Air fittings? - Beyond.ca - Car Forums
Results 1 to 15 of 15
Thread: Air fittings?
    Thaco's Avatar
    Oct 2004
    Rage2
    Default Air fittings?
    Hey all, just curious where people get air fittings locally? somehow i need to get from a 3/8 BSP to a 1/4 tube... seems like there's no such thing, but i am even having trouble finding adapters to switch between the 2.
    i'd even settle for a 3/8 bsp to 1/4 npt... i already have a 1/4npt>1/4 PTC tube
    User title molested by Rage2.
    ^^ Fact Checked
    Cochrane, AB
    Trucks
    I would just braze with 45% silver, two brass or steel ones together, or one of each. Easy job once you locate two fittings that can fit inside each other, even extremely loosely.
    Thaco's Avatar
    Oct 2004
    Rage2
    the fittings should be like $5 or less, i'd rather buy the right things instead of having it blow up in my face.
    ^^ Fact Checked
    May 2009
    skeans
    Blood for Boost
    Cochrane, AB
    Trucks
    Silver will hold much more than 1000 psi. It’s a common method for joining dissimilar metals and certainly more reliable than any threaded joint. If the fitting you are looking for doesn’t exist, making one is very easy. Even just double tapping a solid piece of stock.
    Sep 2002
    BoostLand
    something green
    Oct 2008
    South of Calgary
    is broken
    Pervert Mart (Peavy) seems to have good selection of air fittings.
    Mar 2009
    Silverado
    I've used green line before with success
    Thaco's Avatar
    Oct 2004
    Rage2
    Quote Originally Posted by dirtsniffer View Post
    thanks, i checked their site a couple times but couldnt find it, but i think i was able to find what i need this time, now hopefully they have it in stock since its a pretty obscure item.
    ^^ Fact Checked
    N/A
    Princess Auto always seems to have a very good variety of air fittings, maybe try them?
    Will fuck off, again.
    Thaco's Avatar
    Oct 2004
    Rage2
    Quote Originally Posted by speedog View Post
    yeah that's where i got most of my stuff for this project, unfortunately the staff has practically zero knowledge on the stuff.
    and it doesn't look like they carry any BSP stuff
    ^^ Fact Checked
    Aug 2005
    2007 4Runner
    Check out Unified Alloys they are the Parker rep they'll have what you're looking for. I'm sure I got what you need in Swagelok which is another option but that won't be cheap ether.
    May 2009
    G37X
    Greggs should have it. Make sure you know if you need BSPP or BSPT though.
    Mar 2009
    Silverado
    And there is a greggs almost right next door to greenline
    Thaco's Avatar
    Oct 2004
    Rage2
    thanks all, i called greenline, this is a normally stocked item for them, but they only had one in stock, they'll have them for me tomorrow.
    ^^ Fact Checked
  1. Compressor Air line fittings
    By Vtecmini in forum Mechanical
    Latest Threads: 05-04-2007, 08:45 PM
  2. Door Rubber fittings
    By aosorno1 in forum Mechanical
    Latest Threads: 08-23-2004, 06:53 PM
  3. Where to find earls fittings in town.
    By djfob in forum Performance Modifications
    Latest Threads: 03-05-2004, 11:12 PM
  4. Fittings
    By Taupe20 in forum General Car/Bike Talk
    Latest Threads: 10-17-2002, 05:04 PM
