Halogen to LED headlight conversion? - Beyond.ca - Car Forums
Results 1 to 20 of 28
Thread: Halogen to LED headlight conversion?
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    Default Halogen to LED headlight conversion?
    So, same issue with my 2016 F150 as my 2012. The stock halogens are HORRIBLE at night, and in most situations, I might as well just shut them off completely for how much light they throw. I tried swapping to different and "brighter" halogens, but the gains are barely noticable at best.
    Thinking about swapping to LED headlight bulbs. Is it worth it? will it help with night driving? Can i use the stock housing or should I be looking to do a completely new housing? Anything special I should be looking out for? Any particular brands I should be looking at or staying away from? I haven't done an upgrade like this before, so I am not sure what else I should be researching.
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
    Dec 2008
    All over
    CAEB, 6G72
    A buddy of mine just put some LED's in his 2015 Explorer, and it made a huge difference. The explorers have a kind of projector light housing though so it worked out. I'm not really sure what the F150's have but if it's a projector style as well then you should be fine. If it's not a projector type housing you will just look like every other truck in Alberta who runs HID's in halogen housings.
    As for brands, I'm not sure what a good kind would be. He got his off of amazon, and they had pretty good reviews, so I guess time will tell how long they last.
    If your housings are projector, then they should be ready for LED or HID (sort of passe though). If not, you are looking at a housing swap. Simpy slapping brighter bulbs is not the optimal solution.
    check a 2016 F150 specific forum .... im sure youre number 12435 person with the same complaint!
    Not Aspen
    Two from Freemont
    Jul 2008
    Edmonton, Alberta
    Retrofit or buy the correct housing. Just putting bulbs in will do nothing but throw light everywhere.
    on a map.....??????
    changes daily :D
    LED's are not the same as HID's. you can easily swap a LED light in and have more/brighter power without blinding the rest of the world. I was having the same issue with my accord, and swapped to led's. used to have hid's. with the hid's i was getting flashed all the time because people thought they were my brights. with the led's i have not encountered anyone who has had an issue with my headlights, and it gives me at least 50% more light output than halogens.
    Jun 2014
    Thats the best way for sure but for some its a hard pill to swallow buying that set up
    Quote Originally Posted by infamous View Post
    I had no idea leds were like that, always assumed hid or led in a non projector is a mess
    Oct 2006
    '21 F150 PowerBoost
    Yeah, I have been doing some research. I don't think I want to go the whole replace housings, and wires through the firewall and such.
    In reading, it seems that the most important part is keeping the LED placement as close as possible to where the filament placement is once inside the headlight housing. Doing so keeps nice cutoff lines and light loss as the light source is in the same spot as OEM, and where the reflectors were designed for.
    The F150 forums has been a pretty big help, and I think I am now pretty confident in just replacing my low beams to LEDs as I can't recall the last time I used my high beams.
    Turbos cost money
    May 2004
    2005 F350
    in my opinion, the best way would be get the ANZO headlights with the projector beams in them and swap the halogen bulbs out with LED's. You can get the LED kits and the ANZO headlights from some of the forum sponsors on F150forum.com
    give your truck a cool new look and have it functional as well!
    Dec 2008
    I don’t think that’s exactly true, LEDs still have similar scatter problems. Here is good thread with emperical evidence you can see from the before/after the scatter from LEDs is brutal. Could be different depending on the design of the halogen housing but IMO LEDs suffer the same fate as HIDs in halogen reflectors and shouldn’t be done
    https://www.tacomaworld.com/threads/...ectors.454371/
    Quote Originally Posted by SOAB View Post
    This
    Jan 2003
    I have only looked at the first few post in the thread, but the original poster's LED bulb design isn't really a "correct copy" of the halogen H4 bulb design. The position of the LED might be pretty close, but it is missing the shields at the bottom. I haven't done any scientific studies, but these seem to be a closer design to the H4 bulb.
    https://www.powerbulbs.com/ca/produc...ed-headlamp-h4
    and a slightly cheaper version...
    https://www.powerbulbs.com/ca/produc...dlight-h4-twin
    Dec 2008
    Quote Originally Posted by ZeroGravity View Post
    Interesting yea you’re most likely right, LED design is a huge factor. This guy claims the first one you posted works well
    https://www.tacomaworld.com/threads/...review.405019/
    I might have to look at LEDs again, I initially wrote off LEDs in factory housings in my F150 as every single person that posted had god awful scatter. Probably because they were buying the $70 specials...
