Changing a water pump on a Mitsubishi Lancer (4G69) - Beyond.ca - Car Forums
Results 1 to 4 of 4
Thread: Changing a water pump on a Mitsubishi Lancer (4G69)
    Calgary, Ab
    Question Changing a water pump on a Mitsubishi Lancer (4G69)
    Hey guys,
    anyone know if the water pump can be removed without pulling the timing belt off? I know the belt covers need to be removed, but I'm hoping the timing belt doesn't have to be messed with. Yah, I was one of those idiots that didn't change the water pump with the TB.
    Oddish setup on Mitsus, the water pump is not run by the timing belt but the accessory serpentine belt. You'd think they would make it so the pump could be pulled easily with out having to go anywhere near the timing belt.
    thanks.
    Damn +44411's
    '16 F150 Lariat, SW20 MR2
    from what i can see the tensioner needs to come out to pull the pump. if you're planning on doing it yourself, its pretty easy as long as you match all the timing marks up.
    Calgary, Ab
    @ShermanEF9
    I kinda thought that was the case, but I have not confirmed... where were you looking for info?
    Damn +44411's
    i googled it and found a video i watched.
  1. FS: Long Block 4G69 Mitsubishi 2.4 Mivec (Outlander, Lancer Raliart, Eclipse, Galant)
    By yohan4ws in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 11-06-2015, 10:33 AM
  2. FS: SOHC VTEC head, crankshaft, piston sets, rods, oil pump, water pump
    By Sentry in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 08-13-2010, 06:37 PM
  3. Hot Tub - Changing the Water?
    By E46..sTyLez in forum General
    Latest Threads: 05-26-2008, 02:10 PM
  4. lancer gear changing thing
    By Nekura in forum General Car/Bike Talk
    Latest Threads: 03-10-2008, 10:50 PM
  5. Engine,Motor,fuel pump,Repair kit,Nozzle holder,Nozzle,VE pump,VEpump part
    By chinahanji in forum Automotive Parts [Engine Electronics]
    Latest Threads: 10-20-2006, 09:42 PM
