Cycling Sales and Deals - Page 11 - Beyond.ca - Car Forums
Page 11 of 27 FirstFirst ... 10 11 12 21 ... LastLast
Results 201 to 220 of 527
Thread: Cycling Sales and Deals
  1. #201
    '14 Taco
    Sent you a note.. not sure the BB would fit on mine (have a PF86 in it currently)
  2. #202
    Oct 2009
    rally pig
    the crankset might work but yeah you might need a PF BB.
    maybe your current one will fit. else I see that Shimano has a BB86
  3. #203
    Not Aspen
    Two from Freemont
    have any of you guys looked into China carbon wheels?
    Have any links?
  4. #204
    Oct 2009
    rally pig
    Have any links?
    38mm or 50mm
    https://www.ebay.ca/itm/50mm-Clinche...e/173589717569
    https://www.ebay.ca/itm/Disc-Brake-C...k/273453193127
  5. #205
    Sep 2002
    CGY
    Cayman, F150, Crosstour
    Nope Nope. I would not take the risk of a potential failure. I've heard horror stories of other china carbon parts....
  6. #206
    Oct 2009
    rally pig
    Quote Originally Posted by CLiVE View Post
    Out of curiosity but do you know someone personally that had china carbon parts fail on them or mostly online stories?
    But yeah, I've been thinking about it the past couple of days and have decided not to look into chinese carbon wheels for now. Not because I'm worried about failing parts but mostly because I want to see how the stock wheels perform first. Also I can buy more reputable brand for the same price or slightly more.
    My skills are no where near to require buying a set of wheels that cost as much or more than my bike lol
  7. #207
    Sep 2002
    CGY
    Yes, personally and first hand. ie: I was riding with someone when a set of carbon aerobars failed sending them head first into the ground.
    Another friend of mine had a carbon frame fail.
  8. #208
    Oct 2009
    rally pig
    that will definitely refrain someone from getting chinese carbon parts.
    yeah.. I think I'm going to save for more reputable wheels.
  9. #209
    Oct 2003
    ute
    I've been running carbon wheels on my mountain bikes for years.
    Many of the carbon wheels you would buy are manufactured in China, at the same facilities. A lot of the "boutique" carbon wheel manufacturers are just re-branded Light Bicycle (or similar) wheels.
    I can't speak for the handlebars, frames, etc. But the Chinese Carbon wheel industry is quite mature at this point. I just built up some Carbonfan wheels with some Onyx hubs.
  10. #210
    If you're training with power indoors already, not using a power meter outdoors negates a lot of the benefit unless you're very good at feeling out your RPE outdoors. Yes using a power meter is good for calculating training levels etc, but where you get the benefit after doing all the training indoors will be translating those numbers you're used to seeing indoors, outdoors.
    I would consider Chinese carbon wheels, but only from a well documented brand like FSE. But for the price difference, I'd rather ride a set of FLO wheels which are wind tunnel and real world aero tested.
  11. #211
    '14 Taco
    Quote Originally Posted by buh_buh View Post
    Pretty well basing it off of HR right now. Know that my threshold HR is pretty close to threshold power.. one issue is that after the swim for the tri, it took forever for my HR to drop
  12. #212
    Sep 2002
    CGY
    Increase your kick when you're almost finished the swim. Helps with blood flow and the transition from prone to vertical. When you get on the bike start in an easy gear, take in some water and get settled for a minute. Then get on the power. Gotta love the dizziness coming out of cold water....lol
  13. #213
    '14 Taco
    Might be more tempted by this one:
    https://www.probikekit.ca/cycling-po...B&gclsrc=aw.ds
    Going to the bike shop to figure out wtf my BB is and how much that will make my life hell if i go the crank one instead. Pros/Cons between crank vs pedal?
  14. #214
    Sep 2002
    CGY
    I went pedal based initially (garmin) figuring I would swap them between bikes. I never did, plus love my speedplays pedals (really hate heavy feeling pedals), and the garmin made me run look cleats.
    But nothing wrong with pedal based
    Later switched to crank based on my dedicated tri bike, and the rest of my bikes I don't bother...
    The only issues I've had with crank based is interfering with rear-aero brakes under the frame. Power meter on the inside of the crank interferes with the clearance/action of the rear brake.
    Let me know about the BB. Have a bunch lying around.
  15. #215
    (maah raahde)
    Agreed. I'd have no problems getting Chinese carbon wheels (or any other parts) as long as they're from a reputable seller. I wouldn't even consider either of those eBay links. Too sketchy. But yeah, like buh_buh says, for a bit more, I'd wait for the next FLO sale.
  16. #216
    50% off everything the Red Hook Shop with coupon code rhc50. Bought some Castelli bibs and random crap I probably don’t need. They’ve got a set of FFWD tubulars on there too I think the 50% off applies to.
    I’m using pedal based too (Vector 2), and I do swap them between my bikes which is why I got them. I wish they were easier to swap, as the pods are a bit annoying but it’s not a huge deal. The gf has the Powertap P1 and they seem pretty good. Neither of us have had issues with our power meters.
  17. #217
    Sep 2002
    CGY
    Quote Originally Posted by D'z Nutz View Post
    I've had good luck with Reynolds wheels. Usually can find them for prices close to the FLOs and quite a bit lighter.
  18. #218
    Bow Cycle temp sale on the 28th.
    The % off is the temperature in the negatives.
  19. #219
    Which Reynolds are you running that are a lot lighter than FLOs? I never thought FLOs were lightweights, but thought they were pretty decent at ~1700g for a 60mm rim.
  20. #220
    '14 Taco
    https://www.bowcycle.com/sales/tempe...ogIkpzcDlQeCJ9
    Overnight low on wednesday.. calling for -15.. meh
  1. Replies: 53
    Latest Threads: 08-28-2017, 12:13 PM
  2. E-Cycling: Where to go and what can i recycle?
    By BokCh0y in forum Computers, Consoles, and other Electronics
    Latest Threads: 05-27-2016, 08:52 PM
  3. Replies: 0
    Latest Threads: 07-01-2011, 10:18 PM
  4. Cycling and NYPD.
    By old&slow in forum General
    Latest Threads: 07-30-2008, 11:21 AM
  5. Heat cycling Tires
    By RickDaTuner in forum Mechanical
    Latest Threads: 08-27-2005, 07:42 AM
