Powdercoating your bike frame? - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Powdercoating your bike frame?
    Default Powdercoating your bike frame?
    Anyone done this vs. painting?
    Where should I go? Shops aren't exactly clamouring for a small project like this to powdercoat.
    Thanks.
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    I've used Silverline in Airdrie a few times...but mainly for wheels. and they did a Valve Cover for me once....
    Maybe they would take on a frame??....
    ...@therealarifjina...
    '14 Taco
    Bring back plastidip?
    I'l give silverline a call.
    Jun 2005
    '05 Subaru LGT wagon (5MT)
    I have had Calgary Powder Coatings do two frames and one fork. One frame they did a really good job and masked off everything I asked for. The second frame and fork, they did not mask off everything properly and they sandblasted the fork steer tube, which I requested they not do. The lack of masking added a couple of hours to assembly time as I had to cut the powder out of the head tube, bb shell, seat tube, brake mounts and steer tube crown. The sand blasting on the steer tube meant that the bearing race is not a press fit anymore and I had to lock tight it in place (it still spins fine and the headset stays tight but had it been any worse a rare fork would have been ruined).
    I think Top Gun will also do bike parts and they do much smaller runs of things than CPC so I am planning on trying them next time.
    Does Calgary Powder Coatings they have a large selection of colors?
    I recall that Top Gun didn't have a large selection when I was powdercoating car parts but that could have been their high heat color chart. I forget.
    Jun 2005
    They don't have a huge selection. Stuff like metallic (metal flake or gold/silver/copper/chrome), transparent or candy, base/clear, matte they don't have.
    Rite-Way seems to have a large selection, and with some of those higher end effects you need somebody with experience in applying them or they can turn out pretty bad. Some times things like metal flake needs a clear top coat applied while the base and flake is still liquid so it takes some knowledge and skill to do that without smudging or smearing something and ruining the effect. If they are only used to coating a whole rack of parts, rolling it in and rolling in out of the oven then they will have a hard time with custom masked parts and multi-layer coatings.
    EDIT: Rite-Way's website shows them masking intake manifolds and shows already sprayed auto suspension/chassis parts. These parts take a lot of prep work so if they are confident in doing those, they should be able to do a frame and fork and small parts as well.
    6.7 CUMMINS, E50 AMG
    i have a few bikes i want to repaint, frame forks. wespen will dip strip them for $65 and JIT will powder coat for $150. I thought the powder is a bit high. going to call top gun
    edit: top gun is 140-200 depending metallic
  1. door frame chinup bar without drilling/harming door frame?
    By wardpr68 in forum Health and Fitness
    Latest Threads: 08-03-2010, 02:40 AM
  2. Replies: 4
    Latest Threads: 08-03-2009, 05:08 PM
  3. Free: 2 twin matresses, 1 box spring, 1 metal frame, and another wooden frame with..
    By SkittleFreak in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 03-08-2008, 04:29 PM
  4. anybody can do powdercoating for some bike wheels?
    By Rockski in forum Wheel and Tire Discussion
    Latest Threads: 03-06-2007, 12:53 PM
  5. WTB: Oakley A-Frame goggles (just the frame)
    By Afrodeziak in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-26-2007, 07:12 PM
