Rooting phone, to get rid of crap/bloat ware, worth the trouble? - Beyond.ca - Car Forums
Results 1 to 20 of 21
Thread: Rooting phone, to get rid of crap/bloat ware, worth the trouble?
    Nov 2003
    Calgary / AB
    '13 MazdaSpeed 3, Zoom Zoom!
    Default Rooting phone, to get rid of crap/bloat ware, worth the trouble?
    I'm trying out Android after many years of being an iPhone user. There seems to be a pile of preinstalled apps on phone I will never use.
    Am considering doing root to get rid of them.
    Phone is already out of warranty period so no issue there.
    Anyone recommend for or against doing this?
    My Karma ran over your Dogma
    Don't know, but interested in the subject. Subscribed.
    Aug 2011
    Strathmore
    2005 Dirtymax
    Do it. Problem is that some apps do root checks as do games and you won't be able to use them.
    You can but I;ve found that even factory apps can sometimes be disabled from the service menu.
    Jun 2004
    21 CX5 GT Turbo
    What phone are you trying to root?
    Nov 2003
    Calgary / AB
    Moto x play 1563
    Yep, got Facebook, Instagram and all those useless apps disabled.
    Nov 2003
    Calgary / AB
    For anyone that's done it, did you do it yourself?
    Any suggestions for where to find instructions?
    (maah raahde)
    If you're going to go through all that trouble, you may as well just wipe it and install a custom ROM without all that stuff already. Chances are you'll get a newer version of Android than what the manufacturer is providing as an added bonus.
    I'm a big fan of LineageOS myself cause they try to keep the OS as close to pure Android as possible without too much extra bloat. Pixel Experience has caught my eye too but it doesn't have the device support LineageOS does.
    If you've never done this or don't have good Linux experience, it can be a little overwhelming so make sure you don't skip any steps:
    https://download.lineageos.org/lux
    https://wiki.lineageos.org/devices/lux/install
    Nov 2003
    Calgary / AB
    Well I took a good 3-4 hour stab at installing new ROM, and think I'm almost there, but they lost me on the later steps.
    I did: unlock bootloader, install recovery tool, downloaded ROM (decided to try Pixel Experience instead, cuz it has Google Apps pre-installed).
    Then it all went to hell when instructions got vague.... this is example of what trying to do:
    First, download and install a custom recovery. If you already had a custom recovery installed on your device then skip this step.
    Download Andriod 8.0 ROM and Gapps from above and save it on your device.
    Now Boot your device into Recovery mode.
    Now in TWRP, create a Nandroid backup (Recommended) of your device for safer side, if anything goes wrong.
    Now do a Factory Reset by Goto Wipe>Advanced Wipe>Select Wipe cache, Dalvik cache, System, and data and swipe to confirm it.
    Now, Go to Install and locate the ROM zip file & swipe to Install the ROM file. After the process completes, Flash the GApps zip file.
    Now wipe cache & Dalvik cache again and Reboot your device.
    Done!
    Each of those steps alone seems like a feat, lol.
    Anyone have link to installing new ROM for dummies?
    Is there no section on XDA forum for your phone? Thats my usual go-to.
    Aug 2011
    Strathmore
    2005 Dirtymax
    Quote Originally Posted by cidley69 View Post
    Done!
    Those are very simple steps and once you get the recovery environment installed you will see this.
    The nandroid backup is just to ensure you have a copy of your original OS before doing anything
    Gapps should some in different variations and I usually choose a minimal which gives you play store and gmail. This gets installed after the ROM.
    They are all .zip files which the recovery will install automatically for you
    Also I recommend twrp recovery if you can.
    (maah raahde)
    Follow the install link I provided. The steps are the same regardless of what ROM you're using.
    Saskatchewan, Canada
    What does banking apps think about rooting?
    Nov 2003
    Calgary / AB
    Followed the instructions, everything went smooth, until halfway through the update, got this error:
    E: Footer is wrong E: signature verification failed
    Aug 2011
    Strathmore
    2005 Dirtymax
    At what part and what were you doing to get that error?
    Nov 2003
    Calgary / AB
    Found the problem, I accidentally downloaded old or unstable version of TWRP, and it didn't match the instructions.
    Got that fixed, now i am hung up on the step:
    Place the LineageOS .zip package, as well as any other .zip packages on the root of /sdcard:
    Using adb: adb push filename.zip /sdcard/
    You can use any method you are comfortable with. adb is universal across all devices, and works both in Android and recovery mode, providing USB debugging is enabled.
    for some reason, adb does not see the phone anymore, when I use command: adb devices.
    I can go into sideload in TWRP, and then device shows up with adb devices, but I am not able to copy the zip file to sd card.....
    I get this error:
    PS C:\Users\fernm\Desktop\Phone Tools\platform-tools> .\adb push lineage-14.1-20180817-nightly-lux-signed.zip /sdcard/
    adb: error: connect failed: closed
    any ideas how I can get zip onto sd card? Can i do it first, before entering recovery mode, then not wipe it during the install steps?
    Aug 2011
    Strathmore
    2005 Dirtymax
    I get this error:
    You have a couple of options.
    1) SD Card - If you have a spare place it on that and insert into phone
    2) ADB - Can be a bear and a pita to get working properly
    3) Boot into phone and download to phone
    I always find 1 the easiest with 2 the second.
    Nov 2003
    Calgary / AB
    Got it.
    Not sure why all the trouble, but its finally working.
    Big thanks for the help!
    Anyone reading this interested in rooting your device, do it!
    Its pretty easy process really.
    Nov 2007
    Your Mom's House
    Did it with my Huawei P10 Plus. Their EMUI interface wouldn't bring the phone up in Android Auto, so I had to hack in Google Dialer using Magisk and a Google Framework package.
    Anyway, cool discovery is that most of the P10 Plus phones share the exact same hardware.
    In North America, the phone has single SIM with Micro SD port.
    In Europe, the phone has dual SIM.
    Install firmware from Europe and now I have dual SIM capability but can still use the MicroSD. Also got Oreo way before Rogers ran the update, and I get the monthly Android updates.
    They did fix their EMUI so I'm considering going back to stock, but it's such a pain setting everything up again.
    Found that any stock update that came through meant I had to download the entire ROM, run a script in TWRP to install it from SD, and then push TWRP again to recovery once the update was complete. Such a pain, once Waze and the Phone app started working with Android Auto I stopped installed TWRP...updates work fine now.
  1. Get rid of home phone?
    By Robin Goodfellow in forum Home and Garden
    Latest Threads: 09-04-2015, 12:36 PM
  2. F1 2014 - Who are you rooting for?
    By Sykes in forum Formula 1
    Latest Threads: 02-06-2014, 02:16 PM
  3. wanted: android rooting/romming help
    By Davex in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-30-2012, 06:56 PM
  4. Tred from your tires ware off from racing?
    By bosa in forum General Car/Bike Talk
    Latest Threads: 08-30-2002, 10:05 PM
