Electrical Panel - which switches control doorbell and thermostat? - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Electrical Panel - which switches control doorbell and thermostat?
    Jan 2007
    Default Electrical Panel - which switches control doorbell and thermostat?
    Looking to install a ring doorbell and ecobee soon, before I resort to trial and error, figured I would ask here first. Anyone know what switches control the doorbell/thermostat?
    Thanks
    May 2010
    furnace is normally a light switch near the furnace itself.
    Cochrane, AB
    Trucks
    The pics are too small to read when zoomed in.
    Jul 2007
    it's most likely one of the lighting ones, there's no way to 100% identify from the panel unless the electrician actually labelled it
    The SHBARUS
    Only the major ones are accurate on mine. Furnace should be label. See if there is even a switch by the furnace. Doorbell can be anything.
    I couldn't find the one for my doorbell. I ended up just turning the whole house off.
    '08 Audi A6 4.2L S-line
    Typically the Doorbell is run to a plug nearby the main electrical panel. Should be a big Square black plug, in a local outlet off the panel.. As far as the circuit number, might be worth some trial and error - Plus you can get a nice full description of all the electrical filled in if you properly log all the plugs/lights each circuit affects.
    2020 Subaru Forester Sport
    Thermostat runs off the furnace, so find that, usually close to furnace is a switch.
    Doorbell run on 24V transformer usually, I wouldn't even bother disconnecting or powering that off, won't shock you. I never bothered
    Jan 2007
    Oops, should have seen that.
    https://i.imgur.com/1acH08e.jpg
    https://i.imgur.com/3Wk3JdU.jpg
    Thanks for the replies everyone.
    FB6
    Quote Originally Posted by nagooro View Post
    It's probably going to be on one of your utility receptacles near the bottom of the panel. My transformer was on the breaker of the receptacle that it was beside.
    Apr 2006
    06 WRX
    Found my doorbell breaker via looking for the transformer, which was right beside the panel (might have been hooked right up to the outside of it?).
    First go around, my Ring ended up fried. Not sure if it was because I did it without killing the breaker, or that I did it first without upgrading the transformer or chime. I wouldn't have thought much would have changed in doorbells since 1997, but apparently I was wrong.
  1. Question re: work on the doorbell chime
    By wildrice in forum Home and Garden
    Latest Threads: 01-10-2018, 02:33 PM
  2. Doorbell with camera that stands up to our winters?
    By Sonic in forum Home and Garden
    Latest Threads: 06-10-2017, 09:04 AM
  3. Nest thermostat to replace old thermostat and humidistat
    By saziz111 in forum Home and Garden
    Latest Threads: 05-23-2017, 02:32 PM
  4. Source for random electrical switches and dials?
    By blitz in forum Computers, Consoles, and other Electronics
    Latest Threads: 02-05-2016, 05:44 PM
  5. Replace Civic 96-98 heater control panel with 99-00 panel, need help
    By snow_daniel in forum General Car/Bike Talk
    Latest Threads: 09-07-2006, 12:05 AM
