Newly built home owner, garage question regarding drainage - Beyond.ca - Car Forums
Results 1 to 20 of 34
Thread: Newly built home owner, garage question regarding drainage
    Nov 2003
    2008 Mercedes Benz C230, 1968 Chevy Impala
    Default Newly built home owner, garage question regarding drainage
    So this is my first winter in my new home that was just built. Last night was the first night I pulled into the garage with the car having ice build up in the wheel wells. The snow melted and rather than drain out the front of the garage onto the drive way, I have quite a bit of pooling.
    Should the garage pad not be sloped for all run off to exit the garage? Is this something I should bring up with my builder or am I up shit creek and should just accept it? Wanting to ask you guys so I can manage my expectations with my builder if I reach out to them.
    1968 Impala: Status: Stored
    1977 Dodge Triple E RV: Sold
    1989 Mercedes Benz 420 SEL: Sold
    2008 Mercedes Benz C230: Cruising
    2000 Bluebird TC2000: Build phase of skoolie project
    2018 Rav4 XLE: New baby friendly daily
    Feb 2007
    1991 Toyota Soarer
    Typically the garage will slope 3-4" from the front to the large garage door, it should show if a slope is required on the house cross section of the plans if you still have them.
    Apr 2006
    2011 Ralliart SB
    Last 3 drive ways have been almost perfectly level. I keep a shop broom and a square trowel in the garage for dirt and snow clean up.
    Buy a floor squeegee and next house put a drain in your garage. Builder isn't going to do anything about this.
    Stampede Central
    is pretty sharp lookin'
    Quote Originally Posted by roopi View Post
    Hmm is it possible to add a floor sealant and try to make the grade using that?
    Jun 2007
    Calgary/Alberta
    If the homebuilder won't do anything and you find the slope of the garage is fine but just a bit of pooling from cement settling (happens quite a bit)
    Then use this stuff, if you don't have the tools try and find like a foot long 2x4 and level with the side of it.
    https://www.homedepot.com/p/Quikrete...4011/100318542
    The stuff is pretty fool proof to use, just try your best to make sure the area you are using it dry before hand and give it time to settle before driving on it etc.
    Nov 2003
    I tried to get them to put in a garage drain and Jayman said its not an option they offer.
    FB6
    Quote Originally Posted by cycosis View Post
    Had the same answer with Albi. They would only allow a line drain along the outside of the garage door which I found kinda pointless.
    Aug 2015
    SL550, P100DL, F-450, FIAT
    Calbridge does floor drains. $3500 for a single round one in the middle of The garage and $9000 for a line drain along the inside along the door. Ridiculous pricing IMO.
    Professionally Retired
    Not Aspen
    Two from Freemont
    weird. I got 2 for $400 each.
    Quote Originally Posted by KPHMPH View Post
    Lol what. Baywest was $400-$500.
    Dec 2005
    not calgary
    changes every year
    that must be for existing concrete.
    '21 F150 Lariat Nardo Grey
    I think mine was around the same price as Roopi's. We built with with Morrison in 2013.
    Dec 2008
    Every house I’ve lived in has had a near dead level garage pad. I didn’t know some were sloped. Would be a pain in the ass building shelves!
    Nov 2003
    What it looks like. Just pools, doesnt drain
    Sep 2005
    yqr
    Yup. That's normal. You can try a containment mat.
    The SHBARUS
    When it's cold enough outside, it's just going to form an ice dam at the door anyway. I usually just try to sweep the water out without building an ice rink outside the best I can.
    Aug 2007
    dad van
    That looks like they might have run short on concrete and left a dip. Pretty easy to check if you run a string line from the front wall to front of the slab.
    Aug 2017
    'Berta
    A bunch of Nissans..duh.
    My old Jayman home did this, same with my attached garage now from Shane. Thought it was normal and intentional, you wouldn't want it leak out and freeze to ice right? I just use my janitor broom to push it out and to the sides off the driveway. I wondered about drainage holes, wouldn't that let in cold air into your garage???
    Nov 2003
    Quote Originally Posted by NissanFanBoy View Post
    I've been sweeping. It out and as soon as it hits my driveway it freezes so now I have a delightful skating rink on half my driveway
  1. Garage door seal and drainage - good idea or terrible idea?
    By BerserkerCatSplat in forum Home and Garden
    Latest Threads: 06-10-2015, 04:53 PM
  2. Realtor for a newly built home?
    By rx7boi in forum Real Estate / Finance
    Latest Threads: 09-11-2014, 05:12 PM
  3. Building code regarding property drainage
    By redblack in forum Society / Law / Current Events / Politics
    Latest Threads: 10-04-2008, 08:48 PM
  4. Best way to move into a newly build home?
    By treg50 in forum Real Estate / Finance
    Latest Threads: 11-04-2007, 11:40 AM
  5. FS: Newly Built Prestwick Jayman house
    By rinny in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-04-2007, 12:36 PM