    Jan 2003
    A friend of mine tried a pair of those ~$50 specials from amazon. From the looks of the photos, the bulb design does have similar look to that of those expensive Philips ones. I have the same car as his (2015 Honda Fit), but I didn't try those because it requires some trimming of the rubber gasket plug to make room for the heat sink.
    The more expensive Philips set's heat sink is a separate screw on piece so it is more likely that one doesn't have to cut that rubber gasket piece. The cheaper / but still quite spendy one looks to be one piece. This set doesn't have / need the separate voltage converter box thingy.
    MooooooO
    AWD grandpa wagon
    The Philips LED will ensure you get the ideal output and alignment than the $70 specials. Also, TRS have XB retrofit headlights for your F150. But it'll cost a pretty penny.
    Alternatively, if you don't want to drop few hundreds into a set of LEDs bulbs, the Philips Xtreme Vision +110 halogen (not the +130, way too much blue coating on the bulb).
    Would it be cheaper to add decent after-market, LED light elsewhere? External mounted projectors?
    Oct 2006
    '21 F150 PowerBoost
    I found this guy's post really informative, and he seemed to hit all the spots. I am thinking I may just follow his lead and give this a try before committing to a $1000+ package to completely replace the housings and all.
    https://www.f150forum.com/f118/led-h...-bulbs-370732/
    Turbos cost money
    Bump. Did you end up doing this?
    My main reason for the bump is I now see Canadian Tire is producing an H1 bulb in LED. I was excite but there's just zero chance this thing fits. H1 halogen bulbs are tiny and they tend to clip in. There's no way this bulbous thing is going to fit.
    Has anyone else ever found an H1 in LED that was feasible?
    https://www.canadiantire.ca/en/pdp/h...p.0200512.html
    2020 Subaru Forester Sport
    I know it's an old thread but since it was bumped i might as well ll comment. I have replaced 9007 bulbs with 4WDKING lights from Amazon and they made a huhe difference in my wifes Pontiac Vibe standard housing. Instructions state to make sure LEDs are pointed horizontally. No blinging with these but insane output. I have just recently installed same bulbs in H7 in my dad's Mitsubishi Outlander with projectors and they also had a nice normal cutoff with LEDs horizontally. I hate people with blinding lights but as long as installed correctly I think it's not really an issue.
    They look just like the H7 bulbs I just installed into dad's car. Same idea, you will need an adapter. I got some on ebay for $5 shipped. The adapter slides onto the bulb, the bulb would go into the normal spot with the adapter, and the cable from the bulb plugs into the original clip. The adapter is designed to replicate the clip. Have to find one that matches your clip or car. Name:  $_10.jpg
    Mar 2009
    Silverado
    Halogen bulbs for halogen housings. No need to blind every other driver on the road
  1. LED vs. Halogen for spot light use?
    By Fly Fishin' in forum General Car/Bike Talk
    Latest Threads: 09-17-2015, 03:05 PM
  2. FS: 4x6 H4 Halogen Headlight housing w/bulbs
    By jalalx5 in forum Automotive Parts
    Latest Threads: 12-11-2013, 05:11 PM
  3. Replies: 0
    Latest Threads: 06-10-2012, 09:34 PM
  4. FS: sylvania silverstar halogen light bulbs
    By _wrx_ in forum Automotive Parts
    Latest Threads: 11-22-2004, 02:40 AM
  5. Replies: 24
    Latest Threads: 07-15-2004, 12:00 AM
