1.5 year old house. No hot water. Getting error code....wtf - Beyond.ca - Car Forums
Results 1 to 20 of 39
Thread: 1.5 year old house. No hot water. Getting error code....wtf
    Dec 2005
    not calgary
    changes every year
    Default 1.5 year old house. No hot water. Getting error code....wtf
    Any plumbers here? I tried calling the "emergency" number on my list of who installed what and I didnt get an answer or any sort of response.
    I've checked what the code means and it's a slew of different things it could be. Can anyone tell me where to start looking at fixing this? Or any idea on cost?
    3 flashes, 3 second pause
    "pressure switch or blower temperature switch not working-open position"
    1. Vent blockage or improper vent configuration.
    2. Pressure switch tubing kinked or blocked.
    3. Faulty pressure switch.
    4. Blower not spinning up to speed.
    5. Blower temp or exhaust temp too high
    6. Faulty blower temperature switch.
    Fuck me.
    Calgary AB Canada
    M5 Competition
    Make sure your exhaust vents are not frozen over. Go outside and take a look.
    Dec 2005
    not calgary
    changes every year
    They're clear and blowing.
    Jul 2013
    Calgary / Alberta
    Sounds like a high efficient tank with sidewall venting. First thing to check is the vents terminations on the side of your home. Ensure they aren’t blocked with snow/ice. Could be jammed in there a bit, especially on the intake vent.Pressure switch basically ensures the venting is clear before combustion takes place. Tank is probably locked out at this point. So turn it off(unplug it) and plug er back in after a few moments.
    Dec 2003
    By any chance you have a Bradford white defender?
    Same problem happened to me today. I've checked the vents outside the house, some frost build up. Cleared off the mesh screens.
    Pilot light is off and can't seem to get it to re-ignite, following the instructions.
    Will call the plumber tomorrow.
    Dec 2005
    not calgary
    changes every year
    Quote Originally Posted by jeffh View Post
    So if I feel air coming out of the vents outside, I can rule the blockage out? @jeffh
    Jul 2013
    Calgary / Alberta
    How many pipes you got coming out? You should have 2 for your furnace(single furnace) and 2 for your tank(single tank). Unless you have a concentric setup(all in one vent). Ensure you are focused on the tank’s vents, should be the smaller diameter ones. Now one of the pipes should be shorter and closer to the house. This will be the intake. It should not be blowing air out, but sucking it in. Peak your eyes up into it and ensure it doesnt have blockages. If there are steel mesh pieces on any of the terminations(90deg elbows or Tee’s), remove them and set aside for the longterm.
    Jul 2013
    Calgary / Alberta
    And i guess you could have a faulty pressure switch, as that is what the diagnostic code is dishing out. $80 part i assume. The pressure switch will be somewhere at the top of the tank attached to the vents by way of little hoses.
    Dec 2005
    not calgary
    changes every year
    Ok I have 2 small ones from the furnace and 2 bigger ones from the tank. The 2 bigger ones have the mesh. They both seem to be blowing air...
    Jul 2013
    Calgary / Alberta
    All i can say is ensure ALL of them are clear. Then reset your tank and watch it go through the sequences.
    Dec 2005
    not calgary
    changes every year
    Ok just checked and you're right, one is sucking and one is blowing. I took the mesh out...I'll reset again and report back lol @jeffh
    Calgary AB Canada
    M5 Competition
    Quote Originally Posted by 03ozwhip View Post
    Take a picture of your tank and the igniter system it uses.
    You will have two pipes coming off your tank, one is an intake vent and one is a exhaust vent. If the intake vent is frozen over it will cut power. You need to clear that vent. Power everything off and then restart it.
    Dec 2005
    not calgary
    changes every year
    So I think taking that mesh out is what resolved my issue. Went out the first time and it was blocked. Cleared it, still not working. Check it again, blocked again. Went out the 3rd time, removed mesh, no error codes, hot water is working.
    Thanks for your help guys. Saved me a headache for sure.
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Had this happen to me last night. Seems to only happen when it gets mighty cold outside too. Fixed it by removing the plastic grate on the intake and power cycling the hot water tank.
    Jul 2013
    Calgary / Alberta
    Glad my advice worked out for you.
    Elbonia
    Jeep of Theseus
    This is really common with those high-efficiency tanks in our climate. They install the intake and exhaust in such a way that the intake sucks in a bit of the hot, moist exhaust and in cold snaps that ices the intake pipe a bit, and they are REALLY sensitive to any blockages. Another Beyonder had that issue last year and we ended up raising the tank exhaust by about two feet to get it away from the intake.
    Dec 2005
    not calgary
    changes every year
    I've heard this happen to a lot of people and his is the first time it's happened to me. Before I posted here I checked it and it seemed fine.
    Anyways it was an easy fix, albeit stressful in this cold.
    Aug 2017
    'Berta
    A bunch of Nissans..duh.
    Same problem, same solution in my house. But I noticed something odder this morning, I always have it go down to 18 overnight then back up to 22 by 5am... This morning I come down at 7am and the thermostat control in our living room is reading 20.5?! Wtf!... Does anyone know where the actual thermostat that reads the temp is actually put? The house doesn't feel any different than 22 so I suspect the reading is fucked up or the actual reader is something near a window?
    Btw, first thing I did was go out and check the vents, no Frost and furnace is running normal with no flashes
    My worst fear is that there something wrong that is making the furnace not blow as hot??
    May 2010
    My builder didn't even install the mesh because they get too many calls about this problem. The mesh is beside the furnace, they gave me a warning that without you risk animals but is often easier than the annual lack of hot water.
    Aug 2011
    Strathmore
    2005 Dirtymax
    Quote Originally Posted by NissanFanBoy View Post
    The thermostat is where it takes the reading. Do you have multiple thermostats?
  1. Please service my Hot water tank-no hot water!
    Latest Threads: 12-30-2012, 09:29 PM
  2. Hot Water Tank, no hot water.
  3. 17 year old robs 86 year old woman.
    By signature7 in forum Society / Law / Current Events / Politics
    Latest Threads: 11-14-2008, 06:34 PM
  4. 5 year old & 8 year old DJ's
    By Speed_69 in forum Misc. Gallery
    Latest Threads: 01-18-2008, 10:10 PM
  5. Error, Error, Error
    By finboy in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-10-2004, 12:57 PM
