How much have you guys paid to change out your standard garage o/h door opener to a Liftmaster elite 8500 (or something similar) and to revise the track to be high lift up to the ceiling?
I recently had this done through the builder. Cost was $1350 for the package.
Found some companies on kijiji, prices varied from $1200-1300.
Hope that helps
$429 for the garage door unit.
$45 for the wireless entry pad.
$200 to install it.
have had three installed.
http://shop.overheaddoorparts.ca/
Did you also have the tracks revised to be a high lift door?
\This quote is hidden because you are ignoring this member. Show Quote
no sorry, can't comment on that. Only partially helpful here.
Seems like reasonable pricing. Our builder is doing the upgrade to the liftmaster 8500 for $450 and upgrade to the highlift tracks for $400 (which seems stupid as its less material, but whatever).
Tagging along...
I'm amazed - current prices are what I was charging when our dollar was at par and springs weren't running stupid $.
The cost is largely in the springs - one beyonder had 600$ worth of springs on their door alone (was 2 @ 6' duplex (so 4 springs, one set inside the other) my back clearly remembers that door to this day)
But there was a couple doors where I could do 2' of high lift on 5" drums with a 'stock' spring - so those could be done significantly cheaper.
Sorry
Just re-checked my change order. I paid $1050 for the Liftmaster 8500 and high lift tracks. Not sure why I thought it was $1350.
Well those prices are extras. Base spec includes a regular o/h door track and standard opener. So that should be taken into account.This quote is hidden because you are ignoring this member. Show Quote
Morrison charged $196 to upgrade to the Liftmaster 8500. I think the standard was the Liftmast 8355. This did not include adding an extra outlet at $56 for the side mount as the overhead outlet remained for the remote light. Didn't get a price for the high lift track though.
