EDIT: Looks like Vista SP2 brought in TRIM support as well.
  9. #29
    Mar 2010
    Dewinton, AB
    So I should update to at least w7 then?
  10. #30
    You have 7 days to return it too if it ends up not working out for you, but it should be good regardless. You will need a SATA cable and a free SATA power hookup on your power supply. Chances are you have an extra SATA cable in your motherboard box, or you can buy one from MemEx for $10 or Monoprice for $0.25.
    Yes you will still be running Vista if you clone the drive - it will literally be identical to your current setup.
    How much space are you using on your current 1TB HDD? If you try to clone to a 250GB drive with more than 250 GB, not everything can come over.
    Yes you can just use your other external hard drive for backup - copy anything you wish to keep onto it before you do anything.
    The software does not run automatically - you have to download it:
    http://www.samsung.com/semiconductor...oad/tools.html
    After installing the new SSD alongside your existing HDD, confirm that the computer recognizes the new drive and then the rest is straight forward using the software.
  11. #31
    Mar 2010
    Dewinton, AB
    Oh one more thing, if the drive is a Western Digital GREEN or BLUE series .....esp of that age .... discard it immediately and get an SSD like mentioned above.
    My HD is a Samsung HD103UJ (ATA)
    Oh one more thing, here is a simple (no ads) portable tool (does not install into Windows) that will tell you your drives mechanical/electrical status and whether or not its going out.
    Run the tool and post up the results here.
    https://osdn.net/frs/redir.php?m=pum...kInfo7_0_5.zip
    CrystalDiskInfo 7.0.5 (C) 2008-2016 hiyohiyo
    Crystal Dew World : http://crystalmark.info/
    OS : Windows Vista Home Premium SP2 [6.0 Build 6002] (x64)
    Date : 2017/05/03 16:10:00
    -- Controller Map ----------------------------------------------------------
    + Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20 [ATA]
    + IDE Channel (0)
    - SAMSUNG HD103UJ ATA Device
    + IDE Channel (1)
    - HL-DT-ST DVDRWBD GBC-H20N ATA Device
    + Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26 [ATA]
    - IDE Channel (0)
    + IDE Channel (1)
    - ASUS DRW-24B1LT ATA Device
    - Microsoft iSCSI Initiator [SCSI]
    -- Disk List ---------------------------------------------------------------
    (1) SAMSUNG HD103UJ : 1000.2 GB [0/0/0, pd1]
    (2) WDC WD10TMVW-11ZSMS5 : 1000.2 GB [6/X/X, sa1] (V=1058, P=0740) - wd
    (1) SAMSUNG HD103UJ
    Model : SAMSUNG HD103UJ
    Firmware : 1AA01113
    Serial Number : S1FXJ1KS302147
    Disk Size : 1000.2 GB (8.4/137.4/1000.2/1000.2)
    Buffer Size : 32767 KB
    Queue Depth : 32
    # of Sectors : 1953525168
    Rotation Rate : Unknown
    Interface : Serial ATA
    Major Version : ATA/ATAPI-7
    Minor Version : ATA8-ACS version 3b
    Transfer Mode : ---- | SATA/300
    Power On Hours : 68395 hours
    Power On Count : 435 count
    Temperature : 33 C (91 F)
    Health Status : Caution
    Features : S.M.A.R.T., APM, AAM, 48bit LBA, NCQ
    APM Level : 0000h [OFF]
    AAM Level : FE80h [ON]
    Drive Letter : C: D:
    -- S.M.A.R.T. --------------------------------------------------------------
    ID Cur Wor Thr RawValues(6) Attribute Name
    01 _99 __1 _51 0000000005C0 Read Error Rate
    03 _91 _91 _11 000000000E24 Spin-Up Time
    04 100 100 __0 0000000001DA Start/Stop Count
    05 100 100 _10 000000000000 Reallocated Sectors Count
    07 100 100 __0 000000000000 Seek Error Rate
    08 100 100 __0 000000002D4F Seek Time Performance
    09 _86 _86 __0 000000010B2B Power-On Hours
    0A 100 100 __0 000000000000 Spin Retry Count
    0B 100 100 __0 000000000000 Recalibration Retries
    0C 100 100 __0 0000000001B3 Power Cycle Count
    0D _99 __1 __0 000000000594 Soft Read Error Rate stab
