Originally Posted by
rage2
Sonos beam is way louder than 2 minis. It’s comparable to 2 homepods but that route is stupid expensive. I tried all 3 setups over the holidays and ended up with the beam. You can also expand rear speakers with the beam. The HomePod has atmos support but it’s terrible. Also, one of the major drawbacks of using homepods is that it only works if you use Apple TV. If you decide to have say an Xbox there later, you only get sound from tv speakers.
I’m assuming volume is a must for you if you’re riding a peleton.
As for tv choice for peleton use, just get one bright enough for the environment. Everything else is overkill. Assuming you won’t be using the tv for anything else.
