deleted
deleted
What if the previous owner tampered with it and scammed Honda West?
Or is it just a malfunctioning gauge cluster?
Minus the oil change issue...
Did you accidentally change the speedometer to read MPH? (I believe it is one of the buttons on the left of the steering column)
80 km/h = 50 mph
50 km/h = 30 mph
The odometer would also change from KM to Miles if you had accidentally pushed the button (62000 miles = 100000 km)
deleted
So for the speedometer to be wrongby that much your gearing/tire size would have to be way out of whack. Post your tire size and also verify with gps what your gps speed vs speedometer speed is. A 5% difference between gps speed and speedometer speed is within reason but more than that and I’d question whether your setup is correct.
Not to side with the dealer but I personally doubt they’d screw around with something so easy to catch but I could be wrong
So that's what it is. I didn't touch anything. But somehow it is showing miles. Alright, let me delete this thread.This quote is hidden because you are ignoring this member. Show Quote
But that still can't explain all those false reading on the oil life gauge in the past 6 mth. though
You, sir, have most likely solved the dilemma.This quote is hidden because you are ignoring this member. Show Quote
As far as low mileage vehicles, they do exist - our last two SUV's were both ridiculously low mileage previously owned units, one still had the protective plastic wrapping on the DVD screen and player, headphones hadn't been unwrapped from original packaging. The other was under 70,000km for a 15 year old unit, senior's second vehicle that was used for church and groceries.
Will fuck off, again.
Oil indicators are a function of time and km. You probably timed out the oil and needed a change, despite not driving many km. Your car probably has a 6-month oil change interval...
Sounds to me like you switched the cluster to imperial as well lol.
I would recommend spending some time with your manual...
lol at deleting the posts after dragging dealers name through the mud. Also fire your mechanic friend.
I vote this as the thread of the evening.
The more I re-read the funnier it got.This quote is hidden because you are ignoring this member. Show Quote
Lol at whole thread.
Now enough with the weather thread FFS![]()
aw man, i missed the fun. TL;DR?
OP came in swinging that Honda West did altering to the odometer and also based this off their "friends" mechanic. Another poster questioned if they switched from kilometers to miles and that was the case.This quote is hidden because you are ignoring this member. Show Quote
in what world would Honda West benefit from doing that? OP, get new friends.
fuck this is lame, i wanna see the OP
OP is the same person who wanted to get gull wing doors mounted on Honda Civic coupe or something like that, that was a special thread as well.
Noticed OP has deleted their posts in this thread, so ballsy OP is.
Just curious who your mechanic friend is and where he works?This quote is hidden because you are ignoring this member. Show Quote
Well played.
Sounds like a dude thats never worked at a dealer because they always sussed out his superior intelligence in the interviews.![]()
hahaha oh man this is gold
