Should you still plug in if you use synthetic oil? - Beyond.ca - Car Forums
Page 1 of 6 1 2 ... LastLast
Results 1 to 20 of 112
Thread: Should you still plug in if you use synthetic oil?
    Oct 2009
    Unknown
    Default Should you still plug in if you use synthetic oil?
    Of course it depends on just how cold we're talking about, but even if it's -30 like today, the synthetic oil shouldn't be sludge. So, does that mean it's at least somewhat unnecessary to use the block heater?
    Jul 2007
    Blue boy
    If you're battery is strong enough you dont need a block heater
    It depends 100% on the type of synthetic oil. Some synthetics wont pour any better than regular at these low temps.
    Plugging in, if its available, is usually preferable.
    Oct 2009
    Unknown
    WTH? I thought that was one of the main selling points of synthetic.
    Quote Originally Posted by Seth1968 View Post
    Most common synthetics have a pour point lower than any temperature Calgary ever gets to
    http://highperformancejunkies.com/5w30-oil-comparison/
    Oct 2009
    Unknown
    Whew. That makes me feel better
    Still, I would never have imagined a range of 20 degrees.
    Oct 2009
    Unknown
    Quote Originally Posted by G-ZUS View Post
    Please splain.
    Jan 2014
    AP1
    Plugging in your car will always help reduce wear since the oil will be warm and it won’t take so long to get to operating temp. I don’t think it’s necessary though. Didn’t have any trouble with my 200k km ‘88 civic that was never plugged in.
    Jul 2008
    North North Dakota
    Nissan x2
    Aren't most block heater plugs in the coolant system anyway? So unless you have one of those oil pan heater pads, like the wolverines, the residual heat from the block plug probably won't affect engine oil viscosity.
    Oct 2009
    Unknown
    Quote Originally Posted by EF9 Sedan View Post
    Well that depends on the type of oil. I just want to know if it's necessary to plug it in if you use a synthetic oil that retains it's viscosity even if it's let's say -30. It doesn't seem to be necessary, but I just want to make sure I'm not missing something.
    Main point?? Where did you that information?
    Its not like 100% of synthetics will pour better than regular oils at low temperatures. So many factors to consider.
    Jul 2008
    Edmonton, Alberta
    After my experience today, I will absolutely be plugging in when its cold. Its just easier on the vehicle. running mobil1 in my truck and she wouldn't start.. mind you it was possibly in combination with the battery, but -40 really took a toll on my v8.
    Aug 2017
    'Berta
    A bunch of Nissans..duh.
    My Murano started no problem, but there were some other loud signs for the first 5-7 mins lol... Coming from around the front belt areas, yikes... Went away though and have never heard it other than in this temp.
    Dec 2008
    Fairly certain with the pour point depressants in conventional oil there is very little difference between the pour point of new synthetic vs new conventional. Now high mileage conventional vs high mileage synthetic is a different story.
    Either way, plugging in when it’s this cold will do nothing but good things.
    If you want oil that's thinner at startup get an oil witha lower xW specification. All 5w-30 oils fall within a reasonably narrow range. Sure some so-called synthetic oils (another meaningless distinction) may be slightly less viscous but the difference isn't meaningful no matter what the YouTube scientists say.
    Buy the oil specified for your engine, maintain your battery, and plug in if you feel like it. That's the bottom line.
    Dec 2008
    Also bought an onboard Noco battery charger for my truck that I plug in along with the block heater, works wonders!
    Battery maintainer is more important than block heater imo. I rarely plug my vehicles in but I always hook up the battery tender if I do.
    Aug 2011
    Strathmore
    2005 Dirtymax
    Myth. Block heaters are coolant based and provide very little warmth to the oil pan. Want to warm up your pan? Use a pan heater.
    Block heaters just allow the block to be a bit warmer to help in the cabin temps.
    Dec 2008
    He’s partially right though. Although a block heater doesn’t heat the oil directly and very little conduction heat will make it to the pan it absolutely will (indirectly) get the oil up to operating temperature more quickly.
    That was my debate as well - block heater vs pan heater. In the end I chose pan heater because it was simpler. I did find that it helped warm up the car slightly faster than not though (on the morning I forgot to turn on the heater).
  1. Which Synthetic Oil do you use?
    By integra_vate in forum Mechanical
    Latest Threads: 07-08-2010, 02:03 PM
  2. Replies: 84
    Latest Threads: 10-28-2007, 03:12 PM
  3. Semi-synthetic to synthetic
    By beyondpinoy in forum General Car/Bike Talk
    Latest Threads: 11-23-2006, 10:00 PM
  4. Regular oil -> Synthetic oil
    By switch in forum Mechanical
    Latest Threads: 01-13-2004, 08:56 PM
  5. Synthetic, semi synthetic or mineral?
    By Patrick in forum Mechanical
    Latest Threads: 11-29-2003, 09:54 AM
