Recommendations on where to get rotors turned for cheap? - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Recommendations on where to get rotors turned for cheap?
    '91 NA1 ADVAN'D
    Default Recommendations on where to get rotors turned for cheap?
    It's been ages since I've gotten rotors turned. I think it used to cost ~$5/rotor to have machined down (if they're not close to the minimum thickness).
    Preferred recommendations in the NW if possible.
    E39 M5, E39 540i wagon, 86 Mustang GT, 02 Impreza
    Most shops have a brake lathe, and it's definitely not going to cost 5 bucks a rotor.
    100% Bow tie
    This, it may just be better to spend just a little bit more and get new rotors.
    Moran supreme
    2g Eclipse / EP3
    Unless you know a person working at a brake shop, 5$ a rotor .... good luck.
    Depending on the vehicle, it might be cheaper to buy new discs. I recall the mistake I made years ago when going to CT to fix my front brakes. They ended up turning the brakes, but it was 40$ per side, when brand NEW brake discs would have been 20$ per side.
    Food Court Wifi
    100% SAVAGE
    For common cars, if you are halfway mechanical, you can easily buy new from rockauto or similar for less than getting somewhere to turn them.
    I like foodie meets
    '91 NA1 ADVAN'D
    Thanks for the response guys. I actually do almost all of the mechanical work myself and buy new each time vs. running turned rotors. However there's one set of Endless I have which is special order from Japan ~$500/pair, I had forgot to spray it down with a petroleum based lubricant prior to storage and there's a bunch of corrosion which formed on the surface that I couldn't "buff" out with the wire wheel. Just just looking to have the surface lightly machined to expose new material.
    The other set of rotors I have had some pad deposits formed on them, replaced with new Brembo blanks on the car, but wanted to have a spare set kicking around. Again, just looking for a slight shave on either side to remove the deposits.
    The last time I had gotten rotors turned was back in the mid-late 90's back round then it was ~$5/rotor @ CT; I've always replaced with new as the rotors got worn to minimum thickness.
    GX470
    Id imagine a few hard stops would clear most of the issues up..
    Protege 5 Turbo / Ecoboost FX4
    Had the same problem as you. Specialty Wilwoods that I needed turned.
    McCall brake and Muffler did them, and I even bartered down to $50 for the pair. They turned them three times.
    '91 NA1 ADVAN'D
    Maxx Mazda - Thanks for the lead. Too bad I don't turn enough rotors to justify having a brake lathe. The last time I did a DIY it was back in HS autoshop.... damn that was ages ago! lol
  1. Rotors Turned in Calgary?
    By amorak in forum Mechanical
    Latest Threads: 08-11-2014, 07:32 AM
  2. Good place to get rotors turned?
    By blktopbig28 in forum Mechanical
    Latest Threads: 06-22-2009, 09:01 AM
  3. Magnum Cross Drilled Rotors or KVR Cross Drilled Rotors
    By JDM_RS13 in forum Performance Modifications
    Latest Threads: 06-13-2005, 06:51 AM
