Vacation + water softener - do you turn it off? - Beyond.ca - Car Forums
Results 1 to 20 of 33
Thread: Vacation + water softener - do you turn it off?
    Jan 2007
    Default Vacation + water softener - do you turn it off?
    If you're going to be away from home for a few days (or more), are you turning off your water softener?
    Cochrane, AB
    Trucks
    No. It only works on demand and won’t regenerate if no water is being used. Turn the water off for the entire house instead.
    2020 Subaru Forester Sport
    My manual says otherwise, so I would say you should check on that as well. Mine says after x amount of liters of water (based on hardness setting) or every 2 weeks regardless. My vacations are usually 3 weeks long for the most part, I never bother, just leave it and let it do it's thing.
    Cochrane, AB
    Trucks
    Well, the house water should definitely be off during vacation. The softener will be idle in this case.
    A week? no ..... 3 weeks? = water off
    Hum, i travel like 6-8 weeks of the year, never turned off water, don't see the point?
    Cochrane, AB
    Trucks
    I’ve had a hot water tank rupture twice in 14 years and a hot water hose blow clean off the underside of my kitchen sink, all while being nearby. Could you imagine the damage from an unchecked major water leak over a 6 week span? (or 2 hours with my kitchen sink instead of the 20 seconds it took me to kill it). I think insurance would bend you over badly. I turn mine off if I leave for a weekend.
    how would insurance "bend you over badly"? Is insurance not valid unless you turn off master water supply every time you leave the house? Of course not. It's valid, period.
    In one trip? If youre gone for 2 months most home insurance requires a check person every so often.
    Cochrane, AB
    Trucks
    Many are only valid for 5 days unattended.
    a van down by the river
    Bmw and ford
    Mine only regen with demand ... never turned it off.
    Oct 2002
    Corvette
    No, never turn it off. Works fine this way, no issues.
    Quote Originally Posted by BigShow View Post
    the beads like being recharged even if nobody is using water... so either you use your capacity and it does it right away (or switches tanks if its that super marketed kenitco) or it does it by itself on a set number of days even if you haven't used its capacity
    Chevy Colorado ZR2
    Since early spring, my regeneration stopped working.
    The system does it's thing but the salt from the brine tank stays the same.
    I would assume either is broken or both.
    No sorry, usually 2 or 3 trips a year.
    And I guess it's different because I have cats and my parents drop by every second day to feed them and check on the house.
    Bicycle
    The language is not turning it off, but have someone checking your home's water and heating system periodically while you are away.
    https://park.ca/blog/2015/09/21/3-co...ance-coverage/
    But turning it off and draining the pipes will reduce the risk in the event of heating failure while you are away. So I do exactly that if I'm away more than a week.
    Chevy Colorado ZR2
    Does anyone know a good water softener installer/repair? Thanks!
    Jan 2007
    Quote Originally Posted by jaylo View Post
    Derek @ BRM installed mine and was highly recommended from other members.
    http://www.thewaterman.ca
    May 2010
    Most policies are not valid if no one checks on the place. Other option exist like turning off the water. I suspect it depends on the policy but every one I have had states I need to either have water off or have someone check the place.
    Chevy Colorado ZR2
    Quote Originally Posted by nagooro View Post
    Thanks @nagooro
  1. Water Softener Not working - suggestions?
    By Horatio in forum General
    Latest Threads: 05-03-2010, 03:54 PM
  2. For Free! 2 bags of water softener salt
    By 78si in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-20-2009, 08:28 PM
  3. Water Softener Advice
    By cooperS in forum Home and Garden
    Latest Threads: 06-22-2009, 02:27 PM
  4. Replies: 4
    Latest Threads: 10-16-2008, 09:41 PM
  5. A good water softener
    By riceboi in forum General
    Latest Threads: 11-04-2007, 09:09 AM
