Recently I have had an inspection done from Infiniti and they stated the car needs a new steering rack and are asking for nearly 2000 dollars for the job.
I have ended up finding a rack and pinion on rockauto for about 500-600 CAD with warranty by A1 Cardone. My car is an 08 G35x Sport with 119,000 kms.
The car does wander on uneven roads and the steering pulls to where ever the dip in the road may be. I know the alignment is definitely out also but so far no leaks have been noticed or change in the power steering fluid reservoir. Steering is slightly on the heavier end than it should be.
I have been in search for a competent mechanic in the Calgary Area that can do the job for me as I do not possess the necessary tools nor the expertise.
If anyone on the forums can direct me in to the right direction your help will be greatly appreciated.
Cheers.
