steps to wash a black vehicle - Beyond.ca - Car Forums
Results 1 to 20 of 27
Thread: steps to wash a black vehicle
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    Default steps to wash a black vehicle
    ok, so this truck is really the first black vehicle I have ever owned. I heard black was hard to keep clean, and I believe it.
    I have been doing wand washes, and for whatever reason, I just can't get the truck clean...
    I don't really bother with a pre-soak, I just do 2 laps of the truck with high-pressure soap. The first pass is just a quickish one to get the truck wet and a layer of soap to loosen up everything, with the second pass being a more through and slow job.
    I then use the high-pressure rinse and go around slow the first time, and then much quicker the second.
    Then comes the wax, I just do a fairly quick pass with that, followed by the spot free rinse.
    Now, I am not sure what is going on, but, I don't wipe it down, but instead, drive it about 2kms home to air dry. By the time I get home, I have this "film" or whatever on the sides of the truck, basically, everywhere the truck was most dirty, like the bottom half of the panels, especially right behind the wheels.
    I don't know if it residue from the soap or wax, but I think if it were, it would be everywhere on the truck, not just in the before mentioned places. Having said this, I seem to have much more success with the automatic washes as I have not noticed the same kind of residue left behind...So I figure I must be doing something wrong.
    On my previous vehicles, I haven't had this issue, or at least, not that I have noticed. Maybe it is just more noticeable because the truck is black.
    is there a better way to do this?
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
    FB6
    I use A LOT of pre soak and it seems to work well. At the wand wash for my car, I would probably spend 5 mins on presoak making sure its on every panel and then double or triple back on the really dirty areas. Then 2 mins on high pressure soap. Then 2 mins on rinse. Then a quick walk around ~1 min of high pressure wax then spot free rinse for about 1-2 mins. I usually pay by credit card and this usually comes to about $8-9 for a small car.
    The film is probably a layer of dirt and grime that didn't get washed off.
    Only 15min from Aspen!
    Nothing interesting anymore
    The film is dust, you can't air dry black in this city. It's too dirty.
    You have to hand wash it with microfiber, hand dry it with microfiber, and then apply a good coat of legitimate wax, or even better, paint sealant. And do it at least twice a year. That carwash "wax" is terrible by the way, don't ever use it.
    Sep 2007
    You need to use a wash media as pressure from water alone won't remove all the dirt and grime. Something like a wool or microfiber wash mitt, pad or sponge or Boar's hair brush. Use a bucket with a grit guard and a Rinseless wash solution. I usually just go to a wand wash and do a quick wash to get rid of most of the dirt and then finish off with spray of Waterless wash for additional cleaning and protection or if I want to be more through, I would use the Bucket method. It's much easier for dirt to show on a black vehicle.
    Jun 2003
    KTM
    Are you going to "Top Gear" car wash? I know I have several friends that cant seem to get their black vehicles clean there.
    (though it is a good wash)
    Mar 2009
    '18 Murano
    The film is probably crappy recycled rinse water. I get the same thing at the few local car washes I go to. on the way out, hit the wipers. the area of the windshield not covered by the wipers looks like crap.
    Oct 2006
    '21 F150 PowerBoost
    Yeah. Pretty much exclusively.
    Turbos cost money
    Jun 2003
    KTM
    Haha, figured. Try a different wash and see if if you get the same result.
    Chevy Colorado ZR2
    http://www.detailedimage.com/Auto-De...ying/#overview
    Good article and road film and contamination can only be moved by properly washing the car.
    Also, car wash bays does not have the best soap and water which could cause additional damage to your paintwork and rubber seals over time.
    Jan 2007
    Calgary Alberta
    2012 F150, R6
    THIS... You need some seriously high pressure to get that film off, and with pressure that high you are probably doing other damage to your paint. Unfortunately you have to put in a little elbow work and wipe it down with a wash mitt or microfiber towel. But you need to constantly rinse that mitt. I usually wash the whole truck with high pressure soap, then rinse it off, then use the wash mitt, then rinse the vehicle again. after that you should be good and can dry it off with a towel.
