Mine is sure getting workout this year. Wonder if it'll crap out before the cooling season is over?
You have bad luck, I will send over some good juju vibes.
Just something to consider, if install is done in the winter you'll have to have a second service appointment once it warms up for them to actually come and pressurize it (or whatever it is that they do). They couldn't even do mine when it was like 15* out, they had to come back on a warmer day.
If you're going to get one anyway, why wait until Winter? There's still at least 2 more months left of A/C weather, might as well get it ASAP if you have made the decision.
Availability only seems to be a problem if you're set on using one of the big chain installers or a very specific unit.
I’ve been walking around in a thong to keep cool. I hear it’s trendy now.
Same thing happened to me with W&J, went with 3 ton XR13 for $3800.
Actually I took the hint from your June 29th post about W&J and Airtech, and went for it.
Called early july for quote and booked the install date at the same time.
Installed yesterday and things went well, 9am to 2:30pm, one guy working in a sweltering house.
W&J does a milk run and drops off the equipment & materials in the morning, the tech shows up does the work and collects payment info. Boxes and trash should be picked up today.
The decibel issue is a bit over blown.
I don't hear it at all on my deck around the corner, neighbour and I don't have windows on the AC unit side either.
Other than my fan motor going, I get a very faint whistling at the air filter box that doesn't happen in the winter. Just needs to be fiddled with.
iirc, apri & costco (also apri), was $4500, and sept booking but fully can't remember now.
Thanks for the info guys. Interesting that prices haven’t moved at all since I got AC at the old house years ago.
Glad I could help! W&J is doing my house right now. One guy, said he would take between 4-5 hours. I did the math between the XR14 and XR13 and it wasn't much. W&J still ended up being the cheapest.This quote is hidden because you are ignoring this member. Show Quote
Neighbor just paid 5k for a 16 seer unit and his install was yesterday. Didn't think it was worth the premium for something we use maybe 4 months a year
I tired searching to see if this has been asked already and didn't come across anything. Has anyone had a TX Valve (TXV) installed on their A/C system? If yes, do you recommend it or feel it's not needed?
Supposedly it's a valve that controls how much refrigerant is being pushed through from the condenser into the coil. If you're running the A/C for longer periods it ensures the coils don't freeze and become an icebox within the furnace.This quote is hidden because you are ignoring this member. Show Quote
I would think if you're keeping the thermostat set around 21-23, shouldn't lead to ice build up.
Sounds like the kind of thing a well designed system shouldn't need. Also decreases efficiency I'm certain.
Yup, if your ac was sized correctly from the get go it shouldn’t freeze up.
Your system uses a TxV if its designed for one, or a fixed orifice if that’s the design. Retrofitting in a thermal expansion valve paired to an outdoor unit that is not designed to provide subcooling, will likely cause more issues than correcting the original setup.This quote is hidden because you are ignoring this member. Show Quote
In regards to freeze up issues. Older furnaces and duct sizing in this area generally do not allow sufficient CFM for proper cooling. (never mind the registers and return airs in the completely wrong locations). Add in low humidity here is the Summer months and it is a common bandaid to have a larger capacity evap coil than the capacity of the outdoor unit. ie My place I installed a 2.5 ton indoor coil with 2.0 ton orifice and 2.0 ton outdoor unit. Without the mismatch, the indoor coil would run a lower pressure and too low a superheat, probably causing an occasional freeze ups. Tx valves are used to handle variable output setups, not needed if a/c just runs flat out.
2 ton orifice? I see you know my ex-wife.
I am tired from a restless 40 week pregnant wife, but I spit out my coffee,This quote is hidden because you are ignoring this member. Show Quote
"Speed has never killed anyone, suddenly becoming stationary… That’s what gets you."
That would be a 2 tonne orifice, good sir.This quote is hidden because you are ignoring this member. Show Quote
Thanks for the detailed breakdown. I'm actually in the process of getting pricing on replacing my furnace with a high efficiency model (either 2 stage variable speed fan or modulating variable speed fan) and an A/C unit. What I've been suggested are as follows:This quote is hidden because you are ignoring this member. Show Quote
- Modulating Furnace 80,000 BTU 3 Ton Blower with a 13 Seer Air Conditioner 2 Ton (Single Speed Condenser Fan Motor) or
- 2 Stage DC Drive Furnace 80,000 BTU 3 Ton Blower with a 13 Seer Air Conditioner 2 Ton (Single Speed Condenser Fan Motor)
The TxV is $150.
Yes, use a Txv in this case.This quote is hidden because you are ignoring this member. Show Quote
