Threshold Braking vs ABS - Beyond.ca - Car Forums
Page 1 of 5 1 2 ... LastLast
Results 1 to 20 of 88
Thread: Threshold Braking vs ABS
    Jan 2016
    The YYC
    Parked in the Bike Lane
    Default Threshold Braking vs ABS
    Quote Originally Posted by spikerS View Post
    just did the trek from Coventry down to southcenter mall area, and back. Going south on Deerfoot wasn't bad, was doing 100 in the fast lane, most people in the middle lane were doing 70-80. On the way back though, had to go quite a bit slower, the slightest throttle input was making the truck step out, especially over the calf robe. Was pretty much cruising at 55-60. touch the brakes and ABS kicked on, put my threshold breaking skills to the test for sure and left lots of room.
    KA02 performance today wasn't very good on the roads, Gonna have to put on the studded winters sooner than I was hoping to.
    you are threshold braking in a vehicle with abs?
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    Quote Originally Posted by RealJimmyJames View Post
    Yes, I do threshold braking to avoid ABS kicking on unless it is a situation that calls for emergency breaking.
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
    Dec 2008
    Everyone should. Relying on ABS is a crutch.
    Still don’t get why people are continuing the winter tire debate. Obviously winter tires don’t replace good driving skills that is a silly arguement, but just like good brakes they complement them. A pretty freaking simple concept in my eyes
    (maah raahde)
    Weird. I always assumed that's how everyone did it too. I didn't even know it had a name until I looked it up just now.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Have experts not tested threshold vs abs to death?!
    Been proven over and over again that abs does a better job than any human ever could?
    Oct 2006
    '21 F150 PowerBoost
    Quote Originally Posted by ercchry View Post
    in 99% of situations, yes, especially when steering input is still needed, but, that was never the argument here.
    Turbos cost money
    Dec 2008
    Fairly certain it’s been beaten to death that threshold braking out performs ABS. Pumping the brakes does not though. I know from empirical testing stomping and relying on ABS on my car’s at least increases stopping distances over threshold.
    They have stopped teaching it in drivers ed from what I know as it takes forever to master and most people are better off stomping and letting ABS figure it out.
    I spent my first 5 winters in a car that didn't have ABS so that wasn’t even an option.
    https://jalopnik.com/how-to-stop-on-...kes-1790269905
    http://www.drivingfast.net/braking/
    Red Deer, Alberta
    1995 WRX STi
    Its pretty straightforward, once a tire has lost traction and ABS has kicked in, the friction force between the tire and ground is lowered (because the tire is sliding). In order to get back to a higher friction state, the ABS must lower the braking force to a point the tire starts rolling again, which is less force than if you had simply threshold braked and never lost traction in the first place.
    Having said that, this is an extremely simplistic viewpoint and there are a lot of variables. But one other thing to consider is if you hit abs engagement, what do you typically do?
    You press the brake harder. As its basically impossible to know when ABS will kick in (different cars have different programming for.when and how it will kick in), again, threshold braking is superior.
    The tests that show ABS is better usually is in regards to HIGH FRICTION situations. It's no different than doing software for self driving cars. High friction situations completely eliminate an incredibly important variable, which is traction. If that is taken care of (traction/friction variable is always just used at its maximum) it is easy to optimize the system for that.
    Have ABS systems come a long way? Absolutely. For a lot of drivers, Im.sure they help. But they aren't the best answer.
    Feb 2006
    Isn't the real purpose of ABS to maintain directional control during braking?
    Isn't braking lightly different than true threshold braking?
    Dec 2008
    Quote Originally Posted by ianmcc View Post
    Cant turn if you’re locked up so you’re right on that point but other main purpose is to keep from locking up to decrease stopping distance (vs full and continuous lockup). If you’re on a sheet of ice it’ll take days to stop if you don’t have ABS and lock it up.
    - - - Updated - - -
    Threshold braking is taking it to the limit of traction while staying under the limit where abs kicks in. Essentially “braking lightly” in a stomp vs threshold perspective.
