Air Conditioning! - Page 41 - Beyond.ca - Car Forums
Page 41 of 43 FirstFirst ... 31 40 41 42 ... LastLast
Results 801 to 820 of 855
Thread: Air Conditioning!
  1. #801
    The difference between 750 and 1000 is significant, non?
  2. #802
    I see low summer usage in July, high winter usage in Feb.
    I think if you cared enough to average the high heat and high AC periods you wouldn’t see much difference?
    I guess my main point was if you expect your electricity bill to triple in the summer versus the winter I don’t think you will see that much effect.
    Combine that with usage being a tiny amount of your bill and I’d say the electricity usage is small enough that it isn’t a major consideration.
  3. #803
    This right hurr.
  4. #804
    Name:  Enmax Electricity useage.PNG
    Yeah, I use the most in summer because of AC, but it's not a crazy increase. Goes from around 800 to around 950 for the hottest months.
    My lowest months are the shoulder season, which tracks.
  5. #805
    How easy is it to install a mini split system?
  6. #806
    Cochrane, AB
    Trucks
    Very easy. Toughest job, I find, is locating a suitable water drain or installing a noisy and unreliable water pump.
  7. #807
    Is the drain on the inside or outside part?
  8. #808
    Cochrane, AB
    Trucks
    Inside, hence the problem.
  9. #809
    Ah. Dislike.
  10. #810
    Cochrane, AB
    Trucks
    Ah. Dislike.
    If the indoor unit is on an exterior wall, you can just leave the drain tube dripping into a outside flower pot or spilling onto a patio. They don't produce much water in Calgary, maybe a litre of 2 per day on a hot & sticky day. (not art room sticky)
  11. #811
    06 S2000
    Can anyone recommend a good company to service A/C? Mine was installed by reliance, but I don't want to give them a shout, and it looks like the drain isn't working, and I can't seem to get eyes on it properly. Woke up the other morning, and the entire furnace was covered in condensate, but the fan wasn't spinning. Had to turn it off, let it defrost, and then get the fan running.
    My car sounds like shit.
  12. #812
    6.7 CUMMINS, E50 AMG
    I have a super honest guy, he does it on his weekends, Call Corey 403-921-0226
  13. #813
    Mar 2010
    Ioniq 5
    It’s very easy, one power cable from your panel to the outdoor unit. Then the lineset (2 copper pipes + 1 electrical cable) from the outdoor unit to the indoor unit (we went up and through the attic). Then just a drain line from the indoor unit to somewhere, in my case it’s on an exterior wall so I just ran it outside and then it drains into my flower bed.
    Only special tool you need to borrow / rent is a vacuum pump for when it’s all connected to pull a vacuum on the refrigerant line and check for leaks.
    All in all it was maybe 2-3 hours of work for me and my dad to do.
    Yeah I ran mine into a collector for a while for curiosity and it was closer to 1-2 L a week; though depends if you have a humidifier going with your furnace as then it’ll knock a bit more out
  14. #814
    Sep 2005
    Your charts got me curious, so I checked mine. I guess I really like my A/C.
    Name:  Screenshot 2023-05-22 185708.jpg
  15. #815
    Calgary, AB.
    210000 km oldie
    We got a quote 3 years ago. My wife said we don't need it. I contacted someone today and will see. Prices are what, 30% more than 2020? Anyone got one done recently? What was the wait time to get the job started and how long did it take to do the installation?
  16. #816
    Not Aspen
    Two from Freemont
    I find my summer electricity bills are comparable to my winter electricity bills.
    Attachment 113124
    Basically the AC offsets winter lighting usage. I don’t really see a definitive or material pattern in my electricity bill, and I have 2 AC units and 2 furnaces as well as hydronic heat.
    Same. Winter is the furnace fan and hydronic pumps going all the time. Summer is AC. Shoulder season is where it drops.
  17. #817
    Jul 2007
    Blue boy
    Quote Originally Posted by bigbadboss101 View Post
    ~3500 to 5k ish. Getting quotes ~9k to do furnace and ac fml
  18. #818
    Only 15min from Aspen!
    Nothing interesting anymore
    Quote Originally Posted by G-ZUS View Post
    Lucky, all my quotes were over $10k+
    Getting both done this week. 2 ton AC and 70k btu furnace.
  19. #819
    Jul 2007
    Blue boy
    How big is your house? Who did you end up going with?
  20. #820
    Feb 2006
    CEF4
    Ralli Machine
    Yeah we got ours for $3600 probably 7 years ago. Neighbor got a quote for 8k or something a few weeks back.
    Cos...
  1. air conditioning after D16 to B16 swap
    By super-wang in forum Performance Modifications
    Latest Threads: 01-25-2006, 09:24 PM
  2. Air Conditioning - whose reputable to service?
    By yohan4ws in forum Mechanical
    Latest Threads: 07-16-2004, 01:37 PM
  3. 2000 integra air conditioning parts
    By 98type_r in forum Automotive Parts
    Latest Threads: 03-25-2004, 10:02 PM
  4. WTB: Air Conditioning parts for '99 Civic
    By Horatio in forum Automotive Parts
    Latest Threads: 07-09-2003, 12:08 PM
