Whole house humidifier recommendation - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 52
Thread: Whole house humidifier recommendation
    MooooooO
    AWD grandpa wagon
    Default Whole house humidifier recommendation
    I am looking to replace my old-school aluminum box humidifier. Did some research and most websites recommend two types of whole house humidifier, by-pass or steam.
    All the ones available at Home Depot are made by Honeywell and they received very sub-par review. It seems like that's the only brand Home Depot carry. In fact, even the King Air and Lennox brand from other stores (eg Rona and Lowes) received sub-par reviews.
    What are people using in their home (if you have one). What type and what are the pros and cons of your unit?
    BTW, this is for a 1500 sq. ft. home.
    Mar 2009
    '18 Murano
    I switched from the Wait 5000 (those are fine, but the pad gets a lot of build-up, had a valve fail and parts are price) to a Desert Spring.
    Can't really tell you if it works any better, but it's easier to maintain.
    Hmm Canadian Tire has 'em $50 off, says clearance, wonder if they're dropping the line.
    http://www.canadiantire.ca/en/pdp/de...3101p.html#srp
    Have heard good things about desert spring.
    Steam is a good way to pump a lot of moisture into the system, but not sure how much energy they use, and how they handle Calgary hard water.
    Nov 2003
    2008 Mercedes Benz C230, 1968 Chevy Impala
    I have a basic honeywell one but it gets softened water to reduce the buildup. You can hit the diffuser with some clr every few months to extend its life pretty easily.
    1968 Impala: Status: Stored
    1977 Dodge Triple E RV: Sold
    1989 Mercedes Benz 420 SEL: Sold
    2008 Mercedes Benz C230: Cruising
    2000 Bluebird TC2000: Build phase of skoolie project
    2018 Rav4 XLE: New baby friendly daily
    MooooooO
    AWD grandpa wagon
    Sounds like from a cost efficiency stand point, the basic rotary disc type is the way to go.
    I have a cheapo drum type, works waay better in terms of adding humidity to a large house than a single waffle pad.
    Was a life (nasal) saver this past winter ..... however it does need annual maintenance in terms of pan cleaning and the drum pad, either mid season or post winter..... whereas a pad you just toss.
    The Desert Spring is the optimal solution but with the autoflush system it does approach north of 350$
    2020 Subaru Forester Sport
    I used to have a basic drum one, now have a passthrough, not the most efficient thing, but not like you are going to notice 25c worth of water on your bill.
    ^ so thats just a water soaked pad that air has to flow through ?
    Metal mesh pad, I have that one.
    Yea those dont work really well in bigger homes.....
    No they do not.
    Works well enough in mine, too well even, I'm at 1600 square feet.
    Sep 2008
    Edmonton, AB
    +3 for the Desert Spring. Works way better then our GerenalAir unit.
    You can get it with the autoflush from Amre Supply for $323.
    Our GerenalAir "mesh" would clog really fast and the solenoid finally clogged on ours (no water softener).
    Originally posted by Xtrema
    Originally posted by DayGlow
    How do you respond to stupid?
    Originally posted by rage2
    Originally posted by Seth1968
    ^ yea if we decide to stay here past 2020, I would invest in that for sure.
    Humidifier discusison update! Seriously considering Desert Spring. Have the Generalaire pictured above currently. Have 2/4 people in my household with respiratory issues that would be greatly reduced with higher humidity.
    How tough is the install? I'm handy-ish, but want to know if there's tips or pitfalls.
    Sep 2012
    How is the GeneralAire not keeping up? I can jack mine up to insane humidity levels in winter if I want. 2000 sq ft house.
    Is it installed on the proper side?
    Interesting question, how is it SUPPOSED to be installed? I always assumed it was, but hey, I'm willing to investigate.
    Apr 2004
    I have a similar metal pad style and it seems to work ok. I’ve got it linked up to my ecobee and keep it set at 40%. I would really like to go 55% but want to avoid mold and also frost issues when it starts to get super cold. Nice thing is that ecobee has this setting called “frost control” where it will temporarily turn off the humidifier when it hits a certain outdoor temp (I think -18 or something)
    I guess I did discover this summer that the Furncae was drawing WAAAAY too much fresh air into the house when it was running, so I have that damped down to much less and that should help with humidity too.
    Sep 2012
    Check out the manual:
    https://www.cgfproducts.com/fck_uplo...%20REV%20B.pdf
    The unit is supposed to be installed onto the return air plenum. The illustration is preferred even though it says it doesn't matter, as our air is so dry that the temperature differential matters (source: every furnace guy that looks at my furnace and shakes their head).
  1. Whole house humidifier
    By nzwasp in forum Home and Garden
    Latest Threads: 06-25-2012, 10:56 AM
  2. Best Whole House humidifier?
    By eblend in forum Home and Garden
    Latest Threads: 01-04-2012, 04:26 PM
  3. Whole house filter (water)
    By benyl in forum Home and Garden
    Latest Threads: 12-07-2011, 02:38 PM
  4. Things you learn when renovating your whole house.
    By Seth1968 in forum Home and Garden
    Latest Threads: 02-10-2011, 10:14 AM
