Laptop Won't Boot; "Media Fail" Issue - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Laptop Won't Boot; "Media Fail" Issue
    Jul 2006
    Victoria Park
    Default Laptop Won't Boot; "Media Fail" Issue
    Hey guys,
    Maybe some gurus can help me out as I'm stumped.
    My Toshiba laptop won't boot up and shows the following sequence of errors:
    I googled the case and tried going into bios to see if it recognized the drive, and it looks like it does.
    So more googling suggests trying to boot with Secure Boot disabled and Boot Mode in CSM Mode. I tried that and now the screen shows this:
    The computer originally came with Windows 8, but has since upgraded to Windows 10 when this occurred. I tried loading an ISO of 8.1 and 10 on a flash drive (NTFS format) but it doesn't do anything even though BIOS sees the flash drive. Does it need to be on a DVD or something? Am I missing a step? Not sure what else to try.
    Thanks.
    Yea that looks like a corrputed boot loader. You will have to make a USB repair disk (or DVD) using W10 image, and run the diagnostic programs to rectify the issue.
    Jul 2006
    Victoria Park
    Thanks. I ended up having a bunch of issues but figured out where I went wrong.
    Followed this and it worked!
    http://www.screwloose.com.au/windows...annot-be-found
    Unknown
    Make sure you have a backup of your personal files, as the error is most often indicative of a failing hard drive.
    Jul 2006
    Victoria Park
    Quote Originally Posted by Seth1968 View Post
    Thanks, I will do doing that since I'm still experiencing some issues after following the procedure in the link of my last post.
    Basically, I can only boot using my flash drive, and without it, it comes up with the same error as my first post. Because of this, the computer is slow as fuck but everything does boot up "normally" with the USB plugged in.
    Not sure what to do about that now, but at least I can boot up lol.
    Unknown
    Run an extensive hard drive test:
    https://support.wdc.com/downloads.aspx?p=3
    If you have to back up your data, do that first, as the diagnostics make the hard drive work very hard, and that could be enough to cause the hard drive to fail completely.
    Your drive is done. Plan for a replacement ASAP. Once symptoms start to manifest like this is usually the problems are already serious.
    Jul 2006
    Victoria Park
    K thanks guys, I'll save all my personal stuff tonight and then do that HD test.
    Worst case I'll install a clean copy for the time being until I get a replacement.
    Has four wheels
    I wouldn't bother. You'd just have to do it twice.
    Just back up your stuff, and buy a new drive from Memory Express.
  1. Installed ssd, laptop won't boot off windows usb/dvd, Plz Help
    By r0g3r in forum Computers, Consoles, and other Electronics
    Latest Threads: 01-07-2013, 04:26 AM
  2. Laptop won't boot up after upgrading ram?
    By G-ZUS in forum Computer Help Desk
    Latest Threads: 01-12-2009, 10:53 PM
  3. explorer.exe won't boot up on laptop
    By Disoblige in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-19-2008, 06:03 PM
  4. HELP: Laptop won't boot
    By dooman24 in forum Computers, Consoles, and other Electronics
    Latest Threads: 08-18-2005, 12:38 PM
