Whirlpool dishwasher leaking right side. - Beyond.ca - Car Forums
Results 1 to 20 of 20
Thread: Whirlpool dishwasher leaking right side.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    Default Whirlpool dishwasher leaking right side.
    Does anyone know what this thing is circled in red? can it leak its right above the area that is leaking in my whirlpool dishwasher.
    The inlet hose doesnt leak which is where I would of expected to see a leak. Below this when I look under the dishwasher there is this white plastic bit which the water drips past. Its sort of on the right side just in from the door.
    Quote Originally Posted by BavarianBeast View Post
    Could have been over 60% if I wasn’t a paper hand bitch
    N/A
    Float valve switch and yes, leaks can occur here. Easy fix.
    Will fuck off, again.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    so I took the entire thing out and found that the switch underneath wasnt locked into place so I replaced it back making sure everything clicked in. Turned on the dishwasher and it doesnt leak anymore but also no water sprays or enters the dishwasher when I turn it on. Ive got no idea why just from taking that one piece apart I would suddenly lose the washing ability entirely. Any ideas?
    N/A
    Sounds like your float valve is buggered now as it controls water coming into the dishwasher.
    One step forward, two steps back?
    Only 15min from Aspen!
    Nothing interesting anymore
    When you locked it into place, it might have wedge itself in the "close" position.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    thanks for the tip I will disconnect the power and have another look. I dont really want to take the whole dishwasher out and fuck with it because the water inlet hose on this dishwasher is metal to plastic and really finicky to stop that from leaking. So ive just been fucking with it from the bottom access panel.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    Took the entire thing apart and found that the switch had rattled off, put it all back on. Ran the dishwasher on a 1 hour wash - fucking thing rattled off in the drain phase and leaked a bit on the floor. Looks like im gonna have to replace that whole switch and switch housing - I suspect that the float itself is probably fine.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    So i think that Ive fixed this now. I noticed on the drawing that there is a gasket that the assembly for the float attaches to inside the dishwasher and I ordered it just to see if this was my problem. I got home and took everything out and then noticed that the gasket inside mine was missing or maybe inadequate, it looked nothing like the gasket i purchased which was the same size as the nut that went over the top of it. I put that gasket on and then the nut and the new float and so far no leaks.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    Now its leaking at the back right side, cant fucking win with this dishwasher!
    @speedog Everhad a leak at the back right side?, it appears to be leaking or dripping when its on washing cycle. I fixed the float leak. I read it could be a possible puncture in the tub, although its stainless steel tub.
    I think Ive found my issue:
    Name:  hole in tub.jpg
    What I think caused this is someone put a knife in the top rack that fell during washing into the bottom and punctured the tub wall in the process. Im not sure how the tub isnt thick enough to avoid this kind of damage. Makes me think twice about knives though. Unsure what sort of compound I would use to fix the tub now though.
    N/A
    A hole in your dishwasher from a knife, that is about as unlikely a thing I would've ever expected to occur.
    As for fixing it, probably some sort of heat resistant epoxy. Bizarre, absolutely bizarre.
    That's amazing, and incredibly unlikely.
    Don't know of a good long term fix. If it was me, I'd just be buying a new one at this point.
    N/A
    It's that fucking nanny, she's messing with you through your dishwasher.
    Tell me about it. I just had to throw out a $1600 Bosch dishwasher because of how thin the fucking tub was. (accidentally creased the front bottom lip, no chance of it not leaking after that)
    N/A
    Beginning to think plastic tubs are the way to go, we've only had plastic and have never had any denting, creasing or puncture issues
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    Marine epoxy is applied see what it’s like in the morning. It looks like I’ve just splashed some white paint sloppily on the back of my dishwasher.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    Well after 9 hours curing it still seems very epoxy like but I had the dishwasher door closed so Im going to leave it open during the day and see if it cures better, in the mean time does anyone have any brands and models they recommend? (not samsung)
    Aug 2006
    calgary/AB
    95B
    In our current house we have Bosch and I am extremely happy with it. So far we had no issues at all. Touch wood.
    This is the model we have
    https://www.bosch-home.com/us/produc...ces/SHX68TL5UC
    Bosch is the one. They are quite sensitive to detergent brand, so just buy the finish all in ones and you'll be fine.
    Quote Originally Posted by ganesh View Post
    My Bosch started leaking a couple of times a year after 4 years. It was during the last leak repair that I accidentally damaged it and made it even worse. The problem with the original leaks was because of stainless steel screws in plastic holes. They loosed up over time. The thing did run great before that though, loved how quiet it was.
    This was mine.
    https://www.bosch-home.ca/en/productlist/SHX7ER55UC
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    The marine epoxy has survived a couple of washes now. It only felt dry after 20 hours of no dishwashing. I also bought some JB weld high heat epoxy if this stuff fails.
  1. FS: Whirlpool Dishwasher
    By imritzbitch in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 04-25-2008, 02:47 PM
  2. FS:Free black whirlpool Dishwasher
    By Takemetoothemoo in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-18-2007, 04:52 PM
  3. FS: Whirlpool Washer NEW
    By [.shiny.] in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-19-2007, 06:00 PM
  4. FS: Whirlpool Fridge & Stove
    By Hernando in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 04-15-2006, 11:50 PM
  5. FS: Whirlpool Ultimate Care II Double Capacity Washer & Dryer
    By GoChris in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-28-2004, 02:30 PM
