Rear Main Seal Additive ? - Beyond.ca - Car Forums
Results 1 to 15 of 15
Thread: Rear Main Seal Additive ?
    Mar 2014
    Default Rear Main Seal Additive ?
    I went to a jiffylube to get an oil change on my winter Santa Fe and in the notes they wrote down small leak from oil pan and rear main seal. I haven't seen any leaks in my car before and got me all paranoid. A rear main seal is a big job....
    I'm monitoring to see if i see any leaks and will probably head over to my friends shop with a hoist to further investigate when i have the time but IF there is one that is minor, has anyone used a additive to your oil that stops a rear main seal leak? I know it sounds dumb but read a few people use it to prevent a $1,000 repair bill.
    Jun 2012
    Take a look at LiquiMoly Motor Oil Saver. Reviews seem favorable.
    Feb 2006
    CEF4
    Ralli Machine
    Quote Originally Posted by ducaudi View Post
    Strangely we were recommended Moly-Save specifically for our Santa Fe 3.3L. Seems to be much happier with it. Run it in all my cars now. Interestingly it was developed to be used in Aircraft so the engine wouldn't seize on loss of oil pressure. This is from the company propaganda but I've read it elsewhere too (BITOG maybe?)
    What is MoS2?
    So what is Liqui-moly MoS2?
    At Liqui-Moly, it actually all started with this product 40 years ago and today it is still our leading oil additive. MoS2 was originally developed to maintain lubrication in piston-driven aircraft engines in the event of a loss in oil pressure and to prevent complete engine seizure. The incredible low-friction and robust lubrication properties of Molybdenum-Disulfide (MoS2) have been well known for years. The production and patenting of a liquid, additive form of Molybdenum-Disulfide in 1957, was Liqui-Moly’s first product and formed the basis of the company.
    Cos...
    Mar 2014
    Quote Originally Posted by The Cosworth View Post
    I have the same Sante Fe, the 3.3L.
    I guess it doesn't hurt to just add it in even if there is no major leak? At most it might have been a sweat or something there for them to mention it.
    Feb 2006
    CEF4
    Ralli Machine
    Quote Originally Posted by jabjab View Post
    I had no issues (except the annoying startup, which I am not sure is normal) running it. All I heard is use 1 bottle the first time, then 1/2 a bottle there after as some of it sticks to the insides so you don't need as much.
    Cos...
    I'd review it. Maybe just sweating vs full leak. Winter will expose it more so with a bigger spread of hot and cold cycles. Do you find you need to top the oil up between changes?
    The pan gasket, might try tightning the bolts a bit. Like 1/8th of a turn type. Do not over tighten at all.
    Rear main seal, your only option is the seal softener/oil additive.
    Mar 2014
    What start up issue? Is it loud for a few seconds on cold start up? Almost like chains rattling? I've been told by Hyundai that it is normal and using a oem filter helps with that cause of a check valve or something.
    - - - Updated - - -
    I haven't found the need to top up any oil. If it is a sweat vs full leak I'd rather use an additive now while i can before an additive wouldn't do anything cause a seal is so badly worn.
    Feb 2008
    Not Aspen
    teslo murdel free
    Won't be the rear main, there's a oil pressure switch and harness that are notorious for leaks. $25 for the switch and $32 for the harness
    Jul 2008
    Edmonton, Alberta
    Ford was telling people that too, until it turned out to be stretched timing chains. don't believe them.
    Jan 2006
    Axis powers
    I've used one in the past, I think it was Blue Devil rear main stop leak, worked like a charm on that car
    Sig nuked by mod.
    Jun 2011
    West of the Pen
    Toyota Christopher Lambert
    I've used ATP AT-205 re-seal in the past for a rear main seal leak, it helped/worked.
    Mar 2014
    ordered a few bottles of the Liqui Moly Oil Saver from Amazon. Going to use a bottle and see how it goes.
    Feb 2006
    CEF4
    Ralli Machine
    Yep the same I would think. It just sounds rough for 20 seconds then is good. Isn't an issue on startup if it was running recently. Im not sure if it is the variable valve timing building oil pressure or something else. I hate it though. Feels like crap. Glad this was an economical choice compared to the Highlander we were looking at otherwise I'd be pissed. I like it for the $$ though over-all. Good decent bagger for wife, kids, and dog.
    Quote Originally Posted by ShermanEF9 View Post
    I've pushed super hard. They tell me it is normal also. Without it failing can't make them fix it, and they won't even investigate it.
    Cos...
    Feb 2008
    Not Aspen
    teslo murdel free
    You should check the oil pressure switch before buying all that
    Mar 2014
    Quote Originally Posted by eglove View Post
    thanks! I will get it on a hoist this weekend.
  1. Need someone to change rear main seal
    By benz_890 in forum Mechanical
    Latest Threads: 10-03-2010, 12:20 AM
  2. WTB: S14 sr20 Rear main seal
    By teknical in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 05-22-2009, 09:39 AM
  3. rb20det Rear main seal
    By nismoskyline86 in forum Mechanical
    Latest Threads: 11-20-2008, 12:59 PM
  4. NEEDED: rb20det rear main seal
    By nismoskyline86 in forum Automotive Parts
    Latest Threads: 11-19-2008, 11:38 PM
  5. WTB: SR20 Rear main seal
    By Genjuro in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 11-04-2008, 05:58 PM
