Air Conditioning! - Page 34 - Beyond.ca - Car Forums
Page 34 of 43 FirstFirst ... 24 33 34 35 ... LastLast
Results 661 to 680 of 855
Thread: Air Conditioning!
  1. #661
    Feb 2020
    Edmonton
    There is likely some device directly on the unit that prevents lower temp operation. I seem to remember having dealt with that before on our unit.
    If I had known you guys would end up being such bitches, I would’ve opened the parenting forum.
  2. #662
    Jun 2005
    51N, 114W
    has 3rd party insurance
    gavin came by to investigate, it was the low temp switch on the unit, very sensitive as the ac is in the shade and side of the house with the wind. ecobee will be the low limiter now based on weather temperature rather than the switch.
  3. #663
    V8s
    Our unit is always shaded as well, almost never will run at ambient temp of 16*C. Tbh I didn't realize there was an option to change the LL temp source, I might look into that.
  4. #664
    Cochrane, AB
    Trucks
    He likely just bypassed the mechanical switch outside by moving one control wire.
  5. #665
    V8s
    How much risk is there in doing this? If the AC is running when ambient is below the LL (according to the outside unit temp), isn't that like... not great? The LL is set for a reason, no? Or is it just super conservative..
  6. #666
    Cochrane, AB
    Trucks
    If you tried to start the outdoor unit in winter, most of the refrigerant would be sitting in the compressor in liquid form. Compressors don’t like slugging liquid (can’t compress) or it simply washes the oil from the lower crankshaft bearing. Just turn the 240v breaker off from Oct to June each year. Some power hungry resi units have a crankcase heater to extend the season.
  7. #667
    Jun 2005
    51N, 114W
    yup as above, it’s up to me to be careful now, he removed/bypassed the temp switch, the ecobee has a setting in it for backup now, and the breaker will be off during winter. this could be solved with the low ambient kit but not really needed, more for commercial applications
  8. #668
    Aug 2012
    CGY
    Quote Originally Posted by tha_bandit View Post
    why do you want your outdoor unit to even run in those low outdoor temps?
  9. #669
    Apr 2007
    Can anyone recommend some good portable AC units?
  10. #670
    Jun 2005
    51N, 114W
    Quote Originally Posted by EK69 View Post
    it didn’t run at 16 degrees yesterday evening, inside was 23.5 without opening the windows or whatever, i just simply want it to run, the switch is 12.8 degrees, so it’s too high in my opinion.
  11. #671
    Cochrane, AB
    Trucks
    12°c is the supply air temp from your a/c. It’s not a magically number, it means open your windows instead of killing baby seals, at that temperature outside.
  12. #672
    Jun 2005
    51N, 114W
    lol i get it, dusty environment due to new construction in the area, sometimes i just need to it run for an hour or two for optimal sleeping temperature
  13. #673
    Open windows? What kind of poverty is this
  14. #674
    True. If I wanted fresh air I'd go boating in a new Wakesetter.
  15. #675
    What do you all set the AC to at night?
  16. #676
    12c
  17. #677
    12c
    You must spread some Reputation around before giving it to ExtraSlow again
  18. #678
    I dunno my HVAC guy sets it all for me
  19. #679
    Cochrane, AB
    Trucks
    Meat spoils quickly above 4°C and I’m made of meat, so keep the house at 3. Live forever.
  20. #680
    Jun 2005
    51N, 114W
    Quote Originally Posted by vengie View Post
    21 or 22, or 12c as above with windows open
  1. air conditioning after D16 to B16 swap
    By super-wang in forum Performance Modifications
    Latest Threads: 01-25-2006, 09:24 PM
  2. Air Conditioning - whose reputable to service?
    By yohan4ws in forum Mechanical
    Latest Threads: 07-16-2004, 01:37 PM
  3. 2000 integra air conditioning parts
    By 98type_r in forum Automotive Parts
    Latest Threads: 03-25-2004, 10:02 PM
  4. WTB: Air Conditioning parts for '99 Civic
    By Horatio in forum Automotive Parts
    Latest Threads: 07-09-2003, 12:08 PM
