Kitchen island plug under the island overhang? - Beyond.ca - Car Forums
Results 1 to 14 of 14
Thread: Kitchen island plug under the island overhang?
    2020 Subaru Forester Sport
    Default Kitchen island plug under the island overhang?
    Hi guys,
    Redoing my kitchen right now and need to install a plug. Because I am doing a waterfall face on the sides, i have nowhere to put the plug. My one option is under the overhang, which is about 11". Reading online, some people say you can't put it if it's 12" or more, but I don't really know if there are any local Calgary codes regarding this. Anyone know?
    Thanks
    Stampede Central
    is pretty sharp lookin'
    I believe this stuff comes out of the Canadian Electrical Code.
    See page 5. I don't think you're allowed when there's more than 150mm (6") overhang.
    https://www.esasafe.com/assets/files...ns/26-23-2.pdf
    Suggestion to solve your problem, though I'm not sure if it'll meet code or create more problems. Outlet inside of a cabinet?
    Read that over a few times, so confusing. I think I am getting the same vibe regarding the 6" stuff, but in the same sentence they are talking about 300mm (12"), but perhaps that means vertically, not really sure. The picture they used as an example definitely protrudes much more than 6".
    Stampede Central
    I believe the 300mm means the distance to the countertop.
    Bummer. Looks like short of putting a plug into the waterfall edge, I got no other options. Sucks.
    My home has the plugs in the waterfall edges as well. It doesn't bother me since it is white on white.
    Oct 2008
    South of Calgary
    is broken
    Do it after the inspector leaves
    May 2004
    Calgary, AB -- Canada
    Maybe the kind that recess into the top of the countertop/island would work better for you? They have models that are approved for use in Canada in kitchen counter installations.
    SOURCE: http://www.lewelectric.com/kitchen-countertop/
    Not Aspen
    Two from Freemont
    My plugs are in the waterfall sides. Easy to access location.
    Thanks guys. I looked into the pop up ones as well, but since i have drawers below, I can't really put one of those in, and heard they don't pass code as they are not "permanent", aka, plugin.
    For those who have plugs in the waterfall, did you guys do your own kitchen or someone else? I am just curious on how to place the plug. Reason I ask, is I am doing my own kitchen, but the quarts people will come out later to template. Do I just set the plug like normal, and then use very long screws later through the quarts hole, or does the metal box have to stick out the thickness of the quarts?
    Not Aspen
    Two from Freemont
    I am too lazy to take it apart more than this.
    Name:  File 2017-08-01, 11 50 00 AM.jpg
    Name:  File 2017-08-01, 11 50 16 AM.jpg
    Name:  File 2017-08-01, 11 53 35 AM.jpg
    '91 NA1 ADVAN'D
    You can also have the area of the plate recessed in to provide a more "flush" look as well
    Awesome, thanks for showing that to me. Looks like it's a normal plug, and then a box extension added for the thickness of the granite. Good to know!
    Benyl, are you able to snap a picture of the back of that? Guessing the back is sticking out into the cabinet? Thanks!
  1. installing an kitchen island
    By winson2001 in forum Home and Garden
    Latest Threads: 09-16-2013, 05:22 PM
  2. fs spoon plug and oem plug wires, ats gear set
    By tiper in forum Automotive Parts
    Latest Threads: 10-04-2008, 07:24 PM
  3. FS- Kensington travel plug adaptor, Apple keyboard/mouse, Apple Powerbook plug
    By RawB8figure in forum Computer Hardware & Peripherals
    Latest Threads: 12-12-2007, 10:58 PM
  4. FS: Kitchen Island/Server.
    By 89s1 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-11-2007, 02:53 PM
  5. WTB: ecu plug ins for a 1989-91 civic just the plug i need some pins for my swap
    By eeseen racing in forum Automotive Parts [Engine Electronics]
    Latest Threads: 09-21-2004, 08:32 PM
