FS: 2003 Honda Civic SiR with RSX Type S running gear
****SOLD****
Vehicle Details
Year : 2003
Make and Model : Honda Civic SiR (EP3)
Exterior Color : Tafetta White
Interior Color : Black
Auto or Manual? : Manual (5spd)
Odometer Reading : 160XXX, approximately 95k on K20Z1
Location of Vehicle : Calgary
Description :
The time has come to sell my Tafetta White EP3. The car is loaded with lots of high quality aftermarket and OEM parts as you will see on the list below. Highlights include a fresh '05 RSX Type S K20Z1 motor with approximately 95k on it (new water pump, timing chain, etc) paired with a Hondata ECU (on the EP3 5spd) and a RSX Type S 5 bolt/big brake conversion. All major work done by Garage Box (I have all the receipts). Engine swap done less than 5000km's ago as of this writing. With the Hondata, the engine revs to 8500rpm (off the tachometer), and VTEC engages at 4400rpm.
The car does have rust on the driver side quarter panel (pictured), some bubbling has started on the edge of the hood, and there is a crack in the windshield that is large but thankfully not in your sight lines, driver side headlight has a hole in the seal somewhere (but I am throwing in blacked out Depo headlights). Selling the car as is.
Exterior
OEM Honda Factory Performance Kit (complete)
OEM Type R front and rear Honda H badges
OEM gunmetal SiR trunk badge
Sylvania Night Breakers
ICB Motorsport Vision blue mirrors (wide view, reduces glare)(heated mirrors still work, but very slowly)
LED licence plate bulbs
OEM RSX Type S 5 bolt conversion (with 5 bolt spare tire)
Work Emotion CR Kai rims (bronze) on Toyo DRB, 17x7, +43, 225/45/17 (tires will soon need replacing)
Muteki SR35 lug nuts (dark blue)
Depo black oem style headlights (not installed)
Interior
LED interior + trunk lights
AVT Racing aluminum pedals and dead rest
Acura RSX steering wheel and airbag
Repainted door handle covers and center console
Metra dash kit
Sony DSX-210 deck with full iPod integration (comes with connection for older iPod only (connection can be changed))
K Tuned aluminum shifter bushings
Shifter out of another generation Civic
Engine/drivetrain
’05 RSX Type S K20Z1 motor with 95k on it (EP3 5 speed transmission is still being used)
Injen short ram intake
Hondata
Energy Suspension motor + transmission mount inserts (red)
New OEM exhaust hangers
Exeddy clutch (installed at engine swap)
Exeddy lightweight flywheel (installed at engine swap)
Fumoto oil drain valve
Brakes
OEM RSX Type S 5 lug/big brake conversion
- Stoptech street pads (rear passenger side Akebono pads)
- Stoptech drilled rotors
- Stoptech braided lines
- Timken rear knuckles
- OEM RSX Type S front axles with new OEM boots
Refurbished Powerstop rear calipers
Maintenance
Engine oil changed every 5k with Motul Synthetic 5W40, transmission oil changed every 15k with Honda MTF
Undercoat touched up every season
New rear crankshaft seal (installed at engine swap)
New intake manifold gasket (installed at engine swap)
New water pump at engine swap (installed at engine swap)
New timing chain with tensioner (installed at engine swap)
New spark plugs (installed at engine swap)
AC refresh done at engine swap
Optional Extras : Civic Si FG2 rims on winters
Asking Price : *****SOLD*****
Pictures :
Kijiji link for more pics: http://www.kijiji.ca/v-cars-trucks/c...rce=ios_social
Thanks for looking!
