Smart Thermostat with Humidity Control - Beyond.ca - Car Forums
Results 1 to 18 of 18
Thread: Smart Thermostat with Humidity Control
    Aug 2005
    2007 4Runner
    Default Smart Thermostat with Humidity Control
    With all these rebate programs which thermostat is everyone getting that has a humidity control. From all the research there aren't many or next to no options.
    Dec 2006
    Nothing worth mentioning.
    My ecobee does. Home Depot sells them.
    I think you need to do better research haha.
    Aug 2005
    2007 4Runner
    I guess so hey
    May 2007
    '19 GTI
    Nest
    Oct 2003
    Mazda 3
    Quote Originally Posted by Kjonus View Post
    Better research for sure. I don't think there are "all these" rebate programs. Just the one I know of.
    Here is a start to narrow down your list of thermostats applicable for rebates.
    https://www.efficiencyalberta.ca/onl...t-thermostats/
    The top 3 most popular options that qualify for rebate on that list, Honeywell T6 is the only one that doesn’t support a humidifier. Nest and Ecobee supports it. So ya, not sure where you’re getting next to no options.
    Sep 2008
    Edmonton, AB
    I was thinking of getting the Ecobee 3 to control my desert spring humidifier. It has a manual control that I have to constantly mess with depending on the outside temp.
    Does the Ecobee do a really good job of maintaining the correct humidity? Home Depot has it for $219 right now.
    I checked and I don't have a C wire and I'm guessing there's a wire to the humidifier I'd have to run as well.
    I was going to do some more reading but I'm mostly wonder if it's worth all the effort...
    Originally posted by Xtrema
    Originally posted by DayGlow
    How do you respond to stupid?
    Originally posted by rage2
    Originally posted by Seth1968
    Sep 2012
    Yes, it works great. It's worth it to prevent window trim damage.
    Apr 2003
    WK2
    Quote Originally Posted by ipeefreely View Post
    I opted to add a c-wire, was pretty easy as the basement is undeveloped. My humidifier was already being controlled by my furnace (or old thermostat - HVAC is an ongoing learning experience). But the ecobee3 does a great job controlling the humidity - or at least, its always fairly constant in my house, usually between 34-36%.
    Sep 2008
    Edmonton, AB
    Quote Originally Posted by 94CoRd View Post
    Cool! Thanks guys!
    I'll order one then figure it all out when it arrives!
    Oh, one more question... did you set it to Evaporate or Steam? ecobee3-configuration-tips-for-humidifiers
    I have cold water going to the humidifier so it won't be as effective but it should still help I think... the house air is still warm.
    Sep 2012
    Just make sure you use fire-rated wire. They sell a single fire-rated wire at Home Depot (or least they did when I looked years ago).
    Set it to evaporate, unless you have a steam humidifier.
    After reading all the threads on this i decided to have a go at hooking my home humidifier up to Nest ( 2nd Gen ). You know the whole thing wouldn't be so damn complicated if Nest wouldn't be so pigheaded about humidifier installs being Pro only...
    I have a generalaire 900 hooked up to the bundled generalaire MXH3 humidistat ( which i noticed has a built in relay that could easily be repurposed if someone has one of these and wants to do an ecobee or nest install).
    Anyways after a couple hours of forum surfing i realized all that really needed to happen is Common from the furnace hooked up to one end of the solenoid ( which was already done) and the other side of the solenoid wired to * on the Nest. Set it to humidify only when heating since thats what the relay accomplished previously in pro settings and done. No relay needed though this is a fairly modern humidifier and furnace.
    Spent most of the time trying to decipher the terrible wiring my original HVAC installer did...
    Been having some lingering colds etc. that last few weeks between me and the wife so hopefully this helps! Also would be nice not to lose a gallon a day of water out of my fish tank...
    calgary AB
    toyota MR2
    What do you guys have your humidity set at for the winter?
    The SHBARUS
    The air is so dry in our climate that I found my humidifier is just trying to keep up. It’s practically on the entire time from fall to spring.
    Even with my humidifier disabled my house has always been north of 30%, going to try to hold at 40 with the nest and see how that feels.
    calgary AB
    toyota MR2
    My humidifier is dry as a bone and hasn't worked since we moved in and I consistently see +30% all year round and get major window sweat.
    Nov 2003
    2008 Mercedes Benz C230, 1968 Chevy Impala
    I have two of the fancy lyric units and an HRV. Humidity set at 30%. House is vented for 20 minutes each hour. No build up condensation on windows.
    1968 Impala: Status: Stored
    1977 Dodge Triple E RV: Sold
    1989 Mercedes Benz 420 SEL: Sold
    2008 Mercedes Benz C230: Cruising
    2000 Bluebird TC2000: Build phase of skoolie project
    2018 Rav4 XLE: New baby friendly daily
  1. Smart thermostat - ecobee3
    By ganesh in forum Home and Garden
    Latest Threads: 06-21-2018, 08:36 AM
  2. Nest thermostat to replace old thermostat and humidistat
    By saziz111 in forum Home and Garden
    Latest Threads: 05-23-2017, 02:32 PM
  3. FS: MISB Nest Wi-Fi Smart Thermostat T3007EF (3rd Gen.) -- $235
    By Chiggles in forum Consumer Electronics
    Latest Threads: 11-28-2016, 07:43 AM
  4. FS: Ecobee3 Smart Thermostat
    By spike98 in forum Consumer Electronics
    Latest Threads: 08-04-2015, 11:02 AM
  5. Smart (Wifi) Thermostat + HRV + Humidifier Q's?
    By nobb in forum Real Estate / Finance
    Latest Threads: 06-20-2015, 09:20 AM