    Cochrane, AB
    Trucks
    Threshold braking is useless on really bad roads. I recently had a bad speed sensor on my WRX and on Crowchild yesterday, the slush and snow between the lanes was fairly deep. (No ABS, traction/stability control, no hill assist) Feathering the brakes at all would send the car half a lane sideways as one side had 90% traction and the other had 1%. On my return trip, the car was back normal and the ABS let me brake as hard or as little as I wanted and the car was straight as an arrow. I was very much against ABS as a young driver but the newer driving aids are now pretty sweet. I only now hate ABS on gravel as it most definitely increasing stopping distance vs digging the tires in.
    Dec 2008
    All over
    CAEB, 6G72
    in before:
    When accelerating its much easier to mash the throttle and let traction control sort it out, rather than learn how to accelerate properly. #millennials (?)
    X5D, Fiesta ST
    My goals are always to drive without ABS intervention however it does happen (ie a pedestrian j walked in front of me from a dark alley last night and had to make a very quick stop). When we go out on the lake I generally pull my ABS fuse however that’s more for a competition point of view where I need to be able to left foot brake mid corner at times and use the handbrake on corner entry a lot in my car.
    Bicycle
    This is basically the same as the whole manual vs auto debate. Eventually technology will out perform most human. ABS today isn't the same as ABS from 20 years ago. I remember there were always pile up at the end of a neighborhood hill until ABS and winter tires are more common. People who knows and care about threshold braking isn't the 80-90% of mainstream public which ABS is designed to save.
    And I don't know if people with ABS are still pumping their brakes, remember a lot of people didn't transition well into ABS early on and pumps them which make it perform way worse.
    for many years I loved having a manual transmission on a part-time 4 for engine braking on ice... but these days every auto transmission is gearmatic, let alone a DSG so you can still do the same thing but by no means would I ever say that this method of slowing down is > ABS
    I mean some ABS systems are far more invasive than others, but those sensors are detecting when your tires have "locked"... so by the time the ABS is engaging, you aren't so called "threshold" breaking.
    also performance threshold breaking on tarmac while racing is so incredibly different than a 0 traction environment.
    Though I love my F150 with the locker, part time 4 and geartronic... the fact is its primarily RWD, solid rear axle, weighs alot, high center of gravity... so in flat corners or uneven icy roads, or emergency braking in traffic, I'd take my AWD Volvo with studded Winters any day.
    On a straight highway in inclement weather where must need to be safe and able to get through all potential snow/ice condition (or to get out of a ditch if it so happens...) I prefer my truck with the Cooper AT/Ws (X/T4)
    Only 15min from Aspen!
    Nothing interesting anymore
    TIL people actually use ABS brakes in their habitual driving, and not as an emergency braking procedure. I can't remember the last time I had my ABS in use.
    Feb 2011
    Calgary, AB.
    Quote Originally Posted by D'z Nutz View Post
    Same here. I've been driving like that since I started driving, never knew there was a word for it. Also stopping on undriven/unpolished spots help and if there are patches of concrete I'll brake hard on them.
    I find I can definitely stop sooner and harder in snowy/icy conditions by braking just to the point before ABS kicks in. If I need to also steer, then I let the ABS do it's thing. I assumed this is what everyone does because it's super easy to tell which way makes the car stop harder. Especially with a good set of winters it's astonishing how hard you can stop in some pretty horrible conditions.
    TIL that I'm a much worse driver than most of beyond because when there's snow and ice on the ground, my ABS kicks in at least a few times a week.
  1. What is the threshold for "beater"?
    By jwslam in forum General Car/Bike Talk
    Latest Threads: 02-04-2017, 11:46 AM
  2. Anyone know how to change abs for non abs on S13
    By jurajs240SX-H in forum Mechanical
    Latest Threads: 10-02-2010, 06:32 PM
  3. Motorcycle Fatal Crash ABS Brakes vs Non-ABS
    Latest Threads: 07-02-2010, 03:28 PM
  4. V02 Max and Anaerobic Threshold testing in Calgary
    By Super_Geo in forum Health and Fitness
    Latest Threads: 07-22-2009, 02:26 PM
  5. Lost a serious amount of braking power
    By Fluidic in forum Mechanical
    Latest Threads: 09-10-2002, 11:23 AM
