Detached garage question - Beyond.ca - Car Forums
Results 1 to 6 of 6
Thread: Detached garage question
    Jul 2008
    Tdot n CT
    15,000 red line
    Default Detached garage question
    My parents are looking to build a detached garage on their triangle lot. Imagine an upside down triangle. One side of the triangle already has a gravel pad but puts the garage at an awkward angle. If garage goes on the other side, the angles/ landscaping is sorted.
    However, gas/eletric/telus lines run parallel through it. Gas line is sleeved. Can we build a garage on top of all three lines? What issues might come up in future, and will they be on hook for these?
    Stampede Central
    is pretty sharp lookin'
    Pretty sure you're not allowed to build on a right of way (utilities). They have the right to tear it all down if they need to get access, and you're on the hook for all tear-down charges.
    *edit* you could also work with utils to see if you can move them. Tonnes of excavating but may be worth it?
    Chevy Colorado ZR2
    I got my gas line sleeved for a hefty $3K during my one to two car garage conversion.
    Other utilities like gas or electric I do not think you can place a permanent structure over it.
    jwslam's suggestion could work, either way you have to pay to get them moved.
    Or re-landscape the original area is probably the cheaper option.
    Elbonia
    Jeep of Theseus
    From a CoC brochure:
    Provincial regulations prohibit the construction of
    a garage over a gas line. If you are faced with this
    problem, you can either move the garage at least
    30 cm (1 ft) from the gas line or have the service
    line relocated. For more information, contact your
    gas service provider.
    Doesn't say anything about electrical/comms, you could probably ask the provider. Chances are they will say go ahead, but if they have to service it any additional costs or damages are on you.
    From a different CoC page:
    For information about building near or over gas lines, contact ATCO Gas at 403-245-7888.
    If you have any questions regarding clearance from utility lines and boxes, contact ENMAX at 403-514-6100​.
    No structures are permitted to be built in a utility right-of-way.
    I'd opt to relocate the utilities if you can't make the landscaping work on the other side. You could possibly use the new utility trench to run your services to the garage, worth an ask.
    Dec 2012
    Alberta
    16' IS350 AWD / '93 LHD FD3S
    gas lines are hard piped, electrical is not - generally they can pull the cable whereas they cannot pull piping as easily from under a structure.
    Only 15min from Aspen!
    Nothing interesting anymore
    My garage was poured on top of the gas line before such a rule existed. I hope to hell we never have to get it replaced/repaired. (ditto with the sewage line, which is much more likely to need work done)
  1. Insulating detached garage question
    By drtoohotty1 in forum Home and Garden
    Latest Threads: 11-15-2012, 04:03 PM
  2. Question about elec line going to detached garage
    By DENZILDON in forum Home and Garden
    Latest Threads: 07-14-2011, 07:53 PM
  3. FR: Single detached oversized garage in SW
    By lint in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 06-07-2010, 11:58 AM
  4. New home detached garage issue
    By bobafixed in forum Home and Garden
    Latest Threads: 02-01-2010, 11:07 AM
  5. Wanted: Detached Single Garage in SW Calgary
    By KyleTA in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-01-2009, 12:39 AM
