LF: Repairing brass fitting for pressure washer/ or where to buy replacement - Beyond.ca - Car Forums
Results 1 to 20 of 26
Thread: LF: Repairing brass fitting for pressure washer/ or where to buy replacement
    '91 NA1 ADVAN'D
    Default LF: Repairing brass fitting for pressure washer/ or where to buy replacement
    Well this is from a Simoniz pressure washer, apparently Hose Reel Connector Kit B, SKU: VE01-002-0002
    Which they're out of, but will gladly sell the entire reel
    Anyways, looking to have the brass fitting repaired (or if anyone know's where I can get a generic replacement).
    Thanks in advance!
    Jan 2007
    Calgary Alberta
    2012 F150, R6
    I would check Gregg Distributors, should be able to find something under brass fittings. They have an online catalog.
    https://www.greggdistributors.ca/catalogue.php
    "Speed has never killed anyone, suddenly becoming stationary… That’s what gets you."
    '91 NA1 ADVAN'D
    Thanks, I actually looked them up already. They don't have anything like that. I can't think of any brass fitting supply warehouses off the top of my head.
    Cochrane, AB
    Trucks
    I could braze it, but what is attached to that piece? Looks like a banjo fitting.
    Mar 2005
    Pushbroom
    Simoniz eh? Go to Canadian Tire on a quiet day with a wrench.
    Alberta Forest and Garden on Meridian Rd. Has weird parts like this. Was just there on Friday for a new unloader for my pressure washer.
    Dec 2004
    YYC and YVR
    Princess auto actually a crap ton of brass fittings for pressure washers.
    '91 NA1 ADVAN'D
    Thanks for all the leads guys. I'm going to try Princess Auto first then over to Alberta Forest and Garden to see if they have something that'll work.
    '91 NA1 ADVAN'D
    Just an update. Went to P.A and also AF&G w/o avail unfortunately
    6.7 CUMMINS, E50 AMG
    Jun 2003
    KTM
    If they cant warranty it or provide the part and its still the "current model" I know exactly what i would do..... buy new, return old. So annoying when companies dont back their product.
    '91 NA1 ADVAN'D
    Unfortunately not the current model, still haven't been able to locate a replacement part locally.
    Material looks too thin to be TIG welded, other ways to fix this?
    Dec 2005
    not calgary
    changes every year
    Get it brazed.
    Cochrane, AB
    Trucks
    Quote Originally Posted by JDMMAN View Post
    You can't weld brass, have to braze it.
    '91 NA1 ADVAN'D
    Anyone have suggestions on where to braze it?
    what is the wall thickness? i have tig welded brass on several occasions. usually not pretty but can be machined/sanded back down to look better.
    i thought at first it had a really thin wall but looking at it, it looks around 1/8'? if it is i could probably weld it without a backer. brazing with silfos or something would work but i am the suck at brazing.
    imo it should be clamped tight back to original shape, the crack should be vee'd out a bit (machined) still clamped or re-clamped then welded with silicon bronze or aluminum bronze rod? or brazed? that will give the best chance of successful functional repair lol
    '91 NA1 ADVAN'D
    legendboy - yup ~1/8" thick. Not sure if it would require the crack to be machined or not, but probably clamped together to close up the crack?
    Cochrane, AB
    Trucks
    If you are out near Cochrane I will braze it up for you in 20 seconds. Brazing everything is what my job entails. Maybe it was bronze that can’t be welded, I tried TIGing one of the two and it was nasty.
    that be the brass (zinc)
    he sounds pretty confident, i'd take him up on the offer
    Cochrane, AB
    Trucks
    Quote Originally Posted by legendboy View Post
    I'm more concerned on why it broke. Something must have been twisting it to crack it and it will likely happen again.
    '91 NA1 ADVAN'D
    Darell_n - thanks for the offer, I can pop into Cochrane fairly easily. Not sure how it broke, I don't believe it was from the pressure. Perhaps it fell and hit something?
  1. Pressure Washer Parts, Unloader Valve, no pressure
    By eblend in forum Home and Garden
    Latest Threads: 04-08-2019, 07:08 PM
  2. Replies: 2
    Latest Threads: 05-09-2011, 01:23 PM
  3. Replies: 7
    Latest Threads: 05-11-2010, 03:26 PM
  4. where to get these brass fitting parts in Calgary?
    By 92_VTEC_lude in forum Mechanical
    Latest Threads: 07-20-2007, 11:38 PM
  5. Brazing a brass fitting on an aluminum pan.
    By ZMan2k2 in forum Mechanical
    Latest Threads: 05-03-2005, 08:04 PM
