Garage Door only opening a foot - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Garage Door only opening a foot
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    Default Garage Door only opening a foot
    So for the last week while its been super cold when I open my garage door from the panel outside or the button inside it goes up about 6 - 12 inches - sometimes even 2 feet and then stops. Then I have to press the button and it goes down then pressing the button it either does the same thing again or it goes up normally. Is this normal behavior when its -30 out or could something be wrong with the door function to have it behaving this way
    @andyl, would be great if you could chime in;
    Quote Originally Posted by BavarianBeast View Post
    Could have been over 60% if I wasn’t a paper hand bitch
    Jun 2007
    Calgary/Alberta
    used to happen to us in an older house, depends on the tracks, if they accumulate ice/resistance then yah the door will stop or pull back down as the motor/cable is only designed to have so much tension as its going up. Take a look if if you can see any buildup or obstructions on the track/cable and possibly use some de-icer, and I can't recall the freezing temperature of WD40 but that could also help to run down the tracks
    Nov 2013
    2013 Scion FR-S 10-Series M/T
    I'm not an expert but try oiling the garage door hinges and rollers and see if that helps. I'm guessing the upper hinges are causing a lot of resistance tripping the motor when the door reaches the curved part of the tracks.
    Only 15min from Aspen!
    Nothing interesting anymore
    Your opener will have adjustments for force limits. Look up the manual for it, and decrease the opening force limit which will allow it to use more force when going up. Probably a dial under the light cover.
    Feb 2008
    AMGGGGGGsixtythree
    Quote Originally Posted by colinxx235 View Post
    had this happen too. Tracks/rollers. One side would actually pull more and then it was stuck.... crookedly.
    calgary ab
    4x4
    Increase opener force - cold makes things bind a bit more.
    Newer without a force setting - you need to reprofile the forces. It'll be written beside the buttons.
    No wd40. It's bad mmmmmkay
    Quote Originally Posted by AndyL View Post
    Listen to this man.
    Also WD40 is a solvent, which can therefore work as a great dirt attractor and a short term lubricant
    calgary ab
    4x4
    Wd40 doesn't get along with one of the plastics used in one brand of garage door rollers.
    Princess auto crappy tire, home Depot, Lowe's, all sell a proper garage door lubricant. Or mix ATF/30wt if you're old school.
    The one place I would recommend wd40 is if the tracks are getting jammed with frost from condensation. Wd40 reduces that kind of buildup.
  1. Garage door rubber seal between parts of the door
    By nzwasp in forum Home and Garden
    Latest Threads: 11-05-2017, 11:03 PM
  2. Water damage near garage door opening
    By The_Rural_Juror in forum Home and Garden
    Latest Threads: 12-28-2013, 11:31 AM
  3. How'd you get your foot in the oilfield door?!
    By dsilvia89 in forum Careers
    Latest Threads: 01-19-2013, 11:48 PM
  4. Replies: 9
    Latest Threads: 09-22-2010, 02:13 AM
  5. Free: Overhead Door CodeDodger ACSCTO Type 1 Garage door remote
    By Zero102 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 12-20-2009, 04:47 PM
