Sand blasted driveway - any major downsides vs a typical concrete one? - Page 3 - Beyond.ca - Car Forums
Page 3 of 3 FirstFirst ... 2 3
Results 41 to 46 of 46
Thread: Sand blasted driveway - any major downsides vs a typical concrete one?
  1. #41
    May 2005
    2015 IS350 F Sport
    Quote Originally Posted by nagooro View Post
    After posting on a few forums, I think a top coat is out.
    Either push for a re-pour, or sand blast+seal, but get them to guarantee the work. If it starts falling apart a year or two later they do a re-pour cause obviously the slab below the top layer isn't up to par as the tests showed.
    Edit: a bit off topic, but how are exposed aggregate driveways in the winter for shoveling and slipperyness? Seems like shoveling would be a pain as it's not as smooth as a broom finish?
    They are fine but it does make a difference with what kind of rock is in there. That's why I suggested a repour with the proper formula for exposed rather than just sandblasting it.
  2. #42
    Jan 2007
    In the end, they are going to sandblast the driveway, if the same issue occurs it'll be a complete removal/re-pour. They sent me the reports from the corehole samples which appear to meet the concrete specifications, which is I guess why they are backtracking from the original re-pour option.
  3. #43
    Dirty_SOHC's Avatar
    Dirty_SOHC is offline 0.2 liters away from a good engine
    Jul 2002
    WRX
    Quote Originally Posted by Lex350 View Post
    Get them to rip it out and do it properly. The exposed look you like you won't achieve with the current driveway because the concrete formula is different. The rock used is different.. When you get the new concrete done make sure you apply a sealer to is after.
    What is a good sealer for a brushed finished driveway? I have been always afraid that the driveway would bead water which could freeze in winter and make a skating rink...
  4. #44
    Mar 2005
    Foothills County
    is faster than yours
    Quote Originally Posted by Dirty_SOHC View Post
    Talk to these guys for a recommendation:
    https://www.nca.ca/locations/nca-branches/calgary
  5. #45
    May 2005
    2015 IS350 F Sport
    There is a place called Northland construction supplies that sells a variety of sealers. At my old place I had an exposed driveway and steps. I sealed it every second year. Never had a problem with freezing outside of what a normal driveway might have.
  6. #46
    Mar 2005
    Foothills County
    They are now part of NCA that I linked above.
  1. Concrete driveway / sidewalk
    By Masked Bandit in forum General
    Latest Threads: 07-25-2008, 09:08 AM
  2. Any downsides to declaring bankruptcy?
    By rc2002 in forum Real Estate / Finance
    Latest Threads: 06-10-2008, 09:09 PM
  3. concrete driveway resurfacing
    By 2fast4me in forum General
    Latest Threads: 09-25-2007, 05:41 PM
  4. what sand paper to use to sand body kit?
    By Freebs in forum Cosmetic and Styling Modifications
    Latest Threads: 03-26-2007, 01:24 PM
  5. any downsides to getting a vw gti 2002?
    By lerner04 in forum General Car/Bike Talk
    Latest Threads: 05-28-2005, 03:43 PM