    B7 100 100 __0 000000000000 Vendor Specific
    B8 100 100 _99 000000000000 End-to-End Error
    BB 100 100 __0 000000023094 Reported Uncorrectable Errors
    BC 100 100 __0 000000000000 Command Timeout
    BE _71 _64 __0 0000221D001D Airflow Temperature
    C2 _67 _64 __0 0000241D0021 Temperature
    C3 100 100 __0 0000019DB37C Hardware ECC recovered
    C4 100 100 __0 000000000000 Reallocation Event Count
    C5 _97 _97 __0 000000000074 Current Pending Sector Count
    C6 100 100 __0 000000000000 Uncorrectable Sector Count
    C7 100 100 __0 000000000000 UltraDMA CRC Error Count
    C8 100 100 __0 000000000000 Write Error Rate
    C9 _99 _98 __0 00000000003B Soft Read Error Rate
    -- IDENTIFY_DEVICE ---------------------------------------------------------
    0 1 2 3 4 5 6 7 8 9
    000: 0040 3FFF C837 0010 8856 022A 003F 0000 0000 0000
    010: 2020 2020 2020 5331 4658 4A31 4B53 3330 3231 3437
    020: 0003 FFFF 0004 3141 4130 3131 3133 5341 4D53 554E
    030: 4720 4844 3130 3355 4A20 2020 2020 2020 2020 2020
    040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
    050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110
    060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
    070: 0000 0000 0000 0000 0000 001F 1706 0000 004C 0040
    080: 00F8 0052 746B 7F69 4133 7469 BE41 4123 20FF 0057
    090: 0057 0000 FFFE 0000 FE80 0008 0005 005D 86A0 0001
    100: 6DB0 7470 0000 0000 0064 0000 0000 0000 5000 0F00
    110: 0B0F 100A 0000 0000 0000 0000 0000 0000 0000 401C
    120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000
    130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    200: 0000 0000 0000 0000 0000 0000 003F 0000 0000 0000
    210: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    220: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    230: 0000 0000 0000 0000 0001 0400 0000 0000 0000 0000
    240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    250: 0000 0000 0000 0000 0000 66A5
    -- SMART_READ_DATA ---------------------------------------------------------
    +0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
    000: 10 00 01 0F 00 63 01 C0 05 00 00 00 00 00 03 07
    010: 00 5B 5B 24 0E 00 00 00 00 00 04 32 00 64 64 DA
    020: 01 00 00 00 00 00 05 33 00 64 64 00 00 00 00 00
    030: 00 00 07 0E 00 64 64 00 00 00 00 00 00 00 08 24
    040: 00 64 64 4F 2D 00 00 00 00 00 09 32 00 56 56 2B
    050: 0B 01 00 00 00 00 0A 32 00 64 64 00 00 00 00 00
    060: 00 00 0B 12 00 64 64 00 00 00 00 00 00 00 0C 32
    070: 00 64 64 B3 01 00 00 00 00 00 0D 0E 00 63 01 94
    080: 05 00 00 00 00 00 B7 32 00 64 64 00 00 00 00 00
    090: 00 00 B8 33 00 64 64 00 00 00 00 00 00 00 BB 32
    0A0: 00 64 64 94 30 02 00 00 00 00 BC 32 00 64 64 00
    0B0: 00 00 00 00 00 00 BE 22 00 47 40 1D 00 1D 22 00
    0C0: 00 00 C2 22 00 43 40 21 00 1D 24 00 00 00 C3 1A
    0D0: 00 64 64 7C B3 9D 01 00 00 00 C4 32 00 64 64 00
    0E0: 00 00 00 00 00 00 C5 12 00 61 61 74 00 00 00 00
    0F0: 00 00 C6 30 00 64 64 00 00 00 00 00 00 00 C7 3E
    100: 00 64 64 00 00 00 00 00 00 00 C8 0A 00 64 64 00
    110: 00 00 00 00 00 00 C9 0A 00 63 62 3B 00 00 00 00
    120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    160: 00 00 00 00 00 00 00 00 00 00 00 00 EE 2D 00 7B
    170: 03 00 01 00 02 C5 15 C5 00 00 00 00 00 00 00 00
    180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 35
    -- SMART_READ_THRESHOLD ----------------------------------------------------
    000: 10 00 01 33 00 00 00 00 00 00 00 00 00 00 03 0B
    010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
    020: 00 00 00 00 00 00 05 0A 00 00 00 00 00 00 00 00
    030: 00 00 07 00 00 00 00 00 00 00 00 00 00 00 08 00
    040: 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00
    050: 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00
    060: 00 00 0B 00 00 00 00 00 00 00 00 00 00 00 0C 00
