Winterizing your motorcycle - Beyond.ca - Car Forums
Results 1 to 16 of 16
Thread: Winterizing your motorcycle
    Aug 2004
    Edmonton/Calgary
    This and that.
    Default Winterizing your motorcycle
    How do you guys winterize your bikes? I've owned a few but never nice enough ones to bother about that until now so not sure what it entails.
    Apr 2014
    MR2
    Garage stored? Batter tender, stands, and cover is all I do. Also just cleaning it up nicely just before storage
    Oct 2004
    Quote Originally Posted by shakalaka View Post
    I'll give her a good cleaning, fill it full of fuel and throw in some fuel stabilizer. I also park it on a piece of plywood on its center stand and remove battery and put that on a trickle charger. Lastly, I put the cover on it. Make sure to start her up every couple of months too.
    Jun 2014
    Quote Originally Posted by blueToy View Post
    Everyone has their own method when it comes to break in and winterizing but starting the bike here and there over the winter is supposed to be really bad for the bike. I used to do that all the time(more for hearing the bike lol) but i stopped a couple years ago because i heard on a couple forums its supposed to be really bad for the bike and not necessary at all.
    Heres my routine and this could be totally wrong too lol
    Stabil in the tank and let it run for abit to circulate
    Clean the bike
    Get her on the stands and then clean the chain and lube it up good
    Take the battery out and tender it indoors.
    Sing her a love song and then cover her up and cry for a bit
    Wipe off the tears and then go inside to order some mods to help the winter pass
    (maah raahde)
    Yeah, don't start up your bike until you're going to ride it for good.
    Quote Originally Posted by Rocket1k78 View Post
    Other than periodically starting up your bike if you're not ready to ride again, this is a terrible thing to do cause then you'll be itching to put them on all winter and it will eat away at you haha
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    I don’t do anything... beside random winter rides when we get a good chinook
    But for those that actually put them away... surprised you guys don’t pull plugs and fog
    Aug 2004
    Edmonton/Calgary
    This and that.
    Didn't realize this became a thread. Makes sense though. Thanks guys.
    Mine is in a heated underground garage and I can cover it, put a fuel stabilizer and all that. Only issue being the battery, there is no plug in the parkade so can't connect it to a trickle charger while in the bike but will have to remove the battery and bring it into the condo. Is that something I should definitely do though? I was thinking if I leave the battery in and run it like a few times every month for a few minutes to get the battery charged and wrap it up again. Sounds like that's not a good idea?
    Bring the battery up to your apartment and charge it with a charger.
    Feb 2008
    AMGGGGGGsixtythree
    You can bring the battery up but unless the battery is easy to get to, just start it up once a month is fine. Fuel stabilizer. good clean/wash before putting a cover on top.
    Roll your wheels at the same time too, unless they are on stands.
    Oct 2008
    South of Calgary
    is broken
    Here is mine in a cold garage, but really taking care of the battery is #1 for cold storage.
    Wash, clay, wax.
    Put on rear stand
    Remove battery and place in closet with maintenance charger.
    Fuel in the tank must not have Ethanol since it absorbs water. Add stabilizer if I have it.
    Clean and lube chain, *check tension
    Cover
    Also a good time to clean all your gear, my textile gear gets full of bug guts.
    Then in the spring. Oil change, just do it regardless of km since its convenient.
    Check valve clearance. replace any necessary fluids.
    Ride!
    Do not do this, idling a bike in the dead of winter can be a sure fire way to kill the battery (many bikes barely produce a charge at idle) and to introduce excess combustion byproducts into the crankcase from excessive idling.
    This notion of starting the bike up likely stems from Carb bikes of years gone by - where fuel will turn into slime in the small passages if its left sitting around. People who were lazy and didnt drain their float bowls tended to start up the bike instead.
    If you dont have a charger (you should), best is to cover it, disconnect the negative post, fill tank ( to prevent corrosion on exposed surfaces) stabilize fuel, change oil and leave it.
    Most Lead-Acid batteries lose about 5% a month in storage.
    Note: "The self-discharge of all battery chemistries increases at higher temperature, and the rate typically doubles with every 10°C" .
    Dec 2008
    Unit 91 come in 91
    When I stored my Harley last winter all I did was pull the battery and take it up to my condo and placed it on a trickle charger for the winter time. I just tossed a cover on it. It had fuel in it before and was totally fine.
    I started it once a month or so. But like others said no need to really do that. I personally don't think there's any issues doing that since I've done it several times with vehicles and bikes over the years to just get fluids moving and it operating at normal temp.
    Aug 2009
    Local
    Can't driver because I'm legally blind
    Quote Originally Posted by ercchry View Post
    Word, I like to do occasional burnout and piss around on them during the winter months so I don't do a god damn thing. I won't even cover them cause I like to stare and dream during the winter.
    Oct 2004
    Quote Originally Posted by Shlade View Post
    I guess I should've mentioned I do it to my carb'd bike. Thirty two years now, still runs like new.
    (maah raahde)
    Quote Originally Posted by roll_over View Post
    If I can't go riding in the streets, I may as well winterize it cause I'm not going to go peeling around the parkade like a jackass. Since my parkade gets dusty as fuck I cover it during the winter so no staring and dreaming for me unless it's
    Jun 2014
    Quote Originally Posted by D'z Nutz View Post
    LOL thats a pretty awesome PS. I dont like to cover mine either because i like to go in every other day to say hi to her
  1. winterizing cars?
    By boi-alien in forum General Car/Bike Talk
    Latest Threads: 11-08-2011, 11:43 AM
  2. Winterizing bike... Where to get seafoam?
    By 240bsxed in forum General Car/Bike Talk
    Latest Threads: 10-29-2010, 08:41 PM
  3. Winterizing the car to park in the winter
    By iamkorean in forum General Car/Bike Talk
    Latest Threads: 11-19-2007, 10:24 PM
  4. Winterizing your car
    By New2Talon in forum General Car/Bike Talk
    Latest Threads: 08-21-2006, 07:49 AM
  5. last pics of my s2000 and eclipse before winterizing
    By 4doorj in forum Cars, Bikes, Machines
    Latest Threads: 12-22-2005, 10:56 AM
