Looking for a mechanic for replacing struts - Beyond.ca - Car Forums
Results 1 to 20 of 20
Thread: Looking for a mechanic for replacing struts
    Calgary, Ab
    Question Looking for a mechanic for replacing struts
    on my 2001 Honda Prelude.
    Anyone recommend a shop or a mechanic?
    thanks.
    Damn +44411's
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    Jackie at Balance Auto...
    He can swap the parts and perform the alignment for you...
    ...@therealarifjina...
    06 S2000
    Quote Originally Posted by EK 2.0 View Post
    +1 for Jackie.
    My car sounds like shit.
    Feb 2005
    Cummins F10
    +1 for Jackie.
    +2
    you cant go wrong with Jackie
    Originally posted by Mibz
    The criteria for being a Beyond Baller is simply knowing you are one.
    Deleted F10 535d
    My hybrid burns Diesel & Oil
    Jan 2006
    Axis powers
    I found struts extremely easy to do, you can get full kits that are preassembled then just go for an alignment after
    Sig nuked by mod.
    Quote Originally Posted by T-Dubbs View Post
    +2
    +3
    957,958,NC1,NC3,E90,ITR
    Plus Four. Jackie is
    Aug 2017
    'Berta
    A bunch of Nissans..duh.
    Quote Originally Posted by adam c View Post
    I've decided to DIY too, just not looking forward to extremely rusted bolts and figuring out how to drill them out if I break the heads. ...
    Jan 2006
    Axis powers
    Liquid wrench is your friend, also the bolts are pretty thick it would take a lot to break them... at least on the cars I’ve worked on
    Sig nuked by mod.
    Thaco's Avatar
    Oct 2004
    Rage2
    yeah struts are super easy, usually just take the wheel off and remove like 4 bolts, typically you can do them without messing with any of the ball joints or anything., and you can even bust the bolts most of the time because they're built in to the strut so it doesn't matter, you're replacing them anyway
    if i were to pay a shop i'd go to beyond transmission, they do full auto, really honest guy, he's my inlaws neighbour, will never do work you dont need and will only suggest work you do need... fully set up for the alignment too.
    User title molested by Rage2.
    ^^ Fact Checked
    Aug 2017
    'Berta
    What do you mean by "bust the bolt"...pardon my ignorance, the only time I've gotten in trouble with a bolt was doing my axle back muffler, I sheared off the head so I ended up just drilling a new hole through it...is there a method to busting bolt? Cuz when I do install some coilovers, it would save me a lot of time if there was a way to just knock it out and replace...
    Sep 2016
    Calgary, Ab
    2021 Zonda CRV
    Ryan @ Hu's Garage.
    Aug 2011
    Strathmore
    2005 Dirtymax
    Quote Originally Posted by NissanFanBoy View Post
    Suspension bolts and exhaust bolts are nothing alike except being a bolt. If you worried about breakage then soak everything in PB blaster and when you reassemble use anti-seize.
    Thaco's Avatar
    Oct 2004
    Rage2
    the only bolts that are small enough to bust on a strut are the top ones which are typically built in to the strut, so they will be tossed in the trash with the old strut anyway so you dont need to worry about it if they do break.
    (see on the far right side of this pic. )
    ^^ Fact Checked
    Calgary, Ab
    are you referring to those kits like Monroe Quick struts? They don't make them for Preludes.
    Anyways, thanks guys, I will head to Balance once my struts arrive.
    Damn +44411's
    What do you mean by "bust the bolt"...pardon my ignorance, the only time I've gotten in trouble with a bolt was doing my axle back muffler...
    You are either a) Very lucky b) Haven't done much vehicle work c) Only own summer driven, 2017 or 2016 vehicles.
    Busted bolts happen and even more so if you don't prep the bolts you're taking off.
    Easily can add an hour + onto the install job depending.
    Aug 2017
    'Berta
    Answer would be B lol... On my old Murano, I was trying to take off the AC compressor to get to the alternator, rounded off the last bolt, said fuck it and got access to the alternator from the top lol
    Jan 2006
    Axis powers
    I must be in the A) category as I’ve never busted a bolt, on a car anyways
    Sig nuked by mod.
    Thaco's Avatar
    Oct 2004
    Rage2
    also must have never done exhaust work, lol, heat basically welds nuts to the bolt, thats practically the only way to get some of them off.
    ^^ Fact Checked
    Jan 2006
    Axis powers
    I'm sure I could have, I was lowering my old Integra and couldn't get one of the struts apart so I took it to Canadian tire and they had to torch it to loosen
    Sig nuked by mod.
  1. FS: Stock 05-06 Struts/Springs With Struts Mounts
    By EG_Civic in forum Automotive Parts [Suspension/Handling]
    Latest Threads: 10-26-2011, 12:19 PM
  2. Replies: 0
    Latest Threads: 10-08-2008, 04:15 PM
  3. Replies: 14
    Latest Threads: 11-15-2006, 03:34 PM
  4. Replacing hatchback struts?
    By ryeguy_85 in forum General Car/Bike Talk
    Latest Threads: 02-26-2006, 08:11 PM
  5. Replacing Struts
    By 2.2vtec in forum General Car/Bike Talk
    Latest Threads: 06-13-2005, 05:20 AM
