Fast ticking sound when driving straight and cornering right side only - Beyond.ca - Car Forums
Results 1 to 11 of 11
Thread: Fast ticking sound when driving straight and cornering right side only
    Calgary,AB
    2013 Toyota Highlander Sport
    Default Fast ticking sound when driving straight and cornering right side only
    This sound did not occur at all when I had my all seasons on.
    I put my winters on during the snowy day on tuesday and drove with them on wednesday (didnt notice the noise) and thursday. When I am driving the car straight on the right side I hear this ticking noise which is very noticeable when I turn corners, only on the right and appears right front side. I felt around the tire when I got home but did not notice any plastic or anything hitting the tire or something protruding from it. All the lug nuts are tight as well so I dont think thats the problem. I thought possibly theres a rock stuck in the tread which could be causing this problem as it does sound like something is in there and is striking the road every turn.
    The car is a 2014 Kia Forte 5.
    Food Court Wifi
    100% SAVAGE
    First guess rock in tread. Second guess cv joint.
    Quote Originally Posted by Kobe View Post
    @ExtraSlow is a real inspiration to everyone on Beyond and the internetz!
    Calgary,AB
    Do CV joints usually fail within the first 50K of a cars life.
    Jul 2007
    MK7.5R
    hubcentric rings still left on?
    S.E. (not the drrty south)
    Blandness
    Not usually, but any part can be bad from the factory. Also maybe check your dust shield and see if it's hitting a piece of ice on your wheel?
    2g Eclipse / EP3
    You might have picked up a nail and the head has popped off. I had this exact issue once and it was a pain to find as it was barely visible - just the stud of the nail was protruding barely above the tire surface.
    Stupid ticking noise al day long and it was obvious as it was ticking at every tire rotation, louder the faster you went.
    Secret City, Alberta
    2018 Civic Si
    Start checking your tire pressure daily, then weekly if no change (unless you have TPMS). You should know in a month or 2 if a puncture has happened, though some can seal up really well and not leak noticeably in even months.
    Jap V8
    +1 for nail or screw or bolt or something. If it was a rock big enough to hear it, probably would have popped out eventually. If you can't find it by feeling around the tire, I'd take the ten min to pull the tire off and check carefully.
    You have a Kia. Nothing's out of the question.
    Calgary,AB
    Good idea I will do that this weekend.
    E39 M5, E39 540i wagon, 86 Mustang GT
    Fast ticking? Wile E Coyote planted some dynamite under your car.
    Calgary,AB
    Driving my low car over the snow I had accidentally torn off one of my mudguards and there was a piece dragging on the ground.
  1. Ticking sound in motor - Subaru
    By LilDrunkenSmurf in forum Mechanical
    Latest Threads: 10-25-2010, 10:15 PM
  2. Cornering question...
    By drox in forum Bike Talk
    Latest Threads: 10-06-2006, 11:30 AM
  3. Honda D16 "ticking" sound
    By dainom89 in forum General Car/Bike Talk
    Latest Threads: 06-03-2006, 09:03 PM
  4. Help! what this ticking sound?
    By Zoom_Zoom in forum Mechanical
    Latest Threads: 11-13-2005, 06:24 PM
  5. ticking sound is that a really bad thing to hear???
    By surferbaby13 in forum Mechanical
    Latest Threads: 10-04-2003, 03:03 AM
