2x6 vs 2x4 exterior walls - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: 2x6 vs 2x4 exterior walls
    Nov 2003
    Calgary / AB
    '08 Ford Lariat
    Default 2x6 vs 2x4 exterior walls
    Anyone know what year 2x6 ext walls became standard in Alberta?
    My Karma ran over your Dogma
    Nov 2004
    14frs,06Tacoma,69Olds Vista Cruiser, 73VWwestfalia
    I don't think there every was a transition time that made them standard. However, taking a guess at why you're asking, I'll just give a bit of info.
    2X4 exterior Walls are actually acceptable exterior framing, it's just that you need r20, which you can't get with just fiberglass insulation in a 2x4 cavity.
    So if you see such framing and are wondering how it passed, they probably also used blue insulation on the outside, or something else to achieve r20.
    Feb 2006
    07 E550, 00 V6 Focus, 09 Wrangler X
    I think a better question is 16" OC vs 24" OC exterior framing.
    Better to have 2x6 for insulation purposes but I would think that closer spacing is more stable than wider spacing.
    Points to ponder:
    When you are dead, you do not know you are dead.
    It's only painful for others.
    Same applies to stupid.
    Nov 2003
    Calgary / AB
    '08 Ford Lariat
    Thanks for the replies. Was kinda thinking, long ago the standard wall was 2x4s. Now the typical exterior wall is 2x6s. When did this change happen, or when did the majority of homes start being 2x6 walls?
    Based on the reply above its linked to insulation, and when the building code changed to require more R value in walls. When did this change happen?
    As it related to looking for a home to purchase, is there a certain vintage home that would be likely to be 2x4 vs 2x6?
    Thanks again.
    Jul 2013
    Calgary / Alberta
    I had a home built in 07 with 2x6 walls, styrofoam and osb, with 24centres. To keep the walls rigid, they added steel bands from each corner of the walls like a big X. Jayman called it their 'quantum wall system' and had them pre-built off site. It worked really well for keeping the home well insulated.
    A simple way to tell is by measuring wall thickness at exterior doors. I wish I could tell you when the changed from 2x4s to 2x6s, but I can't. My guess is it was in the early 80s as thats when homes are assumed to be 'tight construction'.
    Aug 2005
    Calgary Alberta
    I would guess closer to 2000. My early 90's house in douglasdale was 2x4 construction.
    Oct 2002
    B7 A4, ZX-6R
    I'm also curious when this started becoming the norm. My 1999 build is 2x6 exterior construction. I don't know if it's the main factor but I do find it quieter inside then the last house I lived in that had 2x4 walls.
  1. For free: bag of 2x6 stud insulation
    By cidley69 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 03-04-2016, 06:25 AM
  2. LF: Scrap wood 2x6 or 2x12
    By iron_man888 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 06-12-2014, 07:22 PM
  3. free wood (2x4, 2x6, osb)
    By gimp in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 03-31-2012, 03:27 PM
  4. 2x4 - how much weight can they handle?
    By black_2.5RS in forum Home and Garden
    Latest Threads: 06-14-2009, 10:13 AM
  5. LF: 2x4 wood
    By HiSpec in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 04-03-2008, 09:01 AM