    070: 00 00 00 00 00 00 00 00 00 00 0D 00 00 00 00 00
    080: 00 00 00 00 00 00 B7 00 00 00 00 00 00 00 00 00
    090: 00 00 B8 63 00 00 00 00 00 00 00 00 00 00 BB 00
    0A0: 00 00 00 00 00 00 00 00 00 00 BC 00 00 00 00 00
    0B0: 00 00 00 00 00 00 BE 00 00 00 00 00 00 00 00 00
    0C0: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C3 00
    0D0: 00 00 00 00 00 00 00 00 00 00 C4 00 00 00 00 00
    0E0: 00 00 00 00 00 00 C5 00 00 00 00 00 00 00 00 00
    0F0: 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 C7 00
    100: 00 00 00 00 00 00 00 00 00 00 C8 00 00 00 00 00
    110: 00 00 00 00 00 00 C9 00 00 00 00 00 00 00 00 00
    160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 22
    Enclosure : WD My Passport 0740 USB Device (V=1058, P=0740, sa1) - wd
    Model : WDC WD10TMVW-11ZSMS5
    Firmware : 01.01A01
    Serial Number : WD-WXL1A71Y9381
    Disk Size : 1000.2 GB (8.4/137.4/1000.2/1000.1)
    Buffer Size : 8192 KB
    Queue Depth : 32
    Rotation Rate : 5200 RPM
    Interface : USB (Serial ATA)
    Major Version : ATA8-ACS
    Minor Version : ----
    Power On Hours : 484 hours
    Power On Count : 20 count
    Temperature : 30 C (86 F)
    Health Status : Good
    Features : S.M.A.R.T., APM, 48bit LBA, NCQ
    APM Level : 0080h [ON]
    AAM Level : ----
    Drive Letter : L:
    01 200 200 _51 000000000000 Read Error Rate
    03 147 141 _21 0000000015F0 Spin-Up Time
    04 100 100 __0 000000000040 Start/Stop Count
    05 200 200 140 000000000000 Reallocated Sectors Count
    07 200 200 __0 000000000000 Seek Error Rate
    09 100 100 __0 0000000001E4 Power-On Hours
    0A 100 253 __0 000000000000 Spin Retry Count
    0B 100 253 __0 000000000000 Recalibration Retries
    0C 100 100 __0 000000000014 Power Cycle Count
    C0 200 200 __0 00000000000C Power-off Retract Count
    C1 198 198 __0 000000001861 Load/Unload Cycle Count
    C2 120 114 __0 00000000001E Temperature
    C4 200 200 __0 000000000000 Reallocation Event Count
    C5 200 200 __0 000000000000 Current Pending Sector Count
    C6 100 253 __0 000000000000 Uncorrectable Sector Count
    C7 200 200 __0 000000000000 UltraDMA CRC Error Count
    C8 100 253 __0 000000000000 Write Error Rate
    0 1 2 3 4 5 6 7 8 9
    000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
    010: 2020 2020 2057 442D 5758 4C31 4137 3159 3933 3831
    020: 0000 4000 0032 3031 2E30 3141 3031 5744 4320 5744
    030: 3130 544D 5657 2D31 315A 534D 5335 2020 2020 2020
    050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0100
    060: FFFF 0FFF 0000 0107 0003 0078 0078 0078 0078 0000
    070: 0000 0000 0000 0000 0000 001F 1F06 0000 004C 0040
    080: 01FE 0000 746B 7D09 6123 7469 BC09 6123 007F 007C
    090: 007C 0080 FFFE 0000 0000 0000 0000 0000 0000 0000
    100: 6DB0 7470 0000 0000 0000 0000 6003 0000 5001 4EE1
    110: 59B4 B867 0000 0000 0000 0000 0000 0000 0000 4018
    120: 4018 0000 0000 0000 0000 0000 0000 0000 0021 0000
    130: 0000 0000 0000 16FE 0134 0000 0000 0000 0000 0000
    140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
    200: 0000 0000 0000 0000 0000 0000 7035 0000 0000 4000
    210: 0000 0000 0000 0000 0000 0000 0000 1450 0000 0000
    220: 0000 0000 101E 0000 0000 0000 0000 0000 0000 0000
    230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000
    250: 0000 0000 0000 0000 0000 B0A5
    000: 10 00 01 2F 00 C8 C8 00 00 00 00 00 00 00 03 27
    010: 00 93 8D F0 15 00 00 00 00 00 04 32 00 64 64 40
    020: 00 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
    030: 00 00 07 2E 00 C8 C8 00 00 00 00 00 00 00 09 32
    040: 00 64 64 E4 01 00 00 00 00 00 0A 32 00 64 FD 00
    050: 00 00 00 00 00 00 0B 32 00 64 FD 00 00 00 00 00
    060: 00 00 0C 32 00 64 64 14 00 00 00 00 00 00 C0 32
    070: 00 C8 C8 0C 00 00 00 00 00 00 C1 32 00 C6 C6 61
    080: 18 00 00 00 00 00 C2 22 00 78 72 1E 00 00 00 00
    090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32