    You'd be surprised how "dirty" your vehicle is after coming out of the car wash if you arent physically removing the dirt/film and just spraying it.
    "Speed has never killed anyone, suddenly becoming stationary… That’s what gets you."
    MooooooO
    AWD grandpa wagon
    Another extra step you can take to reduce the chance of marring the paint is to use drying-aid while drying.
    Sep 2008
    Turbo stuff
    Step 1: Lie down
    Step 2: Try not to cry
    Step 3: Cry a lot
    Jan 2014
    GLK, G37X & S5
    Default Re: steps to wash a black vehicle
    One problem I'm seeing here is not wiping dry. Remember Calgary is very dusty and if your vehicle is wet it attracts more dust and because the vehicle is black..it becomes more noticeable, making it look like your vehicle is not clean.
    Wiping dry is needed for black vehicles even if you car had been nano coated. Coated vehicles will make it a bit "cleaner" but not 100%.
    Another option you can look at is once you arrived home, use Quick Detailer to help clean it up.
    Jan 2014
    GLK, G37X & S5
    Als, depending on how often you wash your truck and how dirty you let it get before washing. Its almost impossible to have it 100% clean at a touch-less.
    Lower panels always attracts the most contamination/dirt/film build-ups.
    When you drive your wet car around, dust gets into the "spotless rinse" water and when the water dries on your vehicle, deposits the dust/dirt. If that's your main complaint, just give it a good dry with a waffle microfiber or something right when you're done at the car wash.
    Also if you only ever pressure wash it, you probably won't always get everything off - you're going to have to use a physical method at some point.
    I'm also guessing the spray-on wax does almost nothing, you could probably save your money there. If it's anything like the the coin wash I go to, everything is so crappy that I can't imagine anything decent is coming out of that nozzle haha.
    If you have the option, I would also look at soap less washes here in Calgary, at your house.
    As long as its just water going down the drain the city doesn't really care.
    I haven't used a wash bay in years - in the winter I just hose off the worst in my attached garage.
    FA20
    This happens to me as well (I also go to Top Gear). I don't bother drying it afterwards because I know it's still dirty and drying it will just rub the dirt around and create swirls in the paint. I just go home after the car wash and use the two bucket method with Optimum No Rinse. Gives pretty good results. Bought a clay mitt kit and sealant kit as well from Amazon on sale so I will be able to detail it as well hopefully.
    Aug 2009
    V8s
    I've been driving black cars for about 5 years now. Every time I swear I'm not going to buy another one, and the right deal comes up on a black one
    As mentioned a few times, contact and drying are the keys. I don't have the time or patience to hand wash every time, so I only do this a couple times per year, but it's definitely critical to get all the shit off your car.
    Drying, I find to give the biggest payoff. Obviously wand wash/hand dry is not the best method, but it's the most bang for your buck (in my experience). As mentioned, this city is super dusty, so as soon as you depart the car wash you need to dry your car, otherwise it's just a dust magnet and you'll have spots/residue everywhere, even if you drive home on side streets.
    And like Sentry said. Just cry. Your truck will never be clean. Even when it's clean, it's still not clean. The only time you'll really be happy is when you look at it in the rain, after dark.
    Jan 2014
    GLK, G37X & S5
    Having your car nano coated or with any good nano sealant will definitely help make them easier to clean at wand wash. But again, it all depends on how often vehicles are washed.
  1. Replies: 2
    Latest Threads: 02-29-2016, 07:05 PM
  2. How not to wash a vehicle
    By xLostx in forum Misc. Gallery
    Latest Threads: 02-23-2009, 09:57 PM
  3. Hand Wash Car Wash in SW
    By robpark in forum General
    Latest Threads: 10-04-2005, 07:01 PM
  4. anyone know who would carry side steps for my truck
    By JordanLotoski in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 02-20-2004, 11:09 PM
  5. How do i stall 2 amps... baby steps please!!
    By peanut in forum In Car Entertainment / Electronics
    Latest Threads: 02-14-2004, 03:29 AM