    0A0: 00 C8 C8 00 00 00 00 00 00 00 C6 30 00 64 FD 00
    0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00
    0C0: 00 00 C8 08 00 64 FD 00 00 00 00 00 00 00 00 00
    0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    160: 00 00 00 00 00 00 00 00 00 00 00 00 28 5F 01 7B
    170: 03 00 01 00 02 ED 05 00 00 00 00 00 00 00 00 00
    180: 00 00 01 06 00 00 00 00 00 00 00 00 00 00 00 00
    1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47
    000: 10 00 01 33 C8 C8 C8 C8 C8 C8 00 00 00 00 03 15
    020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
    030: 00 00 07 00 C8 C8 C8 C8 C8 C8 00 00 00 00 09 00
    040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
    050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
    060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00
    070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
    080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
    090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
    0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
    0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
    0C0: 00 00 C8 00 00 00 00 00 00 00 00 00 00 00 00 00
    1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5D
    Hope that means something to you LOL!
  12. #32
    Mar 2010
    Dewinton, AB
    Originally posted by Seth1968
    This is most likely the issue.
    If necessary, back up your data, then run hard drive diagnostics:
    http://support.wdc.com/downloads.aspx?p=3
    Im doing this right now. It says estimated time is 2 mins and I am currently at 19:26.
    So awesome.
  13. #33
    Mar 2010
    Dewinton, AB
    Ok got the following error:
    Quick Test on Drive 1 did not complete!
    Status Code = 07 (failed read test element) Failure checkpoint = 0
    (unknown test)
    SMART Self-Test did not complete on Drive 1!
  14. #34
    Yea that drive is (slowly) dying. With 70,000 hours though, its had a good life!!
  15. #35
    Mar 2010
    Dewinton, AB
    So could that explain my issue? I bought that 250GB SSD. Looking at my backup tho it says:
    System 624.4 GB
    Docs 128MB
    Mail 765 MB
    Movies 23 GB
    Music 12.6 GB
    Other 8.5 GB
    Pictures 18.1 GB
    229 GB Free
    So how do I use this 250 GB drive??
  16. #36
    Go to My Computer and see how much of the C drive is being used right now.
    The backup drive might contain multiple copies of the system and should not be used as a guide.
  17. #37
    Mar 2010
    Dewinton, AB
    c: it says used is 687 GB and free is 228.
    It has a partition Recovery D:
    Used 7.69 GB
    Free 7.60 GB
  18. #38
    Yea you have something taking up a crap ton of space on the C drive.
    A simple Vista install is about 20GB is memory serves.
    You'll have to purge what you dont need prior to migrating.
    If youre into torrenting movies, etc. then keep the 1TB drive for that purpose.
  19. #39
    Mar 2010
    Dewinton, AB
    Ok I'll do some sleuthing
  20. #40
    Mar 2010
    Dewinton, AB
    Any suggestions on how to find this pile pf crap. I am going folder to folder but havent found much. I did find a file "Windows" which has 19.4 GB. Would that be Vista?
    Also on my profile I get access denied to a lot of folders including Myvideos, Mymusic etc, even though I am an administrator.....what gives there?
  1. Another chill guy in wrong place at wrong time.
    By OU812 in forum Society / Law / Current Events / Politics
    Latest Threads: 08-14-2016, 08:57 PM
  2. wrong time ,wrong place
    By hemaworstje in forum Misc. Gallery
    Latest Threads: 02-19-2005, 11:17 PM
  3. WTF is wrong with my Car??
    By James in forum Mechanical
    Latest Threads: 01-10-2003, 05:22 AM
  4. WTF is Wrong??
    Latest Threads: 09-20-2002, 07:12 PM
  5. WTF is wrong with Some People!
    By James in forum General
    Latest Threads: 09-13-2002, 12:10 AM
